Hey there,
I want to control Tradfri Bulbs via zigbee2mqtt.
I found some stuff here and over at zigbee2mqtt, but I think its more an openhab issue, so I’m posting here.
I am already able to control light level with a Slider in the UI, but I cant seem to manage to control the color temperature. Well, I could make it all cold white with the slider, but now it seems to be stuck there. Could you guys have look at my transforms, I think I did something wrong there.
tradfri_flur1.items
Switch tradfri1_TOGGLE “tradfri1 [%s]” {mqtt=">[broker:zigbee2mqtt/tradfri-flur-1/set:command::JS(setZigbeeState.js)],<[broker:zigbee2mqtt/tradfri-flur-1:state:JSONPATH($.state)]", expire=“120m,command=OFF”}
Dimmer tradfri1_DIMM “tradfri1 Dimm” {mqtt=">[broker:zigbee2mqtt/tradfri-flur-1/set:command::JS(setZigbeeBrightness.js)],<[broker:zigbee2mqtt/tradfri-flur-1:state:JS(getZigbeeBrightness.js)]"}
Dimmer tradfri1_TEMP “tradfri1 Temp” {mqtt=">[broker:zigbee2mqtt/tradfri-flur-1/set:command:*:JS(setZigbeeColor.js)],<[broker:zigbee2mqtt/tradfri-flur-1:state:JS(getZigbeeColor.js)]"}
setZigbeeColor.js
(function(x){
var color_temp = x*255/100;
var result = new Object();
result.color_temp = color_temp;
return JSON.stringify(result);
})(input)
getZigbeeColor.js
(function(x){
var result;
var json = JSON.parse(x);
result = json.color_temp * 100 / 255;
return result;
})(input)
(function(x){
var brightness = x*255/100;
result.brightness = brightness;
})(input)
(function(x){
var result;
result = json.brightness * 100 / 255;
return result;
})(input)
test.sitemap
sitemap default label=“My first sitemap” {
Frame label=“Slide bright” {
Slider item=tradfri1_DIMM
Frame label=“Slide temp” {
Slider item=tradfri1_TEMP
