Hi
Does some now how to convert a variable that contains a unit (seconds) to a formatted string (hh:mm:ss)
Jose
Hi
Jose
You could do this in a rule using the SimpleDateFormat class. If you know how to use Java classes/methods in rules already then this should be pretty easy, if not Iāll try and come back with an example rule later.
Hi
I dont have experiencw with that
Do you have any code to share?
Jose
What is your seconds variable counting from? Does it represent a time such that once I convert it to HH:MM:SS is represents a time of day, or is it just measuring the amount of time since some arbitrary starting point (e.g. when something was switched on)?
If it represents a time of day then @danielwalters86ās suggestion of SimpleDateFormat is the way to go.
If it is the amount of time since some starting point you can do it with some simple math:
val totalMinutes = seconds/60
val remainderSecs = seconds%60
val totalHours = totalMinutes/60
val remainderMins = totalMinutes%60
val formattedTime = totalHours + ":" + remainderMins + ":" remainderSecs
Hi
I tried the config and I have a problem. It seems not to like the %60
Do I need to import specific java library?
The counter is a number that represents a value (seconds minus thread sleep)
Jose
% is the modulo operator and is standard java/xtend.
What error do you get?
Maybe put in a space. Perhaps it is trying to treat it as an escaped character as opposed to the modulo operator. According to the Xtend documentation ā%ā is the right symbol for mod (i.e. remainder).
It also might not like that we are not explicit about type and BigDecimal doesnāt like mod math. If the space doesnāt work try:
val int totalMinutes = seconds/60
val int remainderSecs = seconds%60
val int totalHours = totalMinutes/60
val int remainderMins = totalMinutes%60
val String formattedTime = totalHours + ":" + remainderMins + ":" remainderSecs
Struggling to tell the difference between this latest version and your previous. However there is a concat sign missing before remainderSecs in the last line.
Compare the second word of each line. Iāve added the type to all the vals.
You are correct, there is a missing ā+ā on the last line.
Hi
We are progressingā¦Here is the code and If I declare a value for
seconds, it worksā¦
The problems is how to declare the val seconds with the value of the
counter that is in countdown.
while(Timer_Interrupteur1_ext_avant >= 0) {
//val int seconds = Timer_Interrupteur1_ext_avant
val seconds = 3600
val formattedTime = String::format("%02d", totalHours) + ":" +
String::format("%02d", remainderMins) + ā:ā + String::format("%02d",
remainderSecs)
//Temps_Interrupteur1_ext_avant.postUpdate(Timer_Interrupteur1_ext_avant +
" sec")
Temps_Interrupteur1_ext_avant.postUpdate(formattedTime)
Temps1_Interrupteur1_ext_avant.postUpdate(Timer_Interrupteur1_ext_avant)
Timer_Interrupteur1_ext_avant = Timer_Interrupteur1_ext_avant - 1
Thread::sleep(1000)
Jose
To get the value of an Item you use .state. Assuming your countdown Item is called Countdown and it is a Number Item it would be
val int seconds = (Countdown.state as DecimalType).intValue
HI
I use a variable that is declared globally:
var Number Timer_Interrupteur1_ext_avant
Is it the same way to handle that?
Hi
I tried :
val int seconds = (Timer_Interrupteur1_ext_avant).intValue
and it works
Thanks for your help
Jose
