it is the widget widget_HeatingCSS_2-0-0
I want to set i.e. the example mode item with the heating valve state (Number - Percent)
uid: widget_HeatingCSS_2-0-0
tags: []
props:
parameters:
- context: item
description: Item to control
label: Setpoint Item
required: true
type: TEXT
groupName: mainItems
- context: item
label: Item for current temperature
required: true
type: TEXT
- context: item
description: Humidity Item [Number-Item]
label: Humidity Item
required: false
type: TEXT
- description: eg. living room
label: location and widget identifier
required: true
type: TEXT
groupName: generalSettings
- description: Minimum value
label: minTemp
required: true
type: TEXT
- description: Maximum value
label: maxTemp
required: true
- description: Visual size of the control in px (default 400px), without a size the design is responsive
label: size [px]
required: false
type: TEXT
- description: Control item unit eg °C
label: unit
required: false
type: TEXT
advanced: true
- context: item
description: Heating Mode Item [String-Item]
label: Heating Mode Item
required: false
type: TEXT
groupName: extensionItems
advanced: true
- description: Heating mode strings as array eg. AUTO,MANU,OFF. The string will be send to the Heating-Mode-Item [String-Item]
label: Heating Mode Array
required: false
type: TEXT
advanced: true
- context: item
description: Example Mode Item [String-Item] (eg. State of heating valve)
label: Example Mode Item
required: false
type: TEXT
advanced: true
- description: Example Mode Strings as Array eg. OFF,ON,BOOST. The string will be send to the Example-Mode-Item [String-Item]
label: Example Mode Array
required: false
type: TEXT
advanced: true
- context: item
description: Valve/Alarm Item [Switch-Item] (eg. State of heating valve) for Animation in the center of the widget
label: Valve Item
required: false
type: TEXT
advanced: true
- context: item
description: Extension Item 1 eg. Battery-State [Number-Item]
label: Extension Item 1
required: false
type: TEXT
advanced: true
- description: Choose the F7-Icons for the Extension Item 1 as Array. -> <battery_100,battery_25,battery_0>. 1st Icon = Value > 75, 2nd Icon = Value > 25, 3th Icon = Value < 25
label: Extension Item 1 F7-Icon
required: false
type: TEXT
advanced: true
- context: item
description: Extension Item 2 eg. Battery-State [Number-Item]
label: Extension Item 2
required: false
type: TEXT
advanced: true
- description: Choose the F7-Icons for the Extension Item 2 F7-Icon as Array. -> <battery_100,battery_25,battery_0>. 1st Icon = Value > 75, 2nd Icon = Value > 25, 3th Icon = Value < 25
label: F7-Icon for the Extension Item 2
required: false
type: TEXT
advanced: true
- description: URL or path to a Image (if you use a local img eg. -> http://local-IP-Adress:8080/static/folder/img.svg )
label: URL or path to image
required: false
type: TEXT
groupName: moreDesign
advanced: true
- description: eg. default 1em
label: Custom font-size current&set-point marker
required: false
type: TEXT
groupName: fonts
advanced: true
- description: eg. default 2em
label: Custom font-Size center
required: false
type: TEXT
groupName: fonts
advanced: true
- description: default 1em for eg. Living Room
label: Custom font-size location label
required: false
type: TEXT
groupName: fonts
advanced: true
- description: default eg. 1.8em
label: Custom font-Size buttons
required: false
type: TEXT
groupName: fonts
advanced: true
- description: default 1em for Heating-Label in bottom of the widget
label: Custom font-Size footer
required: false
type: TEXT
groupName: fonts
advanced: true
- label: Main-Color Thermostat
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color control ring
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color buttons
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color center
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color Typo
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color setPoint Marker
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color currentPoint Marker
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color bar linear gradient startPoint
required: false
type: TEXT
groupName: colors
advanced: true
- label: Color bar linear gradient endPoint
required: false
type: TEXT
groupName: colors
advanced: true
- description: Control if the Chart is visible
label: Chart Swtich
required: false
type: BOOLEAN
groupName: chartSettings
- description: currently not possible -> The minimun value of axis. (eg. 10.5)
label: yAxis min
required: false
type: TEXT
advanced: true
- description: currently not possible -> The maximum value of axis. (eg. 30.5)
label: yAxis max
required: false
type: TEXT
advanced: true
parameterGroups:
- name: mainItems
label: Main Items (setpoint-temperature, current temperature, humidity)
- name: advancedItems
label: Advanced Items (Battery-State, ...)
- name: generalSettings
label: General Settings
- name: extensionItems
label: Extension Items
- name: moreDesign
label: More Design Options
- name: colors
label: Color Settings
- name: fonts
label: Font Settings
- name: chartSettings
label: Chart Settings
timestamp: Mar 29, 2024, 10:11:22 PM
component: f7-card
stylesheet: >
.mylink {
#background-color: blue !important;
animation-name: example;
animation-duration: 4s;
} .mylink#####:hover {
text-decoration: underline !important;
transform: scale(1.5);
transition: 0.3s all;
@keyframes example {
0% {background-color: red;}
25% {background-color: yellow;}
50% {background-color: blue;}
100% {background-color: green;}
.thermostat {
flex-shrink: 0;
--f7-block-margin-vertical: 0px;
--f7-block-padding-vertical: 0px;
--f7-block-padding-horizontal: 0px;
padding-left: 0px;
border-radius: 50%;
box-sizing: content-box;
border: 2px solid rgb(64, 60, 77);
.thermostat .bar {
margin-top: 0px;
position: absolute;
top: 50%;
left: 50%;
transform: translate(-50%, -50%);
border-radius: 50%;
} .thermostat .bar .inner_bar {
margin-top: 0;
position: absolute;
top: 50%;
left: 50%;
border-radius: 100%;
z-index: 4 !important;
} .thermostat .bar .inner_bar .block {
content: "";
display: block;
position: absolute;
width: 100%;
height: 100%;
left: 50%;
transform: translate(-50%);
title: "=(props.location) ? 'Klima ' + props.location : ''"
slots:
default:
- component: f7-card-content
slots:
default:
- component: f7-row
class:
- justify-content-center
resizable-absolute: true
resizableFixed: true
slots:
default:
- component: f7-block
class: thermostat
style:
background: "=props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)'"
padding-top: "=props.size ? props.size + 'px': '100%'"
width: "=props.size ? Number(props.size)+'px' : '100%'"
slots:
default:
class: bar
style:
height: "=props.size ? (Number(props.size)*0.89) +'px' : '89%'"
width: "=props.size ? (Number(props.size)*0.89) +'px' : '89%'"
slots:
default:
class: inner_bar
style:
background-color: "=props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)'"
height: "=props.size ? (Number(props.size)*0.86) +'px' : '97%'"
width: "=props.size ? (Number(props.size)*0.86) +'px' : '97%'"
slots:
default:
style:
background: "='conic-gradient(transparent 0deg 160deg, ' + (props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)') + ' 160deg 200deg, transparent 200deg 360deg)'"
bottom: "=props.size ? '-7px' : '-7px'"
class: hold left
style:
background-color: rgb(58, 55, 73)
border-radius: 100%
clip-path: "=props.size ? 'inset(0px 0px 0px ' + (Number(props.size)*0.89/2) + 'px)' : 'inset(0% 0% 0% 50%)'"
height: 100%
margin-top: 0px
position: absolute
width: 100%
slots:
default:
class: fill fill1
style:
background: "=props.colorBarStartPoint && props.colorBarEndPoint ? '-webkit-linear-gradient(top, ' + props.colorBarEndPoint + ' 20%,' + props.colorBarEndPoint + ' 100%)' : '-webkit-linear-gradient(top, rgb(255, 73, 0) 20%,rgb(255, 73, 0) 100%)'"
border-radius: 100%
clip-path: "=props.size ? 'inset(0px ' + (Number(props.size)*0.89/2) + 'px 0px 0px)' : 'inset(0% 50% 0% 0%)'"
height: 100%
margin-top: 0px
position: absolute
transform: "=(items[props.setPointItem].state.split(' ')[0] >= (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp)) && items[props.setPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : (items[props.setPointItem].state.split(' ')[0] > Number(props.maxTemp)) ? 'rotate(180deg)' : '')"
transition: transform 0.6s
width: 100%
z-index: 1 !important
class: hold right
style:
border-radius: 100%
height: 100%
margin-top: 0px
position: absolute
transform: rotate(180deg)
width: 100%
z-index: 3 !important
slots:
default:
class: fill
style:
animation: right 1s linear both
border-radius: 100%
height: 100%
margin-top: 0px
position: absolute
width: 100%
class: fill fill2
style:
background: "=props.colorBarStartPoint && props.colorBarEndPoint ? '-webkit-linear-gradient(top, ' + props.colorBarEndPoint + ' 40%,' + props.colorBarStartPoint + ' 100%)' : '-webkit-linear-gradient(top, rgb(255, 73, 0) 40%,rgb(255, 158, 35) 100%)'"
border-radius: 50%
clip-path: "=props.size ? 'inset(0px '+ (Number(props.size)*0.89/2) + 'px 0px 0px)' : 'inset(0% 50% 0% 0%)'"
height: 100%
margin-top: 0px
position: absolute
transform: "=(items[props.setPointItem].state.split(' ')[0] <= (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp)) && items[props.setPointItem].state.split(' ')[0] >= Number(props.minTemp) ? 'rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))+20)+'deg)' : (items[props.setPointItem].state.split(' ')[0] > (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp))) ? 'rotate(180deg)' : '')"
width: 100%
class: span
style:
bottom: 0px
color: "=props.colorTypo ? props.colorTypo : 'rgb(87, 84, 95)'"
font-size: "=props.fontSizeFooter ? props.fontSizeFooter : '1em'"
font-weight: "=props.size ? (Number(props.size)*2) +'px' : 'calc(var(--f7-list-item-title-font-weight)*2)'"
margin-top: 0px
position: absolute
text-align: center
text-transform: uppercase
width: "=props.size ? (Number(props.size)*0.89) +'px' : '100%'"
z-index: 99 !important
slots:
default:
- component: Label
text: Heating
class: shadow
style:
animation: shadow 1.4s ease-out both
height: 86%
left: 50%
margin-top: 0px
position: absolute
text-align: center
top: 50%
transform: "=(items[props.setPointItem].state.split(' ')[0] >= Number(props.minTemp) && items[props.setPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'translate(-50%, -50%) rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : 'translate(-50%, -50%) rotate(0deg)')"
transition: 0.7s ease
width: "=props.size ? (Number(props.size)*0.0625) +'px' : '6.25%'"
slots:
default:
class: shadow-cube
style:
box-shadow: "=props.size ? '0 0 ' + (Number(props.size)*0.1125) +'px ' + (Number(props.size)*0.0325) + 'px ' + (props.colorSetMarker ? props.colorSetMarker : 'rgba(255, 158, 35, 0.5)'): '0 0 45px 13px rgba(255, 158, 35, 0.5)'"
height: 0px
margin-top: 0px
position: absolute
top: 0
width: "=props.size ? (Number(props.size)*0.0625) +'px' : '100%'"
class: markerContainer
style:
height: 100%
left: 50%
margin-top: 0px
opacity: 1
pointer-events: none
position: absolute
text-align: center
top: 50%
transform: "=(items[props.currentPointItem].state.split(' ')[0] >= Number(props.minTemp) && items[props.currentPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'translate(-50%, -50%) rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.currentPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : 'translate(-50%, -50%) rotate(0deg)')"
width: "=props.size ? (Number(props.size)*0.1) +'px' : '10%'"
slots:
default:
class: markerCurrent
style:
background: "=props.colorCurrentMarker ? props.colorCurrentMarker : 'rgb(33, 150, 243)'"
border-radius: 0% 50% 50% 50%
box-shadow: 0 0 5px 1px rgb(48, 46, 56)
height: "=props.size ? (Number(props.size)*0.1) +'px' : ''"
left: 50%
margin-top: 0px
padding-top: "=props.size ? '' : '100%'"
position: absolute
top: "=props.size ? (Number(props.size)*0.14) +'px' : '15%'"
transform: translate(-50%,-50%) rotate(45deg)
width: "=props.size ? (Number(props.size)*0.1) +'px' : '100%'"
slots:
default:
class: number
style:
left: 50%
margin-top: 0px
position: absolute
text-align: center
top: 50%
transform: translate(-50%, -50%) rotate(-45deg)
slots:
default:
- component: Label
style:
color: white
font-size: "=props.fontSizeMarker ? props.fontSizeMarker : '1em'"
font-weight: bold
text: =Math.round(items[props.currentPointItem].state.split(' ')[0] * 10) / 10
style:
height: 100%
left: 50%
margin-top: 0px
opacity: 1
position: absolute
text-align: center
top: 50%
slots:
default:
class: markerSet
style:
background: "=props.colorSetMarker ? props.colorSetMarker : 'rgb(230, 74, 25)'"
border-radius: 50% 50% 50% 0
left: 50%
margin-top: 0px
position: absolute
top: "=props.size ? (Number(props.size)*Number(-0.0125)) +'px': '-2%'"
transform: translate(-50%,-50%) rotate(-45deg)
z-index: 100 !important
slots:
default:
class: number
style:
left: 50%
margin-top: 0px
position: absolute
text-align: center
top: 50%
transform: translate(-50%, -50%) rotate(45deg)
slots:
default:
- component: Label
style:
color: white
font-weight: bold
text: =Math.round(items[props.setPointItem].state.split(' ')[0] * 10) / 10
class: center
style:
background: "=props.colorControlRing ? props.colorControlRing : 'rgb(227, 228, 237)'"
border-radius: 50%
box-shadow: 0px 15px 35px 11px rgba(46, 44, 58,0.60)
height: "=props.size ? (Number(props.size)*0.65) +'px' : '65%'"
left: 50%
margin-top: 0px
position: absolute
top: 50%
width: "=props.size ? (Number(props.size)*0.65) +'px' : '65%'"
slots:
default:
- component: f7-swiper
pagination: true
params:
direction: horizontal
mousewheel: true
slidesPerView: 1
scrollbar: false
style:
border-radius: 50%
height: 100%
left: 50%
position: absolute
top: 50%
width: 100%
slots:
default:
- component: f7-swiper-slide
style:
height: 100%
width: 100%
slots:
default:
class: page
style:
background: transparent
border-radius: 50%
height: 100%
left: 50%
margin-top: 0px
position: absolute
top: 50%
width: 100%
slots:
default:
class: buttonContainer
style:
display: "=props.heatingModeItem ? '' : 'none'"
height: 100%
left: 50%
margin-top: 0px
opacity: 1
position: absolute
text-align: center
top: 50%
transform: "=props.exampleModeItem ? 'translate(-50%, -50%) rotate(30deg)' : 'translate(-50%, -50%)'"
width: "=props.size ? (Number(props.size)*0.15) +'px' : '15%'"
slots:
default:
- component: oh-button
popoverOpen: ='.' + props.location + '.popoverHeatingMode'
style:
bottom: 0%
color: "=props.colorButton ? props.colorButton + ' !important': ''"
height: 20%
left: 50%
position: absolute
width: 100%
slots:
default:
- component: f7-icon
f7: "=props.heatingModeItem ? (items[props.heatingModeItem].state == props.heatingModeArray.split(',')[0] ? 'hand_raised' : items[props.heatingModeItem].state == props.heatingModeArray.split(',')[1] ? 'arrow_2_squarepath' : items[props.heatingModeItem].state == props.heatingModeArray.split(',')[2] ? 'airplane' : 'thermometer') : ''"
style:
font-size: "=props.fontSizeButtons ? props.fontSizeButtons : '2em'"
margin-top: auto
position: absolute
top: 50%
- component: f7-popover
class: =props.location + ' popoverHeatingMode'
slots:
default:
action: variable
actionVariable: myVar
actionVariableValue: success
class:
- popover-close
clearVariable: true
noShadow: true
slots:
default:
- component: f7-row
config: {}
slots:
default:
- component: f7-col
slots:
default:
- component: oh-repeater
containerStyle:
width: 100%
for: buttonlabel
in: =props.heatingModeArray.split(",")
slots:
default:
action: command
actionCommand: =loop.buttonlabel
actionItem: "=props.heatingModeItem ? props.heatingModeItem : ''"
active: "=props.heatingModeItem ? (items[props.heatingModeItem].state === loop.buttonlabel ? true : false) : ''"
class: margin
color: "=props.colorButton ? props.colorButton : ''"
outline: true
text: =loop.buttonlabel
style:
display: "=props.exampleModeItem ? '' : 'none'"
height: 100%
left: 50%
margin-top: 0px
opacity: 1
position: absolute
text-align: center
top: 50%
transform: "=props.heatingModeItem ? 'translate(-50%, -50%) rotate(-30deg)' : 'translate(-50%, -50%)'"
slots:
default:
popoverOpen: ='.' + props.location + '.popoverExampleMode'
style:
bottom: 0%
height: 20%
left: 50%
position: absolute
width: 100%
slots:
default:
f7: wrench
style:
margin-top: auto
position: absolute
top: 50%
class: =props.location + ' popoverExampleMode'
slots:
default:
action: variable
class:
- popover-close
clearVariable: true
noShadow: true
slots:
default:
- component: f7-row
config: {}
slots:
default:
- component: f7-col
slots:
default:
containerStyle:
width: 100%
for: buttonlabel
in: =props.exampleModeArray.split(",")
slots:
default:
action: command
actionItem: "=props.exampleModeItem ? props.exampleModeItem : ''"
active: "=props.exampleModeItem ? (items[props.exampleModeItem].state === loop.buttonlabel ? true : false) : ''"
class: margin
outline: true
action: command
actionCommand: "=Number(items[props.setPointItem].state.split(' ')[0]) > Number(props.minTemp) ? Number(items[props.setPointItem].state.split(' ')[0]) - 0.5 : ''"
actionItem: =props.setPointItem
style:
height: 50%
left: 10%
margin-top: 0px
position: absolute
top: 50%
width: 30%
slots:
default:
f7: arrow_turn_left_down
style:
margin-top: auto
position: absolute
top: 50%
action: command
actionCommand: "=Number(items[props.setPointItem].state.split(' ')[0]) < Number(props.maxTemp) ? Number(items[props.setPointItem].state.split(' ')[0]) + 0.5 : ''"
style:
height: 50%
left: 90%
margin-top: 0px
position: relative
top: 50%
width: 30%
slots:
default:
f7: arrow_turn_right_up
style:
margin-top: auto
position: absolute
top: 50%
class: valveAnimation
style:
animation: skeleton-effect-fade 2s linear infinite
background: "=props.colorSetMarker ? 'radial-gradient(' + props.colorSetMarker +' 30%, transparent 50%)' : 'radial-gradient(var(--f7-theme-color) 30%, transparent 50%)'"
border-radius: 50%
display: "=(props.valveItem && items[props.valveItem].state == 'ON' )? '' : 'none'"
height: 100%
left: 50%
margin-top: 0px
position: absolute
top: 50%
width: 100%
z-index: -100 !important
class: small
style:
animation: bound-in-small 0.6s ease forwards
background: "=props.colorCenter ? props.colorCenter : 'rgb(248, 249, 250)'"
border-radius: 50%
box-shadow: 0px 5px 10px 5px rgba(96, 93, 111,0.19)
height: "=props.size ? (Number(props.size)*0.375) +'px' : '57.6%'"
left: 50%
margin-top: 0px
position: absolute
text-align: center
top: 50%
width: "=props.size ? (Number(props.size)*0.375) +'px' : '57.6%'"
slots:
default:
class: heat
style:
font-size: "=props.fontSizeLocation ? props.fontSizeLocation : '1em'"
font-weight: 300
left: 50%
margin-top: 10%
slots:
default:
- component: Label
text: =props.location
params:
autoplay:
delay: 1500
disableOnInteraction: false
direction: vertical
mousewheel: true
slidesPerView: 1
scrollbar: false
style:
border-radius: 50%
height: 100%
left: 50%
position: absolute
top: 50%
width: 100%
slots:
default:
style:
display: "=props.humItem ? '' : 'none'"
slots:
default:
class: heat
style:
display: flex
font-size: "=props.fontSizeCenter ? props.fontSizeCenter : '2em'"
font-weight: 300
left: 50%
margin-top: 0
position: absolute
top: 50%
slots:
default:
- component: Label
text: =items[props.humItem].state
- component: Label
style:
font-size: "=props.fontSizeCenter ? 'calc(' + props.fontSizeCenter + ' * 0.2 )' : '0.6em'"
vertical-align: top
text: =items[props.humItem].displayState.split(' ')[1]
style:
display: "=props.currentPointItem ? '' : 'none'"
slots:
default:
class: heat
style:
display: flex
font-weight: 300
left: 50%
margin-top: 0
position: absolute
top: 50%
slots:
default:
- component: Label
text: =Number(items[props.currentPointItem].state).toFixed(1)
- component: Label
style:
vertical-align: top
text: "=props.unit ? props.unit : items[props.currentPointItem].displayState.split(' ')[1]"
- component: oh-image
style:
bottom: 5%
left: 50%
position: absolute
width: 40%
url: "=props.imgUrl ? props.imgUrl : 'https://community-openhab-org.s3-eu-central-1.amazonaws.com/original/2X/7/7d388a86c95471f89b1bb911d96d7609a3e3a059.svg'"
style:
display: "=props.chartSwitch ? '' : 'none'"
height: 100%
width: 100%
slots:
default:
class: page
style:
border-radius: 50%
height: 100%
left: 50%
margin-top: 0px
position: absolute
top: 50%
width: 100%
slots:
default:
- component: oh-chart
height: 100%
period: 12h
periodVisible: false
slots:
grid:
- component: oh-chart-grid
borderWidth: 0
height: 60%
left: 15%
right: 15%
show: true
top: 20%
series:
- component: oh-time-series
data:
gridIndex: 0
item: "=props.currentPointItem ? props.currentPointItem : ''"
lineStyle:
color: "=props.colorCurrentMarker ? props.colorCurrentMarker : 'rgb(33, 150, 243)'"
markPoint:
data:
- name: Höchsttemperatur
type: max
- name: Tiefsttemperatur
type: min
itemStyle:
name: Ist Temp. Indoor
smooth: true
type: line
xAxisIndex: 0
yAxisIndex: 0
gridIndex: 0
item: "=props.setPointItem ? props.setPointItem : ''"
lineStyle:
color: "=props.colorSetMarker ? props.colorSetMarker : 'rgb(230, 74, 25)'"
name: Soll Temp. Indoor
step: end
type: line
xAxisIndex: 0
yAxisIndex: 0
title:
- component: oh-chart-title
bottom: 10%
left: center
text: 12h
textStyle:
fontSize: 1em
fontWeight: normal
xAxis:
- component: oh-time-axis
axisLabel:
show: false
axisLine:
onZero: true
axisPointer:
label:
show: false
axisTick:
show: false
boundaryGap: false
gridIndex: 0
show: true
yAxis:
- component: oh-value-axis
axisLabel:
formatter: "{value} °C"
gridIndex: 0
max: auto
min: auto
nameGap: 45
nameLocation: center
show: false
style:
display: "=(props.extensionItem1 || props.extensionItem2)? '' : 'none'"
height: 100%
width: 100%
slots:
default:
class: page
style:
border-radius: 50%
height: 100%
left: 50%
margin-top: 0px
position: absolute
top: 50%
width: 100%
slots:
default:
- component: Label
style:
margin-bottom: 5%
margin-top: 5%
text-align: center
text: Extension Items
for: i
rangeStart: "=props.extensionItem1 ? Number(1) : (!props.extensionItem1 && props.extensionItem2) ? Number(2) : ''"
rangeStop: "=(props.extensionItem1 && props.extensionItem2) ? Number(2) : (props.extensionItem1 && !props.extensionItem2) ? Number(1) : Number(2)"
sourceType: range
slots:
default:
style:
align-items: center
display: flex
flex-flow: row wrap
justify-content: space-evenly
padding: 0 5% 0 5%
slots:
default:
color: '=(Number.parseInt(items[props["extensionItem" + loop.i]].state) > 75) ? "green" : (Number.parseInt(items[props["extensionItem" + loop.i]].state) > 25) ? "yellow" : "red"'
f7: '=props["extensionItem" + loop.i + "Icon"] ? ((Number.parseInt(items[props["extensionItem" + loop.i]].state) > 75) ? props["extensionItem" + loop.i + "Icon"].split(",")[0] : (Number.parseInt(items[props["extensionItem" + loop.i]].state) > 25) ? props["extensionItem" + loop.i + "Icon"].split(",")[1] : props["extensionItem" + loop.i + "Icon"].split(",")[2]) : "clear"'
style:
line-height: 2
min-width: 40px
- component: f7-badge
style:
font-size: 1em
line-height: 3
margin: 0 5px 0 5px
min-width: 30px
slots:
default:
- component: Label
text: =items[props["extensionItem" + loop.i]]
