Convert seconds to Hours:Minutes:Seconds in HabPanel?
Hi All
The following displays the duration of a movie, it displays the seconds fine but wont display in the correct format.
Clearly ive got something wrong in my code? Can someone please suggest a fix?
         <div class="music">
                <div class="cover" style="width:175px; height:175px; float:none; margin-left: auto"
                     ng-style="{'background-image': 'url(' + itemValue('myKodi_fanart') + ')'}"></div>
                <div class="playback" style="width:50%; float:none">
                    <div class="playbackTime">{{itemValue('myKodi_currenttime')}}
                    </div>
                    <div class="playbackBar">
                        <div class="playbackBarDone"
                             ng-style="{'width': itemValue('myKodi_currenttime')}"></div>
                    </div>
                    <div class="playbackTime">{{itemValue('myKodi_duration')}}
                    </div>
Thank you
What happens when you use the Angular timedate formatting? I’m not sure this will do the conversion you may need to add a filter to do the conversion.
Try something like this…
&lt;div class="playbackTime"&gt;{{itemValue('myKodi_duration')| date:'HH:mm:ss'}}
Reference information here…
https://docs.angularjs.org/api/ng/filter/date
No joy im afraid. I tried it before as the spotify widget used this.
I was afraid that might be the case. Take a look at the filter proposed here:
Good Luck.
Thanks, i can give that a go. Where would that JS code go?
app.filter('secondsToDateTime', function() {
    return function(seconds) {
        var d = new Date(0,0,0,0,0,0,0);
        d.setSeconds(seconds);
        return d;
<b>{{seconds | secondsToDateTime | date:'HH:mm:ss'}}</b>
Hi @dastrix80,
Have you managed to figure out where to put the function code?
I actually want to implement the same thing in my habpanel :slight_smile:
Yes, you need to write a custom java script.
Here is the script I had written, call this in your widget with this:
<div oc-lazy-load="['/static/time.js']">
(function () {
  'use strict';
  angular
    .module('app', [])
    .controller('ngclickCtrl', ['$scope', function ($scope) {
      $scope.clkcount = 0;
      $scope.getdetails = function (timeSec) {
        if(timeSec){
        console.log("i am here, got time - " + timeSec);
        // $scope.clkcount = cntr + 1;
        var date = new Date(null);
        var length = timeSec.length - 2;
        var seconds = +timeSec.substr(0,length);
        console.log("Time without Seconds suffix - " + seconds);
        date.setSeconds(seconds);
        var result = date.toISOString().substr(11, 8);
        console.log("Converted Time  - " + result);
        return result;
        } else
        return 0;
Perfect! With a few modifications I got it to work :slight_smile:
Thanks!
