piro
(Sven)
March 28, 2020, 1:26pm
1
I use iobroker and Habpanel instead of VIS from iobroker. I like the layout more because it is more fancy.
Today, I started to use the dummy widget with a datetime field (number = timestamp) with the format dd.MM.yyyy HH:mm:ss without success.
Result
What is the correct usage of format in the settings of the dummy widget.
Many thanks in advance.
Sven
This is an English only forum. There is a German language forum here.
German openHAB - KNX-User-Forum
piro
(Sven)
March 28, 2020, 2:17pm
3
Oh sorry, I will translate into english.
Sorry again.
piro
(Sven)
March 28, 2020, 7:58pm
4
Hi, I hope, one of you know the right setting.
piro
(Sven)
March 28, 2020, 9:57pm
5
What is correct syntax in the Format field to reach my goal to present the timestamp in a format “dd.MM.yyyy HH:mm:ss”?
Sven
ve7mkf
(Mike Fenske)
March 28, 2020, 10:35pm
6
Greetings Sven,
I have used the format “dd-MM-yyyy HH:mm:ss” to display sunrise/sunset on my Habpanel, but I did try it and it also works if you use “dd.MM.yyyy HH:mm:ss”
Regards,
Mike
piro
(Sven)
March 28, 2020, 10:46pm
7
Many thanks. Good to know. Maybe I have the issues because I use Habpanel with iobroker and then the format settings don’t work. Maybe, I’m not an expert on that.
Any other help will be great.
Many thanks.
Sven
rossko57
(Rossko57)
March 29, 2020, 1:23am
8
What is that Item you are trying to display? Doesn’t look like a valid Item name.
piro
(Sven)
March 29, 2020, 6:56am
9
It is a valid item. The value comes from openweathermap
I also tried an other date value.
For your information. In iobroker all datetime values are stored as a number based on the timestamp (milliseconds since 01.01.1970)
rossko57
(Rossko57)
March 29, 2020, 9:55am
10
It’s not an openHAB Item, names with . characters are not allowed. I’ve no idea what your screenshot is of, are those channels?
piro
(Sven)
March 29, 2020, 11:04am
11
I mentioned it in a prior post. I use iobroker instead of openHab. It is an iobroker item like you can see in the scrrenshot. iobroker give me the option to use Habpanel instead of the iobroker visualisation vis.
When I use a chart, the items are working well.
rossko57
(Rossko57)
March 29, 2020, 11:30am
12
Okay, you are using ioBroker.habpanel, not HABpanel.
Try
piro
(Sven)
March 29, 2020, 12:09pm
13
thx. I did it as well. I had the hope, someone knows it.
Many thanks for your time and help to understand it.
