Converting Rules DSL to JSRule (ecma2021) datatype problems
Hi guys…
actually I’m trying to convert my last Rules DSL rules to JSRules. but sometimes it get’s a little bit hard for me to sort out the problems…
this is one of the rules I’m trying to convert:
rule "TimeOfDay - Write DayStart Time and Set SleepState"
	System started or
	Item BedtimeStart changed or
	Item ManualOverride changed
	rescheduleTimer?.cancel
	rescheduleTimer = createTimer(now, [ |
		// get values from BedtimeStart for calculation
		val awake = (BedtimeStart.state as DateTimeType).getZonedDateTime().plusDays(1).minusHours(16).minusMinutes(15)
		val asleep = (BedtimeStart.state as DateTimeType).getZonedDateTime().plusMinutes(15)
		val squeezestop = (BedtimeStart.state as DateTimeType).getZonedDateTime().plusDays(1).minusHours(14).minusMinutes(15)
		val DateTimeType asp = new DateTimeType(asleep)
		val DateTimeType awk = new DateTimeType(awake)
		val DateTimeType sqstp = new DateTimeType(squeezestop)
		val bedtime = Bedtime.state
		// send values to Items
		MyDayStart.postUpdate(awk)
		MySleepStart.postUpdate(asp)
		SqueezeStop.postUpdate(sqstp)
		// Calculate the SleepState
		switch true {
			case 	now.isAfter(awake) && bedtime == OFF						 : curr2 =	"AWAKE"
			case	now.isAfter(asleep) && now.isBefore(awake) && bedtime == OFF : curr2 =	"AWAKE"
			case 	now.isAfter(asleep) && now.isBefore(awake) && bedtime == ON  : curr2 =	"ASLEEP"
		if ( SleepState.state.toString != curr2 ) {
			SleepState.sendCommand(curr2)
			logInfo("DayStart", "SleepState = "+curr2)
	rescheduleTimer.reschedule(now.plusMinutes(5))
my main problem is that I can’t figure out how to work with zonedDateTime in java.
this is my approach to convert to JSRule:
const {log, rules, triggers, time} = require("openhab");
rules.JSRule({
  name: "ECMA2021Script - Sleep State",
  description: "toggle sleep state when bedtime/daystart changes",
  triggers: [
    triggers.SystemStartlevelTrigger(100),
    triggers.ItemStateChangeTrigger('BedtimeStart'),
    triggers.ItemStateChangeTrigger('ManualOverride')
  execute: data => {
    const sleepstate = items.getItem("SleepState");
    const bedtimestart = items.getItem("BedtimeStart");
    const mydaystart = items.getItem("MyDayStart");
    const mysleepstart = items.getItem("MySleepStart");
    const squeezestop = items.getItem("SqueezeStop");
    const bedtime = items.getItem("Bedtime");
    const bedtimeStartTime = time.ZonedDateTime.of(
      bedtimestart.year,
      bedtimestart.month,
      bedtimestart.day,
      bedtimestart.hour,
      bedtimestart.minute,
      bedtimestart.second,
      bedtimestart.nano,
      bedtimestart.zone
    // Create ZonedDateTime objects from the number of milliseconds
    var awake = bedtimeStartTime.plus(time.Duration.ofDays(1)).minus(time.Duration.ofHours(16)).minus(time.Duration.ofMinutes(15));
    var asleep = bedtimeStartTime.plus(time.Duration.ofMinutes(15));
    var sqzstop = bedtimeStartTime.plus(time.Duration.ofDays(1)).minus(time.Duration.ofHours(14)).minus(time.Duration.ofMinutes(15));
    var now = time.ZonedDateTime.now();
    var curr = "UNKNOWN";
    mydaystart.postUpdate(awake);
    mysleepstart.postUpdate(asleep);
    squeezestop.postUpdate(sqzstop);
    if ( now.isAfter(awake) && bedtime.state === "OFF" ) {
      curr = "AWAKE";
      console.log("SleepState ",curr);
    if (now.isAfter(asleep) && now.isBefore(awake) && bedtime.state === "OFF") {
      curr = "AWAKE";
      console.log("SleepState ", curr);
    if (now.isAfter(asleep) && now.isBefore(awake) && bedtime.state === "ON") {
      curr = "ASLEEP";
    if (sleepstate.state !== curr) {
      sleepstate.sendCommand(curr);
    // Reschedule timer to run every 5 minutes
    setTimeout((data) => rules.JSRule(data), 300000, data);
  tags: [],
I tried to figure out what’s the problem and it seems like I’m having problems telling java to work corectly
with my string items (e.g. bedtimestart) that hold the DateTime data.
this is the error I get from the logs when manually firing the rule via UI:
2022-12-29 09:37:22.490 [ERROR] [tion.script.file.rules_sleepstate.js] - Failed to execute rule ECMA2021Script---Sleep-State-f2bd3f2b-a45f-4f0e-977e-0de2498f6d96: NullPointerException: year must not be null: NullPointerException: year must not be null
        at JsJodaException (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:76)
        at requireNonNull (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:298)
        at LocalDate (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:11303)
        at of (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:12008)
        at ofNumbers (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:12766)
        at of (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:12756)
        at of8 (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:10516)
        at of (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:10500)
        at execute (rules_sleepstate.js:18)
seems like the conversion approach is completely wrong, but I’m a little bit lost, because the more I read about ZDT in java, the more I get confused.
I also tried to replace this definition
      bedtimestart.year,
      bedtimestart.month,
      bedtimestart.day,
      bedtimestart.hour,
      bedtimestart.nano,
      bedtimestart.zone
with
const bedtimeStartTime = time.ZonedDateTime.parse(bedtimestart.state);
but then I get the following error:
2022-12-29 09:48:44.769 [ERROR] [tion.script.file.rules_sleepstate.js] - Failed to execute rule ECMA2021Script---Sleep-State-1ab88ac8-aa36-410c-a92a-32999c0412a2: DateTimeParseException: Text '2022-12-29T01:12:41.206118+0100' could not be parsed at index 26: 2022-12-29T01:12:41.206118+0100, at index: 26: DateTimeParseException: Text '2022-12-29T01:12:41.206118+0100' could not be parsed at index 26: 2022-12-29T01:12:41.206118+0100, at index: 26
        at _parseToBuilder (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:7742)
        at parse2 (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:7701)
        at parse (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:7676)
        at parse (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:10658)
        at doExecute (webpack://openhab/./node_modules/openhab/rules/rules.js?:242)
my skills in datatype conversions are very limited I think :wink:
maybe someone can help me understand more what to look out for in plain words?
thanks!
The openhab-js library goes to great lengths to make sure you only ever have to mess with JavaScript classes and objects most of the time. Date times are no exception. The relevant docs are JavaScript Scripting - Automation | openHAB
To achieve this goal, the openhab-js library makes available the joda-js library (a reference to the docs for that are linked to in the docs linked above) which works almost exactly like the Java date time classes. So definitely look at the examples and the reference docs there.
OK, with that out of the way, what does that error mean? It’s saying that bedtimestart.year is null/undefined. So let’s focus on that variable.
You’ve initialized bedtimestart to items.getItem("BedtimeStart"). Looking at the reference docs for items we see that getItem(String) returns an Item Object. An Item doesn’t have a .year, .month, and all the rest because an Item isn’t a ZonedDateTime.
You need to get the state of the Item, same as you do in Rules DSL. However, looking at the reference docs we see that Item.state returns a String, not a DateTimeType. That’s because DateTimeType is a Java Class but a String is JavaScript and there is no JavaScript equivalent to the Item state classes. But you will also see Item has a rawState. This is the original DateTimeType Java Object for that DateTime Item.
Once you have the DateTimeType, the code is basically the same as Rules DSL. Call getZonedDateTime to get the ZonedDateTime Object.
Given all of this, your line to create bedtimeStartTime becomes
const bedtimeStartTime = bedtimestart.rawState.getZonedDateTime();
That’s it. It’s already a ZonedDateTime so you don’t need to create a new one. Just use what you already have. I believe that the add-on will auto-convert to/from the Java ZonedDateTime to the joda-js ZonedDateTime but if not, use toZDT() which will convert it for you.
const bedtimeStartTime = time.toZDT(bedtimestart.rawState.getZonedDateTime());
That should fix this particular error.
Some other other observations:
  • Why use a timer to run every five minutes instead of a cron trigger?
  • Why use a polling rule in the first place? You can use a Time is <item> trigger to trigger a rule based on the state of a DateTime Item. It would be way simpler to break this up into a rule that recalculates the DateTimes when BedtimeStart changes and then create a simple rule for each state that triggers based on the states of the DateTimeItems. It would look something like (note there are some utilities in time that make the calculations easier too):
rules.JSRule({
  name: "ECMA2021Script - Calculate times based on BedtimeStart",
  description: "Updates time of day Items based on BedtimeStart",
  triggers: [
    triggers.SystemStartlevelTrigger(100), // This isn't needed if BedtimeStart and the other Items have restoreOnStartup
  execute: data => {
    var bedtimeStartTime = items.getItem('BedtimeStart').rawState.getZonedDateTime();
    var awake = bedtimeStartTime.plus(time.Duration.parse('P1D').minus(time.Duration('PT16H15M'));
    var sqzstop = bedtimeStartTime.plus(time.Duration.ofDays(1)).minus(time.Duration.parse('PT14H15M'));
    items.getItem('MyDayStart`).postUpdate(awake.toLocalDateTime().toString()); // there was a problem with posting an update from a Joda ZonedDateTime, this is guaranteed to work
    items.getItem('MySleepStart').postUpdate(asleep.toLocalDateTime().toString());
    items.getItem(`SqueezeStop`).postUpdate(sqzstop.toLocalDateTime().toString());
  tags: [],
rules.JSRule({
  name: "ECMA2021Script - Awake Time",
  description: "Updates sleep state to AWAKE",
  triggers: [
    triggers.DateTimeTrigger('MyDayStart')
  execute: data => {
    items.getItem("SleepState").sendCommand("AWAKE");
  tags: [],
rules.JSRule({
  name: "ECMA2021Script - ASLEEP",
  description: "Updates sleep state to ASLEEP",
  triggers: [
    triggers.DateTimeTrigger('MySleepStart'),
    triggers.ItemStateChangedTrigger('Bedtime')
  execute: data => {
    const bedtime = items.getItem('Bedtime').state
    const sleepStart = items.getItem('MySleepStart').rawState.getZonedDateTime();
    const sleepState = (bedtime == "ON" && time.toZDT().isAfter(sleepStart)) ? "ASLEEP" : "AWAKE";
    items.getItem("SleepState").sendCommand(sleepState);
    console.log("SleepState ", sleepState);
  tags: [],
No timers. No complex conditions or conversions.
thanks for that I think I have to read it again… it was very confusing I didn’t understand all this java time & joda js stuff at my first look :wink:
yes this was my fourth approach I changed and tried so much to get it running without help… as I mentioned I guessed that this approach was totally wrong.
thanks I worked with rawState before in other cases, but wasn’t aware that it makes a difference in that case - but now it makes sense that my approach with state wouldn’t have worked, because of the wrong datatype. Sometimes it’s a bit overwhelming to keep everything in mind if you’re just a hobby-coder :wink:
whoooh… I have to think about that… actually my approach was to convert my rules without the focus on improvements but I definately have a look at your suggestion to split this up.
thanks for this very good explanation where my problem / misunderstanding was based on. I honestly appreciate your help, thanks a ton!! :slight_smile:
I’ll try your tips and give an update after I tested them…
while leaving everything else untouched I get these errors
2022-12-29 22:54:17.664 [ERROR] [tion.script.file.rules_sleepstate.js] - Failed to execute rule ECMA2021Script---Sleep-State-43d309cb-eb2e-48fc-bbd7-44b47c27250a: java.lang.UnsupportedOperationException: Unsupported operation identifier 'toFullString' and  object '[object Object]'(language: JavaScript, type: ZonedDateTime). Identifier is not executable or instantiable.
2022-12-29 22:54:17.665 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'ECMA2021Script---Sleep-State-43d309cb-eb2e-48fc-bbd7-44b47c27250a': Fail to execute action: 1
seems like toZDT is not working in this case and produces another datatype error?!?
2022-12-29 22:58:59.354 [ERROR] [tion.script.file.rules_sleepstate.js] - Failed to execute rule ECMA2021Script---Sleep-State-36266e38-68a4-404e-9d2b-530e4baf4ee6: RangeError: Maximum call stack size exceeded: RangeError: Maximum call stack size exceeded
        at addTo (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:1317)
        at addTo (webpack://openhab/./node_modules/@js-joda/core/dist/js-joda.esm.js?:1318)
2022-12-29 22:58:59.356 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'ECMA2021Script---Sleep-State-36266e38-68a4-404e-9d2b-530e4baf4ee6': Fail to execute action: 1
an this seems to be a joda-js conversion problem?? I’m sorry just guessing :wink:
What version of OH are you running?
Have you ever installed openhab-js by hand or are you using the version that comes with the add-on?
That’s something different. It may not even have anything to do with this code itself. You’d usually see this kind of error if you have a recursion run amok. That should be possible here, we don’t have a recursion.
Try restarting OH to get a clean slate and try it again.
If the problem persists, add logging to narrow it down to which line it’s failing on.
just updated to 3.4.0.1 stable (debian)
I have some old jsr223 (jython) stuff installed… but the js addon is installed via UI
Ok we’ll see… thanks!
after restarting and firing the rule via ManualOverride item change, at the first time the log is going nuts:
2022-12-29 23:24:57.854 [ERROR] [Events.Framework                    ] - FrameworkEvent ERROR
java.lang.StackOverflowError: null
        at org.objectweb.asm.SymbolTable.addConstantUtf8(SymbolTable.java:774) ~[?:?]
        at org.objectweb.asm.MethodWriter.<init>(MethodWriter.java:598) ~[?:?]
        at org.objectweb.asm.ClassWriter.visitMethod(ClassWriter.java:446) ~[?:?]
        at org.objectweb.asm.ClassVisitor.visitMethod(ClassVisitor.java:366) ~[?:?]
        at org.apache.aries.spifly.weaver.TCCLSetterVisitor.visitMethod(TCCLSetterVisitor.java:79) ~[?:?]
        at org.objectweb.asm.ClassReader.readMethod(ClassReader.java:1353) ~[?:?]
        at org.objectweb.asm.ClassReader.accept(ClassReader.java:744) ~[?:?]
        at org.objectweb.asm.ClassReader.accept(ClassReader.java:424) ~[?:?]
        at org.apache.aries.spifly.dynamic.ClientWeavingHook.weave(ClientWeavingHook.java:60) ~[?:?]
        at org.eclipse.osgi.internal.weaving.WovenClassImpl.call(WovenClassImpl.java:187) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.weaving.WovenClassImpl.call(WovenClassImpl.java:1) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.notifyHookPrivileged(ServiceRegistry.java:1332) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.notifyHooksPrivileged(ServiceRegistry.java:1305) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.weaving.WovenClassImpl.callHooks(WovenClassImpl.java:249) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.weaving.WeavingHookConfigurator.processClass(WeavingHookConfigurator.java:80) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.processClass(ClasspathManager.java:735) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:706) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:639) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:607) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:587) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:566) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:335) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:397) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass0(BundleLoader.java:488) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:416) ~[org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:168) ~[org.eclipse.osgi-3.17.200.jar:?]
        at java.lang.ClassLoader.loadClass(ClassLoader.java:522) ~[?:?]
        at com.oracle.truffle.polyglot.PolyglotImpl.guestToHostException(PolyglotImpl.java:642) ~[?:?]
        at com.oracle.truffle.polyglot.HostToGuestRootNode.handleException(HostToGuestRootNode.java:147) ~[?:?]
        at com.oracle.truffle.polyglot.HostToGuestRootNode.execute(HostToGuestRootNode.java:129) ~[?:?]
        at com.oracle.truffle.api.impl.DefaultCallTarget.callDirectOrIndirect(DefaultCallTarget.java:85) ~[?:?]
        at com.oracle.truffle.api.impl.DefaultCallTarget.call(DefaultCallTarget.java:102) ~[?:?]
        at com.oracle.truffle.polyglot.PolyglotObjectProxyHandler.invoke(PolyglotObjectProxyHandler.java:103) ~[?:?]
        at com.sun.proxy.$Proxy2504.addTo(Unknown Source) ~[?:?]
        at java.time.ZonedDateTime.plus(ZonedDateTime.java:1608) ~[?:?]
        at com.oracle.truffle.host.HostMethodDesc$SingleMethod$MHBase.invokeHandle(HostMethodDesc.java:331) ~[?:?]
        at com.oracle.truffle.host.GuestToHostCodeCache$1.executeImpl(GuestToHostCodeCache.java:96) ~[?:?]
        at com.oracle.truffle.host.GuestToHostRootNode.execute(GuestToHostRootNode.java:80) ~[?:?]
        at com.oracle.truffle.api.impl.DefaultRuntimeAccessor$DefaultRuntimeSupport.callInlined(DefaultRuntimeAccessor.java:160) ~[?:?]
        at com.oracle.truffle.host.GuestToHostRootNode.guestToHostCall(GuestToHostRootNode.java:102) ~[?:?]
        at com.oracle.truffle.host.HostMethodDesc$SingleMethod$MHBase.invokeGuestToHost(HostMethodDesc.java:362) ~[?:?]
        at com.oracle.truffle.host.HostExecuteNode.doInvoke(HostExecuteNode.java:871) ~[?:?]
        at com.oracle.truffle.host.HostExecuteNode.doOverloadedCached(HostExecuteNode.java:288) ~[?:?]
        at com.oracle.truffle.host.HostExecuteNodeGen.execute(HostExecuteNodeGen.java:85) ~[?:?]
        at com.oracle.truffle.host.HostObject.invokeMember(HostObject.java:451) ~[?:?]
        at com.oracle.truffle.host.HostObjectGen$InteropLibraryExports$Cached.invokeMember(HostObjectGen.java:2674) ~[?:?]
        at com.oracle.truffle.api.interop.InteropLibraryGen$CachedDispatch.invokeMember(InteropLibraryGen.java:8134) ~[?:?]
        at com.oracle.truffle.js.nodes.function.JSFunctionCallNode$ForeignInvokeNode.executeCall(JSFunctionCallNode.java:1496) ~[?:?]
        at com.oracle.truffle.js.nodes.function.JSFunctionCallNode.executeCall(JSFunctionCallNode.java:244) ~[?:?]
        at com.oracle.truffle.js.nodes.function.JSFunctionCallNode$InvokeNode.execute(JSFunctionCallNode.java:732) ~[?:?]
        at com.oracle.truffle.js.nodes.control.ReturnNode$TerminalPositionReturnNode.execute(ReturnNode.java:165) ~[?:?]
        at com.oracle.truffle.js.nodes.control.AbstractBlockNode.executeGeneric(AbstractBlockNode.java:85) ~[?:?]
        at com.oracle.truffle.js.nodes.control.AbstractBlockNode.executeGeneric(AbstractBlockNode.java:55) ~[?:?]
        at com.oracle.truffle.api.impl.DefaultBlockNode.executeGeneric(DefaultBlockNode.java:65) ~[?:?]
        at com.oracle.truffle.js.nodes.control.AbstractBlockNode.execute(AbstractBlockNode.java:75) ~[?:?]
        at com.oracle.truffle.js.nodes.function.FunctionBodyNode.execute(FunctionBodyNode.java:73) ~[?:?]
        at com.oracle.truffle.js.nodes.function.FunctionRootNode.executeInRealm(FunctionRootNode.java:143) ~[?:?]
        at com.oracle.truffle.js.runtime.JavaScriptRealmBoundaryRootNode.execute(JavaScriptRealmBoundaryRootNode.java:92) ~[?:?]
        at com.oracle.truffle.api.impl.DefaultDirectCallNode.call(DefaultDirectCallNode.java:59) ~[?:?]
        at com.oracle.truffle.js.nodes.function.JSFunctionCallNode$UnboundJSFunctionCacheNode.executeCall(JSFunctionCallNode.java:1277) ~[?:?]
        at com.oracle.truffle.js.nodes.interop.JSInteropInvokeNode.doCached(JSInteropInvokeNode.java:80) ~[?:?]
        at com.oracle.truffle.js.nodes.interop.JSInteropInvokeNodeGen.execute(JSInteropInvokeNodeGen.java:46) ~[?:?]
        at com.oracle.truffle.js.runtime.objects.JSObject.invokeMember(JSObject.java:241) ~[?:?]
        at com.oracle.truffle.js.runtime.objects.JSObjectGen$InteropLibraryExports$Cached.invokeMember(JSObjectGen.java:400) ~[?:?]
        at com.oracle.truffle.polyglot.PolyglotObjectProxyHandler$ProxyInvokeNode.invokeOrExecute(PolyglotObjectProxyHandler.java:231) ~[?:?]
        at com.oracle.truffle.polyglot.PolyglotObjectProxyHandler$ProxyInvokeNode.doCachedMethod(PolyglotObjectProxyHandler.java:206) ~[?:?]
        at com.oracle.truffle.polyglot.PolyglotObjectProxyHandlerFactory$ProxyInvokeNodeGen.execute(PolyglotObjectProxyHandlerFactory.java:49) ~[?:?]
        at com.oracle.truffle.polyglot.PolyglotObjectProxyHandler$ObjectProxyNode.executeImpl(PolyglotObjectProxyHandler.java:148) ~[?:?]
        at com.oracle.truffle.polyglot.HostToGuestRootNode.execute(HostToGuestRootNode.java:125) ~[?:?]
but only the first time, after repeating this the log shows the errors mentioned before:
2022-12-29 23:28:28.338 [ERROR] [tion.script.file.rules_sleepstate.js] - Failed to execute rule ECMA2021Script---Sleep-State-cde6d6df-5c2f-4e68-a890-35f6def76db2: java.lang.StackOverflowError
2022-12-29 23:28:28.340 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'ECMA2021Script---Sleep-State-cde6d6df-5c2f-4e68-a890-35f6def76db2': Fail to execute action: 1
2022-12-29 23:28:29.976 [ERROR] [tion.script.file.rules_sleepstate.js] - Failed to execute rule ECMA2021Script---Sleep-State-cde6d6df-5c2f-4e68-a890-35f6def76db2: RangeError: Maximum call stack size exceeded: RangeError: Maximum call stack size exceeded
2022-12-29 23:28:29.978 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'ECMA2021Script---Sleep-State-cde6d6df-5c2f-4e68-a890-35f6def76db2': Fail to execute action: 1
I’ll go to bed now… and have a look tomorrow :sleeping:
The very latestes, yet unpublished version of the openhab-js library should be able to parse these strings:
time.toZDT("2022-12-29T01:12:41.206118+0100");
I‘ll try to publish a new version soon, so that you can install it by running npm i openhab inside the $OPENHAB_CONF/automation/js folder.
@rlkoshak Does this problem persist?
thanks good to know… :wink: would be nice to get a notice when you published it finally…
ok thanks! I’ll wait for the update and install it…
Seems this would also make me able to simplify this monster I created a few days ago because of same problem IIRC:
items.getItem("DanfossHRV_Main_Boost_LastActivated").postUpdate(time.toZDT().toLocalDateTime().toString());
I am not sure if that’s the same …
The toZDT method creates a ZonedDateTime from many different formats, but it returns a JS Joda ZonedDateTime. If the postUpdate doesn’t accept this, it’s a different problem.
Does time.toZDT().toString() not work inside postUpdate?
@laursen I see the problem, I’ll fix it and then release a new version soon.
Yeah, that suggestion produces:
State '2022-12-30T14:33:57.522+01:00[SYSTEM]' cannot be parsed for item 'DanfossHRV_Main_Boost_LastActivated'.
Initially I was optimistic enough to try:
items.getItem("DanfossHRV_Main_Boost_LastActivated").postUpdate(time.toZDT());
which gave the result I remembered:
Can you please retry with adding replace(/\[[^\]]*\]$/, '') to the ZonedDateTime string?
That works.
This is because openHAB core does not accept a ZonedDateTime for state updates and commands – GraalJS translates the JS-Joda ZonedDateTime to the Java counterpart (and that translation works; if not createTimer wouldn’t work).
So we either add the ability to accept a java.time.ZonedDateTime for postUpdate and sendCommand inside core, or I fix it in the library. I’ll fix it in the library, but maybe one can add this to core. See BusEvent (openHAB Core 4.0.0-SNAPSHOT API).
@laursen @Dan @rlkoshak
I have just released a new version with many bugfixes, see the changelog: openhab-js/CHANGELOG.md at main · openhab/openhab-js · GitHub
You can install it with npm i openhab.
thanks a lot…
What would be the simplest way possible now? This:
items.getItem("DanfossHRV_Main_Boost_LastActivated").postUpdate(time.toZDT().toString());
Still results in:
State '2022-12-30T16:29:15.516+01:00[SYSTEM]' cannot be parsed for item 'DanfossHRV_Main_Boost_LastActivated'.
Without the toString():
I have updated the JSDoc and type definitions, that it also accepts a time.ZonedDateTime
const bedtimeStartTime = time.toZDT(bedtimestart.rawState);
is working now thanks a ton :wink: I’ll have a look at the updated docs which changes you made in general…
