I’m trying to implement my first MQTT HomeAssistant Thing and have run into some issues.
I’m already using MQTT for other things, so the broker is setup and working.
I’ve created this mmWave sensor and it’s successfully pushing data to MQTT, both config and data topics.
The topics I can see for config are as follows:
- homeassistant/binary_sensor/mmwave-esp8266/mmwave_sensor/config
- homeassistant/button/mmwave-esp8266/factory_reset_mmwmcu_mmwave-esp8266/config
- homeassistant/button/mmwave-esp8266/restart_esp_mmwave-esp8266/config
- homeassistant/number/mmwave-esp8266/distance/config
- homeassistant/number/mmwave-esp8266/latency/config
- homeassistant/number/mmwave-esp8266/sensitivity/config
- homeassistant/switch/mmwave-esp8266/led/config
- homeassistant/switch/mmwave-esp8266/mmwave_sensor/config
- homeassistant/switch/mmwave-esp8266/use_safe_mode/config
These appear correct to me and the reading of the spec I did.
But I get a bunch of auto-discovery errors:
2023-02-12 17:28:38.490 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channel 'ESPswitchmmwave_5Fsensor#switch', because channel type 'mqtt:ESPswitchmmwave_5Fsensor_switch' could not be found.
2023-02-12 17:28:38.491 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channel 'ESPbinary_5Fsensormmwave_5Fsensor#sensor', because channel type 'mqtt:ESPbinary_5Fsensormmwave_5Fsensor_sensor' could not be found.
2023-02-12 17:28:38.492 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channel 'ESPswitchled#switch', because channel type 'mqtt:ESPswitchled_switch' could not be found.
2023-02-12 17:28:38.492 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channel 'ESPswitchuse_5Fsafe_5Fmode#switch', because channel type 'mqtt:ESPswitchuse_5Fsafe_5Fmode_switch' could not be found.
2023-02-12 17:28:38.492 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channels for channel group 'ESPswitchmmwave_5Fsensor' for thing type 'mqtt:homeassistant_c45bbe60df53:4d0a5b9184:c45bbe60df53', because channel group type 'mqtt:ESPswitchmmwave_5Fsensor' could not be found.
2023-02-12 17:28:38.492 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channels for channel group 'ESPbinary_5Fsensormmwave_5Fsensor' for thing type 'mqtt:homeassistant_c45bbe60df53:4d0a5b9184:c45bbe60df53', because channel group type 'mqtt:ESPbinary_5Fsensormmwave_5Fsensor' could not be found.
2023-02-12 17:28:38.493 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channels for channel group 'ESPswitchled' for thing type 'mqtt:homeassistant_c45bbe60df53:4d0a5b9184:c45bbe60df53', because channel group type 'mqtt:ESPswitchled' could not be found.
2023-02-12 17:28:38.493 [WARN ] [re.thing.internal.ThingFactoryHelper] - Could not create channels for channel group 'ESPswitchuse_5Fsafe_5Fmode' for thing type 'mqtt:homeassistant_c45bbe60df53:4d0a5b9184:c45bbe60df53', because channel group type 'mqtt:ESPswitchuse_5Fsafe_5Fmode' could not be found.
2023-02-12 17:28:38.504 [WARN ] [ssistant.internal.DiscoverComponents] - HomeAssistant discover error: thing factory_reset_mmwmcu_mmwave-esp8266 component type is unsupported: button
2023-02-12 17:28:38.506 [WARN ] [ssistant.internal.DiscoverComponents] - HomeAssistant discover error: thing sensitivity component type is unsupported: number
2023-02-12 17:28:38.507 [WARN ] [ssistant.internal.DiscoverComponents] - HomeAssistant discover error: thing restart_esp_mmwave-esp8266 component type is unsupported: button
2023-02-12 17:28:38.508 [WARN ] [ssistant.internal.DiscoverComponents] - HomeAssistant discover error: thing distance component type is unsupported: number
2023-02-12 17:28:38.508 [WARN ] [ssistant.internal.DiscoverComponents] - HomeAssistant discover error: thing latency component type is unsupported: number
and I don’t have Channels in the thing for Distance / Latency or Sensitivity (which would be nice).
Some discover message content for:
{“dev_cla”:“motion”,“name”:“mmWave Sensor”,“stat_t”:“mmwave-esp8266/binary_sensor/mmwave_sensor/state”,“avty_t”:“mmwave-esp8266/status”,“uniq_id”:“ESPbinary_sensormmwave_sensor”,“dev”:{“ids”:“c45bbe60df53”,“name”:“mmwave-esp8266”,“sw”:“esphome v2022.12.8 Feb 12 2023, 16:48:54”,“mdl”:“d1_mini”,“mf”:“espressif”}}
{“min”:0.15,“max”:9.45,“step”:0.15,“unit_of_meas”:“M”,“mode”:“box”,“name”:“distance”,“entity_category”:“config”,“stat_t”:“mmwave-esp8266/number/distance/state”,“cmd_t”:“mmwave-esp8266/number/distance/command”,“avty_t”:“mmwave-esp8266/status”,“uniq_id”:“ESPnumberdistance”,“dev”:{“ids”:“c45bbe60df53”,“name”:“mmwave-esp8266”,“sw”:“esphome v2022.12.8 Feb 12 2023, 16:48:54”,“mdl”:“d1_mini”,“mf”:“espressif”}}
I have the required transformation bindings installed. I’m not sure where to go from here, can anyone point me in the right direction?
