Hi again,
here is something very strange to me …
Look at the code
var int dayLightValueMin = 12000
var int dayTimeTimeout = 10
var int nightTimeTimeout = 60
val org.eclipse.xtext.xbase.lib.Functions$Function4 calculateTimeOut = [
int p_lightValue,
int p_dayLightvalueMin,
int p_dayTimeTimeout,
int p_nightTimeTimeout
logInfo("Powersaving", "NEW LIGHTSAVING calc "+p_lightValue+","+p_dayLightvalueMin+","+p_dayTimeTimeout+","+p_nightTimeTimeout)
if(p_lightValue < p_dayLightvalueMin)
p_dayTimeTimeout
else
p_nightTimeTimeout
Here is the triggering rule
rule "Light Timeout switchlight_erdgeschosseg_toilettedeckenlampe"
Item switchlight_erdgeschosseg_toilettedeckenlampe changed
logInfo("Powersaving", "NEW LIGHTSAVING START")
var lightValue = illumination_sensor_aussendachmastlicht.state
logInfo("Powersaving", "NEW LIGHTSAVING LV "+lightValue)
val int timeoutValue = calculateTimeOut.apply(lightValue, dayLightValueMin, dayTimeTimeout, nightTimeTimeout) as Integer
logInfo("Powersaving", "NEW LIGHTSAVING DEBUG ITEM("+switchlight_erdgeschosseg_toilettedeckenlampe+")")
logInfo("Powersaving", "NEW LIGHTSAVING DEBUG TIMEOUT("+timeoutValue+")")
lightTimers.apply(timerTable,switchlight_erdgeschosseg_toilettedeckenlampe, timeoutValue)
In the calculateTimeOut Lambda i get an
[ERROR] [.script.engine.ScriptExecutionThread] - Rule 'Light Timeout switchlight_erdgeschosseg_toilettedeckenlampe': Could not invoke method: org.eclipse.xtext.xbase.lib.IntegerExtensions.operator_lessThan(int,int) on instance: null
But the debug msg says, all variable are set and have values:
NEW LIGHTSAVING calc 100,12000,10,60
When I remove the comparission it works fine …
How is this possible ?
