Am seeing this issue when I’m adding a Fibaro Single Switch 2 via HABMin:
13:43:27.838 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 010F:0403:3000::3.2
However this device does exist in the database, it’s this.
It looks like the suffix is different? 1000 vs 3000? Potential firmware update or maybe it’s because it’s the AU/NZ version? Can I manually copy the 0403:1000 config to 0403:3000 to test my theory?
edit Assuming the database gets compiled into the jar? This looks like the line I need to adjust.
Versions:
bundle:list -s | grep openhab
166 | Active | 90 | 2.0.0 | openHAB Core | org.openhab.core
167 | Active | 80 | 2.0.0 | openHAB Karaf Integration | org.openhab.core.karaf
169 | Resolved | 80 | 2.0.0 | openHAB Sound Support, Hosts: 111 | org.openhab.io.sound
170 | Active | 80 | 2.0.0 | openHAB Dashboard UI | org.openhab.ui.dashboard
176 | Active | 80 | 2.0.0 | openHAB 1.x Compatibility Layer | org.openhab.core.compat1x
200 | Active | 80 | 2.0.0 | openHAB REST Documentation | org.openhab.io.rest.docs
201 | Resolved | 80 | 2.0.0 | openHAB Basic UI Fragment, Hosts: 197 | org.openhab.ui.basicui
202 | Active | 80 | 2.0.0 | openHAB Classic UI Fragment | org.openhab.ui.classicui
203 | Active | 80 | 2.0.0 | HABmin User Interface | org.openhab.ui.habmin
204 | Active | 80 | 2.0.0 | HABPanel User Interface | org.openhab.ui.habpanel
205 | Resolved | 80 | 2.0.0 | openHAB Paper UI Theme Fragment, Hosts: 199 | org.openhab.ui.paperui
209 | Active | 80 | 1.9.0.201701200211 | openHAB Piface Binding | org.openhab.binding.piface
210 | Active | 80 | 1.9.0 | openHAB Mail Action | org.openhab.action.mail
211 | Active | 80 | 1.9.0 | openHAB Twitter Action | org.openhab.action.twitter
213 | Active | 80 | 2.0.0 | ZWave Binding | org.openhab.binding.zwave
214 | Active | 80 | 1.9.0 | openHAB Serial Binding | org.openhab.binding.serial
215 | Active | 80 | 1.9.0 | openHAB MQTT Binding | org.openhab.binding.mqtt
216 | Active | 80 | 1.9.0 | openHAB MQTT Transport Bundle | org.openhab.io.transport.mqtt
217 | Active | 80 | 1.9.0 | openHAB RRD4j Persistence Bundle | org.openhab.persistence.rrd4j
218 | Active | 80 | 1.9.0 | openHAB InfluxDB Persistence bundle | org.openhab.persistence.influxdb
219 | Active | 80 | 2.0.0 | Network Binding | org.openhab.binding.network
