Count and show Time since Washing machine is running
I have a plug at my washing machine to show, that the machine is running.
This icon is normally green, when the machine works, it is red.
Now I want to show the time in habpanel, since the machine is running in the format HH:mm.
When the icon becomes green, the counter should show 00:00.
I tried to find a solution, but without success.
I hope you can help?!
This is going to take some Rules and some Math.
  • I’d write a Rule that triggers when the Switch turns ON.
  • Create a Number Item to store the Number of minutes and reset this Item to 0 when the Rule triggers.
  • Create a Design Pattern: Looping Timers that runs every minute and adds one to the Number Item.
  • Create a JS transformation that converts the number of minutes to HH:MM format to be used in the Item’s label.
  • When the Switch turns OFF, cancel the looping timer.
thank you very much.
I am a newbie, can you please explain it a little bit more?
In the Rule
MyNumberItem.postUpdate(0)
where MyNumberItem is the name of the Number Item you created.
Read the design pattern and come back with specific questions.
See the design pattern
