I created groups for every of my HUE lamps to combine all settings.
In the end I want to count all active lamps in each room and all together.
And here ist the problem for the HUE-groups each setting is counted, specially the colortemperature,
if I switch a HUE-lamp off the colortemperature stays the same and makes the lamp still being count.
Is there a nice way to avoid that and still keep the group?
Group:Switch:OR(ON, OFF) gLampen "Beleuchtung [(%d)]" <light> (ALL)
Group:Switch:OR(ON, OFF) gLampenSZ "Lampen SZ [(%d)]" <light> (gLampen, gSchlafzimmer)
Group:Switch:OR(ON, OFF) gLampenBad "Lampen Bad [(%d)]" <light> (gLampen, gBad)
Group:Switch:OR(ON, OFF) gLampenAZ "Lampen AZ [(%d)]" <light> (gLampen, gArbeitszimmer)
Group:Switch:OR(ON, OFF) gLampenWZ "Lampen WZ [(%d)]" <light> (gLampen, gWohnzimmer)
Group:Switch:OR(ON, OFF) gLampenK "Lampen Küche [(%d)]" <light> (gLampen, gKueche)
Group:Switch:OR(ON, OFF) gLampenFlur "Lampen Flur [(%d)]" <light> (gLampen, gFlur)
// Schlafzimmer
Switch DeckenlampeSZ "Deckenlampe SZ" <light> ( gLampenSZ ) [ "Lighting" ] { channel="homematic:HM-LC-Sw2-FM:x:KEQ1073512:1#STATE" }
Switch Ankleidelampe "Ankleidelampe SZ" <light> ( gLampenSZ ) [ "Lighting" ] { channel="homematic:HM-LC-Sw1-FM:x:KEQ1075291:1#STATE" }
Group:Switch:OR(ON, OFF) gHue <colorwheel>
Group:Color gHueColor "Hue Lampen Farbe" <colorwheel>
Group:Switch gHueToggle "Hue Lampen" <light>
Group gHueAlarm "Hue Alarm" <alarm>
Group gHueColorLoopWZ "Hue Color Loop WZ" <colorwheel>
// Bulb3 Schlafzimmer
Group:Switch gHue3 (gHue, gLampenSZ)
Switch Hue3_Toggle "Farblampe 3 SZ" <colorwheel> (gHue3,gHueToggle) { channel="hue:0210:x:1:brightness" }
Dimmer Hue3_Dimmer "Dimmer 3 [%d%%]" <light> (gHue3) { channel="hue:0210:x:1:brightness" }
Color Hue3_Color "Farbe 3" <colorwheel> (gHue3,gHueColor) { channel="hue:0210:x:1:color" }
Dimmer Hue3_ColorTemp "Farbtemperatur 3" <colorwheel> (gHue3) { channel="hue:0210:x:1:color_temperature" }
String Hue3_Alarm "Alarm 3" <alarm> (gHue3,gHueAlarm) { channel="hue:0210:00178823bc22:1:alert" }
Switch Hue3_ColorLoop "ColorLoop 3" <colorwheel> (gHue3) { channel="hue:0210:x:1:effect" }
