I’m running fine with build 925. Running top, java is taking around 5-10%. I tested running a Odroid C2(arm64) with Oracle 8 java and an Odroid XU4(arm32) with Oracle 8 java and tested with java versions “1.8.0_131” and “1.8.0_144”.
Somewhere around build 940 (i guess, not sure) I see that the CPU is increasing by hour/day. It looks that every now and then the CPU goes up starting with the same 5-10% and now after 4 hours it’s running 40-50% CPU. What I see that after a day or so the CPU load is 200%+. It is sort of CPU leakage :-). In the logs I don’t see anything different compared to the 925 build. My question is how to trace the root cause of this.
Any suggestions would be very welcome!
