- Platform information:
- Hardware: Intel Core i7 4550u
- OS: Windows 8.1 professional 64bit
- Java Runtime Environment: Java 8 Update 151 (64bit)
- openHAB version: 2.2.0 (Release Build)
- Issue of the topic: OH stopped working completely (process finnished abruptly) without warning tonight at 22:25:57. The only indication can be found in openhab.log (last 4 entries) which shows an error with arthome.ui.icon.internal.IconServlet:
2018-01-10 22:25:12.276 [ERROR] [arthome.ui.icon.internal.IconServlet] - Failed sending the icon byte stream as a response: Nicht gend Systemressourcen, um den angeforderten Dienst auszufn
2018-01-10 22:25:12.277 [ERROR] [arthome.ui.icon.internal.IconServlet] - Failed sending the icon byte stream as a response: Nicht gend Systemressourcen, um den angeforderten Dienst auszufn
2018-01-10 22:25:19.829 [ERROR] [arthome.ui.icon.internal.IconServlet] - Failed sending the icon byte stream as a response: Nicht gend Systemressourcen, um den angeforderten Dienst auszufn
2018-01-10 22:25:19.833 [ERROR] [arthome.ui.icon.internal.IconServlet] - Failed sending the icon byte stream as a response: Nicht gend Systemressourcen, um den angeforderten Dienst auszufn
I am using OH2.2.0 since 29.12.2017 , the system was running fine for more than a week now.
