Hiya, after todays update to OH2.2 my installation is crashing at startup.
I have an apt-get installation on a pi3. Removal of packages and reinstall didn’t help.
Any ideas what else I can try?
/var/log/openhab2/openhab.log below
`2017-12-19 12:35:07.375 [ERROR] [org.eclipse.smarthome.core.audio ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.audio
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.audio [112]
Unresolved requirement: Import-Package: org.eclipse.jdt.annotation; resolution:="optional"
Unresolved requirement: Import-Package: org.osgi.service.http
at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2017-12-19 12:35:07.432 [ERROR] [org.eclipse.smarthome.core.voice ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.voice
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.voice [121]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.audio
-> Export-Package: org.eclipse.smarthome.core.audio; bundle-symbolic-name=“org.eclipse.smarthome.core.audio”; bundle-version=“0.10.0.b1”; version="0.0.0"
2017-12-19 12:35:07.439 [ERROR] [org.eclipse.smarthome.io.javasound ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.javasound
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.javasound [124]
2017-12-19 12:35:07.453 [ERROR] [org.eclipse.smarthome.io.net ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.net
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.net [126]
2017-12-19 12:35:07.461 [ERROR] [org.eclipse.smarthome.io.rest.voice ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.voice
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.rest.voice [133]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.voice.text
-> Export-Package: org.eclipse.smarthome.core.voice.text; bundle-symbolic-name=“org.eclipse.smarthome.core.voice”; bundle-version=“0.10.0.b1”; version="0.0.0"
-> Export-Package: org.eclipse.smarthome.core.voice; bundle-symbolic-name=“org.eclipse.smarthome.core.voice”; bundle-version=“0.10.0.b1”; version="0.0.0"
Unresolved requirement: Import-Package: org.eclipse.smarthome.io.rest
-> Export-Package: org.eclipse.smarthome.io.rest; bundle-symbolic-name=“org.eclipse.smarthome.io.rest”; bundle-version=“0.10.0.b1”; version="0.0.0"
org.eclipse.smarthome.io.rest [127]
Unresolved requirement: Import-Package: org.glassfish.jersey.server
2017-12-19 12:35:07.474 [ERROR] [org.eclipse.smarthome.io.webaudio ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.webaudio
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.webaudio [135]
2017-12-19 12:35:07.485 [ERROR] [org.eclipse.smarthome.model.core ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.core
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.core [136]
Unresolved requirement: Import-Package: org.eclipse.xtext.common.types.impl
-> Export-Package: org.eclipse.xtext.common.types.impl; bundle-symbolic-name=“org.eclipse.xtext.common.types”; bundle-version=“2.12.0.v20170519-0752”; version=“0.0.0”; x-internal:=“true"
org.eclipse.xtext.common.types [163]
Unresolved requirement: Require-Bundle: org.eclipse.emf.mwe2.lib; bundle-version=“2.2.0”; x-installation:=“greedy”; resolution:=“optional"
Unresolved requirement: Require-Bundle: org.objectweb.asm; bundle-version=”[5.0.1,6.0.0)”
2017-12-19 12:35:07.556 [ERROR] [org.eclipse.smarthome.model.rule ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.rule [144]
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.core
-> Export-Package: org.eclipse.smarthome.model.core; bundle-symbolic-name=“org.eclipse.smarthome.model.core”; bundle-version=“0.10.0.b1”; version="0.0.0"
-> Export-Package: org.eclipse.xtext.common.types.impl; bundle-symbolic-name=“org.eclipse.xtext.common.types”; bundle-version=“2.12.0.v20170519-0752”; version=“0.0.0”; x-internal:="true"
Unresolved requirement: Require-Bundle: org.objectweb.asm; bundle-version=”[5.0.1,6.0.0)"
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.items
-> Export-Package: org.eclipse.smarthome.model.items; bundle-symbolic-name=“org.eclipse.smarthome.model.item”; bundle-version=“0.10.0.b1”; version="0.0.0"
org.eclipse.smarthome.model.item [137]
Unresolved requirement: Require-Bundle: com.ibm.icu; resolution:="optional"
Unresolved requirement: Require-Bundle: org.apache.commons.logging; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.emf.codegen.ecore; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.emf.mwe.utils; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.emf.mwe2.launch; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.smarthome.model.lazygen; resolution:="optional"
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.core.valueconverter
-> Export-Package: org.eclipse.smarthome.model.core.valueconverter; bundle-symbolic-name=“org.eclipse.smarthome.model.core”; bundle-version=“0.10.0.b1”; version="0.0.0"
Unresolved requirement: Require-Bundle: org.eclipse.xtext.common.types
-> Bundle-SymbolicName: org.eclipse.xtext.common.types; bundle-version=“2.12.0.v20170519-0752”; singleton:="true"
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.script.engine.action
-> Export-Package: org.eclipse.smarthome.model.script.engine.action; bundle-symbolic-name=“org.eclipse.smarthome.model.script”; bundle-version=“0.10.0.b1”; version="0.0.0"
org.eclipse.smarthome.model.script [147]
-> Export-Package: org.eclipse.smarthome.model.script; bundle-symbolic-name=“org.eclipse.smarthome.model.script”; bundle-version=“0.10.0.b1”; version="0.0.0"
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.persistence.extensions
-> Export-Package: org.eclipse.smarthome.model.persistence.extensions; bundle-symbolic-name=“org.eclipse.smarthome.model.persistence”; bundle-version=“0.10.0.b1”; version="0.0.0"
org.eclipse.smarthome.model.persistence [141]
Unresolved requirement: Require-Bundle: org.eclipse.smarthome.model.item
-> Bundle-SymbolicName: org.eclipse.smarthome.model.item; bundle-version=“0.10.0.b1”; singleton:=“true”
2017-12-19 12:35:07.610 [ERROR] [eclipse.smarthome.model.rule.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule.runtime
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.rule.runtime [146]
-> Export-Package: org.eclipse.smarthome.model.script.engine; bundle-symbolic-name=“org.eclipse.smarthome.model.script”; bundle-version=“0.10.0.b1”; version="0.0.0"
-> Export-Package: org.eclipse.smarthome.model.script; bundle-symbolic-name=“org.eclipse.smarthome.model.script”; bundle-version=“0.10.0.b1”; version=“0.0.0”
2017-12-19 12:35:07.628 [ERROR] [org.eclipse.smarthome.model.script ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.script
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.script [147]
-> Export-Package: org.eclipse.smarthome.core.voice.text; bundle-symbolic-name=“org.eclipse.smarthome.core.voice”; bundle-version=“0.10.0.b1”; version=“0.0.0”
2017-12-19 12:35:07.673 [ERROR] [lipse.smarthome.model.script.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.script.runtime
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.script.runtime [149]
Unresolved requirement: Require-Bundle: org.eclipse.smarthome.model.script
-> Bundle-SymbolicName: org.eclipse.smarthome.model.script; bundle-version=“0.10.0.b1”; singleton:="true"
2017-12-19 12:35:08.318 [ERROR] [org.eclipse.xtext.common.types ] - FrameworkEvent ERROR - org.eclipse.xtext.common.types
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.xtext.common.types [163]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]`
