Crazy bevavior in Basic UI OH3
Tags: #<Tag:0x00007fc90de0e768> #<Tag:0x00007fc90de0f550>
Nearly: We are on the way. But that code lookd good. We have to do deeper search in getUnit
Yes, thats my plan tomorrow :slight_smile:
I m no developer, but looked deeper from function to function until system units in another imported code. Maybe because of metric or what else. I think needs somebody more familiar with Java as I am
The issue has been solved
As long as the new openHAB version is not released that contains this fix you can just set a label to the widget in the sitemap as a workaround :slight_smile:
Thanks to @AndrewFG for providing the piece within the sourcecode where I started debugging :slight_smile:
To be specific you need to set a label that contains a unit format string e.g. “Setpoint [%.1f °C]”
