I’m testing a mecross switch with MQTT & openhab, and it’s almost working. I have one last step, which is to create an MD5 hash of some values to sign the JSON payload in a javascript transform script.
My script so far:
(function(state) {
var logger = Java.type("org.slf4j.LoggerFactory").getLogger("myScript");
logger.warn("mecross.js - start");
var message = "messsage" + Date.now();
var timestamp = Date.now() / 100;
var result = {};
result.header = {};
result.header.messageId = message;
result.header.namespace = "Appliance.Control.ToggleX";
result.header.method = "SET";
result.header.payloadVersion = 1;
result.header.from = "/appliance/openhab/ack";
result.header.timestamp = timestamp;
result.header.sign = MD5(message+timestamp).toString();
result.payload = {}
result.payload.togglex = {};
result.payload.togglex.channel = 0;
result.payload.togglex.onoff = state == "1"?1:0;
logger.warn(JSON.stringify(result));
return JSON.stringify(result);
})(input)
My issue is with the following line:
I need a function to create the MD5 hash — Does one exist? Or do I need to create my own?
Thank you.
