Ok so yesterday I was working on some code to control a heater, I did get it to work almost the way I’d like it to. But I’d like it to offset the turn on point to one or two degrees below the set point, and turn off one or two degrees above the set point.
this is the rule I currently have:
rule "Maintain Heat"
Item temperature1 received update
or Item TSsetpoint received update
or Item TstatEnable received update
if (TstatEnable.state == ON){
if (temperature1.state <= TSsetpoint.state){
if (Heat.state == OFF){
sendCommand(Heat,ON)
else if (temperature1.state >= TSsetpoint.state){
sendCommand(Heat,OFF)
What I’d like to do is like this, but it doesn’t seem to work (I commented the two lines I’m talking about)
if (temperature1.state <= TSsetpoint.state-1){ // Here's the problem "ADDED -1 HERE"
else if (temperature1.state >= TSsetpoint.state+1){ // Here's the problem "ADDED +1 HERE"
sorry the error I was getting getting:
Error during the execution of rule ‘Maintain Heat’: The name ’ - ’ cannot be resolved to an item or type.
I made the changes you suggested but now i get this error:
2016-12-15 16:04:01.502 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘Maintain Heat’: Cannot cast org.openhab.core.library.types.DecimalType to void
yes I am sure the item is called Heat, ans yes I verified that TSsetpoint does indeed have a state, (currently 74), I just tried changing sendCommand(Heat,ON) to Heat.sendCommand(ON) I’m still getting this error:
OK, just copied and pasted your code, I had to change the first line (item was misspelled), but I’m still getting this error:
this is what I’ve got back from the logs between this and the last try:
2016-12-15 16:28:41.505 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘Maintain Heat’: Cannot cast org.openhab.core.library.types.DecimalType to void
2016-12-15 16:28:52.909 [INFO ] [runtime.busevents ] - PCD2 state updated to OFF
2016-12-15 16:28:55.909 [INFO ] [runtime.busevents ] - PCD1 state updated to OFF
2016-12-15 16:29:22.161 [INFO ] [.o.b.i.InsteonPLMActiveBinding] - devices: 6 configured, 6 polling, msgs received: 10
2016-12-15 16:29:24.434 [INFO ] [.o.b.i.i.device.MessageHandler] - DimmerRequestReplyHandler: set device 27.2A.C7 to level 100
2016-12-15 16:29:27.052 [INFO ] [c.internal.ModelRepositoryImpl] - Refreshing model 'Tstat.rules’
2016-12-15 16:29:33.122 [INFO ] [runtime.busevents ] - TstatEnable received command OFF
2016-12-15 16:29:33.522 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘Maintain Heat’: Cannot cast org.openhab.core.library.types.DecimalType to void
2016-12-15 16:29:37.364 [INFO ] [runtime.busevents ] - lightLevel state updated to 1.00
2016-12-15 16:29:37.468 [INFO ] [runtime.busevents ] - temperature1 state updated to 69.98
2016-12-15 16:29:37.474 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘Maintain Heat’: Cannot cast org.openhab.core.library.types.DecimalType to void
here are my item definitions:
Number temperature1 “Room Temperature [%.1f °F]” (Jory) {mqtt="<[myBroker:STATUS/TF1:state:JS(trim.js)]"}
Switch Heat “Heater” (Jory){insteonplm=“2F.83.A2:F00.00.02#switch”}
Number TSsetpoint “Heating Set Point” (Jory)
Switch TstatEnable “Tstat enable” (Jory)
OK, lets try to give it a little extra hint about Item types. We can also add some logging to know what the rule things temperature1.state is.
logInfo("test", "temperature1.state = " + temperature1.state.toString)
val Number temp1 = temperature1.state as Number
logInfo("test", "Temperature 1 = " + temp1)
val Number setPoint = TSsetpoint.state as Number
logInfo("test", "Setpoint = " + setPoint)
DecimalType is a Number so the above should work OK.
I’ll definitely be tweaking it a bit, but it’s nice to have a baseline where everything works, thanks so much for your help though I really appreciate it.
I really like that you changed this if(Heat.state == OFF) to if(Heat.state != OFF).
I thought about that a minute and realized that the device might not always report OFF or may be uninitialized, thanks for that bit. so at least I took away something, even if I don’t understand why my code wasn’t working. so thanks again.
