Create Timer for Sunset and Sunrise
I like to create a Timer (createTier) for Sunset and Sunrise_Time
Items:
DateTime Sunrise_Time “Sonnenaufgang [%1$tH:%1$tM]” {astro=“planet=sun, type=rise, property=start, offset=15”}
DateTime Sunset_Time “Sonnenuntergang [%1$tH:%1$tM]” {astro=“planet=sun, type=set, property=end, offset=-20”}
Rules:
var DateTime Sunrise = parse(now.getYear() + “-” + now.getMonthOfYear() + “-” + now.getDayOfMonth() + “T” + Sunrise_Time.state)
var DateTime Sunset = parse(now.getYear() + “-” + now.getMonthOfYear() + “-” + now.getDayOfMonth() + “T” + Sunset_Time.state)
createTimer(Sunrise) [| sendCommand(Schalter0_Switch, OFF) ]
createTimer(Sunset) [| sendCommand(Schalter0_Switch, ON) ]
Unfortunately it is not working, any hints?
F Hatz
I am sure you already know this, but just in case…
You can associate the astro binding with a Switch item (instead of a DateTime item), in which case the binding will handle the timer-stuff for you. When the event happens (i.e. sunrise, sunset, etc.) the switch will “fire” (briefly toggle from OFF to ON and then OFF again) and this can be used as trigger condition in rules (e.g. for turning lights ON or OFF).
Alternatively you can use it to toggle a “daylight” switch and then use this to control your lights, something like this:
Switch Sunrise_Event {astro="planet=sun, type=rise, property=start, offset=15"}
Switch Sunset_Event {astro="planet=sun, type=set, property=end, offset=-20"}
Switch Daylight
rule "Daylight - Sunrise"
	Item Sunrise_Event changed to ON
	logInfo("daylight", "End of sunrise. It is now daylight outside.")
	Daylight.postUpdate(ON)
rule "Daylight - Sunset"
	Item Sunset_Event changed to ON
	logInfo("daylight", "Start of sunset. It is now dark outside.")
	Daylight.postUpdate(OFF)
Hope this helps.
BR
Kjetil
I need to use the createTimer function as the script is used for a presence simulation. Using the Caldav-binding a switch ‘Gang’ is toggled on/off. In respect to sunrise and sunset time the switch ‘Licht_Gang’ is either immediately executed or delayed until the sunrise/sunset event.
Items:
Switch Licht_Gang “Licht Gang” (Licht, Schalter) {homematic=“address=MEQ1510934, channel=1, parameter=STATE” }
Switch Gang // <- this item is changed by the caldav-binding
Rule:
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.openhab.core.transform.actions.Transformation
import org.joda.time.*
import org.openhab.model.script.actions.Timer
var Timer Gang_Begin
var Timer Gang_End
var DateTime Gang_StartTime = null
var DateTime Gang_StopTime = null
rule "Gang"
Item Gang changed
if (Toggle_Absence.state == ON) {
if (Gang.state == ON) {
Gang_StartTime = now
if (Gang_StartTime.isBefore(Sunset) && Gang_StartTime.isAfter(Sunrise)) {
Gang_StartTime = Sunset
Gang_Begin = createTimer(Gang_StartTime) [| sendCommand(Licht_Gang, ON) ]
} else {
Gang_StopTime = now
if (Gang_StopTime.isAfter(Sunrise) && Gang_StartTime.isBefore(Sunset)) {
Gang_StopTime = Sunrise
if (Gang_StartTime != null && Gang_StopTime.isAfter(Gang_StartTime)) {
Gang_StopTime = Gang_StopTime.plusSeconds(2)
Gang_End = createTimer(Gang_StopTime) [| sendCommand(Licht_Gang, OFF) ]
} else {
Gang_Begin.cancel
Gang_Begin = null
if (Licht_Gang.state == ON) {
This is exactly what I need … unfortunately it doesn’t work for me :frowning:
The rules never fire.
.items
    Switch Daylight
.rules
	postUpdate(EventLog, "Daylight - Sunrise")        // eventlog.rules
	sendPushoverMessage(pushoverBuilder("End of sunrise. It is now daylight outside.").withSound("pushover"))
	postUpdate(EventLog, "Daylight - Sunset")        // eventlog.rules
	sendPushoverMessage(pushoverBuilder("Start of sunset. It is now dark outside.").withSound("pushover"))
The Astro-Binding is installed and shows values in my sitemap.
But is the code above still compatible with oH2.4 - especially this astro line:
Thanks in advance
No, it is not. Please take a look at the documentation for the Astro v2 binding:
The concept has changed a bit with the introduction of things, event channels, etc.
My working setup is based on the following:
astro.things
Thing astro:sun:home [ geolocation="54.1362,05.9753" ]
(Location is randomized for privacy, :-))
general.rules
rule "general.rules - Daylight - Start"
  Channel "astro:sun:home:daylight#event" triggered START
  vDaylight.sendCommand(ON)
rule "general.rules - Daylight - End"
  Channel "astro:sun:home:daylight#event" triggered END
  vDaylight.sendCommand(OFF)
Let me know if it works out for you.
Great - many thanks for the really quick reply.
I’ll try this one and get back to you!
It works :slight_smile:
