Hi everybody,
just migrating from OH2 to OH3, wanted to create the rules I’ve had in OH2 with red node but I have very little practice with that and spent the last 3 days with looking videos and reading tutorials, anyway I couldn’t find the answer to my problem.
I have the following items in OH3:
- switch tasmotaX
- number timer_duration
timer_duration is defined as setpoint and can get values between 5 and 30 (minutes in my case).
I just want to define a timer flow that checks the value of timer_duration when tasmotaX is switched ON and sets the switch off after timer_duration has expired.
If tasmotaX is switched OFF and ON again while the timer is running the timer should obviously restart from scratch.
I’ve made some tests with adding a simple delay, but that will be always switch off at a fixed time.
How can I get this timer_duration variable into my flow?
Thank you very much!!!
