I have a lambda and I want to create a Timer in it.
I have done this before and in different rules this works just fine.
However in this case I can’t get it to work and I get errors.
The Designer and openhab shows this as a Problem:
createTimer(now.plusMinutes(30)) [|
val anz = countItem30min.state as DecimalType
if( anz > 0) countItem30min.postUpdate( anz - 1)
This is the resulting Error:
2015-11-06 10:37:13.603 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Wohnzimmer Balkontür Counter': The name '<XFeatureCallImplCustom>.plusMinutes(<XNumberLiteralImpl>)' cannot be resolved to an item or type.
Where is this Error coming from?
// Imports
import org.yoda.time.*
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import java.util.regex.Matcher
import java.util.regex.Pattern
import java.util.Date
import java.text.SimpleDateFormat
val org.eclipse.xtext.xbase.lib.Functions$Function2 CounterHandler = [
org.openhab.core.items.GenericItem countItem,
org.openhab.core.items.GenericItem countItem30min|
//Counter erhöhen
countItem.postUpdate( countItem.state as DecimalType + 1)
val DateTimeType now = new DateTimeType()
//30min Counter
countItem30min.postUpdate( countItem30min.state as DecimalType + 1)
//Dynamischen Namen
val String nameraw = countItem.name
val Pattern pattern_name = Pattern::compile( "^ctr_(\\w+)$" )
var Matcher matcher_name = pattern_name.matcher( nameraw)
matcher_name.find()
val int count_name = matcher_name.groupCount()
if( count_name != 1) {
logError( "Counter", String::format( "%10s | Groupcount doesn't match 1! Name: '%s'", "Counter", nameraw))
return false
val String itemname = matcher_name.group(1)
//Timestamp-History
val DateTimeType ts0 = gTimestamp.members.findFirst[ name.equals( "ts0_" + itemname)].state as DateTimeType
val DateTimeType ts1 = gTimestamp.members.findFirst[ name.equals( "ts1_" + itemname)].state as DateTimeType
val DateTimeType ts2 = gTimestamp.members.findFirst[ name.equals( "ts2_" + itemname)].state as DateTimeType
postUpdate( "ts3_" + itemname, ts2.toString())
postUpdate( "ts2_" + itemname, ts1.toString())
postUpdate( "ts1_" + itemname, ts0.toString())
postUpdate( "ts0_" + itemname, now.toString())
return false
