I have installed Open HAB in raspberry. I have create a new sitemap in configurations folder like home.sitemap and the code is
sitemap home label="Home"
// Raspberry Pi
// GPIO
Frame label="Rasperry Pi GPIO"
Switch item=RaspiLED
<img src="//community-openhab-org.s3-eu-central-1.amazonaws.com/original/2X/0/0a1b0540081777acb37d04f3acd84d2737addce4.jpg" width="690" height="387">
But,I cannot see the sitemap in webpage
MHerbst
(Martin Herbst)
March 12, 2017, 11:51am
#2
You have to option: either set your new sitemap as the default sitemap in Paper UI (under Configuration/Services/UI/Basic UI) or use the following URL http://<openHAB address>:8080/basicui/app?sitemap=home
But,I can see in Available sitemaps only DEMO sitemap! How to check my added sitemap
MHerbst
(Martin Herbst)
March 12, 2017, 12:09pm
#4
Here you can simply enter the name:
Sir, check both images I cannot find AUTOMATION Sitemap and I configured as per your suggestion
MHerbst
(Martin Herbst)
March 12, 2017, 12:22pm
#6
I think there is a problem in your sitemap definition. In your sample I see a “ ” tag outside the sitemap. This is probably not allowed and so your sitemap can’t be used.
I didnt get you sir, Can you figure it out clearly ? can you show me in the code?
MHerbst
(Martin Herbst)
March 12, 2017, 12:41pm
#9
The last line in your sitemap that you posted in your first post of this thread contains <img src= ...
. This won’t work.
sir, actually i have posted an image in the form of link! it is not included in the actual code
MHerbst
(Martin Herbst)
March 12, 2017, 1:02pm
#11
Ah OK. Can you see any error messages in the openhab.log file?
