I am experimenting with a binding to get vehicle information from a backend system, similar to VolvoOnCall or Tesla. The APIs require the use of a JWT in the authentication handshake, and oddly uses an insecure key length.
I was able to build my binding with JJWT (https://github.com/jwtk/jjwt) but this library staunchly refuses to work with the insecure key, which is probably a good stand, but an impediment to my goal. Another promising library is jose4j (https://bitbucket.org/b_c/jose4j/wiki/Home) but including this leads down a path of dependencies (in particular BouncyCastle) which I believe would make deployment challenging if my effort is successful.
I have scoured the forums and repos looking for examples of Bindings using a JWT for access to APIs. Unfortunately I really have not found any solution. I did notice a recent merge from @ysc to use JWTs in the REST interface, and the code has a dependency on jose4j. I did not see the other dependency in the code changes, so maybe I’m missing something obvious.
Does anyone have any insights or suggestions to use JWTs? I’d like to stay within the best practices of OpenHAB so anything I build could benefit the community. Thanks for any leads.
