I am trying the ‘new’ Rules engine so JSScripting and take a step by step approach to filter out any issues. So far so good but I’ve run into a problem.
Goal:
Generate a random list of switches. For each switch, create a timer and then send an ON command to the corresponding switch when the timer is up. The length of the timer is also randomly generated.
Problem:
The list of swicthes is indeed generated in random order. This is confirmed by the logs. Further, timers are created at random intervals, also confirmed by the logs. However, when the timer is up, the ON command is send to the same item over and over again and not to the next item. In other words, it looks like the timer is created for the same item while the log part that states “Winner is…” is moving through the list of items instead of sticking to the same item.
Code:
function startTimer(){
for (var i = 0; i < maxLights; i++) {
var rand = makeUniqueRandom();
var randomSwitch = switches[rand];
var timeoutID = setTimeout(function(){ // If timer is up
randomSwitch.sendCommand("ON"), // Switch light on
console.log("Timer is up for", randomSwitch.name) // Log entry to debug code
}, getRandomInt(0, startDiff) * 60000); //Set timeout by generating a random minute number and convert to milli seconds
var temp = timeoutID.toString();
console.log("Winner is", randomSwitch.name, ". TimerID is", temp.split('.')[7]);
var test = startTimer();
Logs:
2022-01-12 19:32:01.341 [INFO ] [org.openhab.automation.script ] - Generated random time is 4 mins.
2022-01-12 19:32:01.351 [INFO ] [org.openhab.automation.script ] - Winner is wandverlichting_gFloor_switch . TimerID is TimerImpl@77639552
2022-01-12 19:32:01.352 [INFO ] [org.openhab.automation.script ] - Generated random time is 26 mins.
2022-01-12 19:32:01.354 [INFO ] [org.openhab.automation.script ] - Winner is plafondverlichtingAchter_fFloor_switch . TimerID is TimerImpl@5f57d4f9
2022-01-12 19:32:01.356 [INFO ] [org.openhab.automation.script ] - Generated random time is 28 mins.
2022-01-12 19:32:01.358 [INFO ] [org.openhab.automation.script ] - Winner is plafondlampenVoor_fFloor_switch . TimerID is TimerImpl@564c02c4
2022-01-12 19:32:01.359 [INFO ] [org.openhab.automation.script ] - Generated random time is 20 mins.
2022-01-12 19:32:01.361 [INFO ] [org.openhab.automation.script ] - Winner is hoeklamp_fFloor_switch . TimerID is TimerImpl@43233cfb
2022-01-12 19:32:01.362 [INFO ] [org.openhab.automation.script ] -
2022-01-12 19:36:01.365 [DEBUG] [org.openhab.automation.script.items ] - Sending command ON to hoeklamp_fFloor_switch
2022-01-12 19:36:01.368 [INFO ] [org.openhab.automation.script ] - Timer is up for hoeklamp_fFloor_switch
2022-01-12 19:52:01.363 [DEBUG] [org.openhab.automation.script.items ] - Sending command ON to hoeklamp_fFloor_switch
2022-01-12 19:52:01.365 [INFO ] [org.openhab.automation.script ] - Timer is up for hoeklamp_fFloor_switch
2022-01-12 19:58:01.356 [DEBUG] [org.openhab.automation.script.items ] - Sending command ON to hoeklamp_fFloor_switch
2022-01-12 19:58:01.357 [INFO ] [org.openhab.automation.script ] - Timer is up for hoeklamp_fFloor_switch
2022-01-12 20:00:01.358 [DEBUG] [org.openhab.automation.script.items ] - Sending command ON to hoeklamp_fFloor_switch
2022-01-12 20:00:01.361 [INFO ] [org.openhab.automation.script ] - Timer is up for hoeklamp_fFloor_switch
I see that the “Timer is up…” message refers to the last “Winner is…” timer item that was created. Could it be that although multiple timers are being created the variables passed to the timers are being overwritten each time? I.e., multiple timers are created but all will process the item most recently processed.
Could the contents of the timeoutID variable be moved into the array? If the array is declared at the top of a js rules file then it persists between invocations of the rule. Instead of a 1D array you’d have a 2D array, the first dimension would be the random index, the second dimension would contain details about each timer such as the setTimeout function.
Alternatively you could use the cache functions as described here.
It does seem related, yes. Timers seem to be a bit tricky to handle.
I recently wrote some JS code to turn lights on if movement was detected and turn them off after a period of time. I started using the cache functions but changed to managing the timers in a 2d array so I could list the contents of the array and store several pieces of data about each timer such as the room name, time it started, etc.
I’m thinking of that as “the timer”. It would be interesting to call/create that from the base rule, instead of from an intermediate function. There’s only one of ‘something’, so it gets shared and overwritten, but not too clear what to me.
First of all, thanks for your replies and thinking with me on this issue.
I have dropped the function startTimer(){..} bit. This is what you refer to as inline right? Unfortunately it still persists, the problem does. Please let me know if you mean something differen with ‘inline’ Log:
2022-01-13 16:40:30.135 [INFO ] [org.openhab.automation.script ] - Generated random time is 16 mins.
2022-01-13 16:40:30.143 [INFO ] [org.openhab.automation.script ] - Winner is hoeklamp_fFloor_switch . TimerID is TimerImpl@7e7dc062
2022-01-13 16:40:30.146 [INFO ] [org.openhab.automation.script ] - Generated random time is 30 mins.
2022-01-13 16:40:30.148 [INFO ] [org.openhab.automation.script ] - Winner is plafondverlichtingAchter_fFloor_switch . TimerID is TimerImpl@1cde7c0e
2022-01-13 16:40:30.150 [INFO ] [org.openhab.automation.script ] - Generated random time is 4 mins.
2022-01-13 16:40:30.152 [INFO ] [org.openhab.automation.script ] - Winner is wandverlichting_gFloor_switch . TimerID is TimerImpl@300a6423
2022-01-13 16:40:30.154 [INFO ] [org.openhab.automation.script ] - Generated random time is 10 mins.
2022-01-13 16:40:30.156 [INFO ] [org.openhab.automation.script ] - Winner is plafondlampenVoor_fFloor_switch . TimerID is TimerImpl@1a573464
2022-01-13 16:40:30.157 [INFO ] [org.openhab.automation.script ] -
2022-01-13 16:44:30.171 [DEBUG] [org.openhab.automation.script.items ] - Sending command ON to plafondlampenVoor_fFloor_switch
2022-01-13 16:44:30.174 [INFO ] [org.openhab.automation.script ] - Timer is up for plafondlampenVoor_fFloor_switch
How and where would you implement let in my code in this case? At the part where it says var timeoutID = setTimeout(function(){...} and change that to let timeoutID = setTimeout(function(){...}? I’ve read the MDN-link you provided and I do get the concept but unsure as where to put it…
I don’t see why not but I am not that good in JS. This would be an array with key->value I guess? Or am I thinking to complicated here? Maybe you give a little hint
randomswitch should be defined using let, to prevent it being overwritten in the next iteration of the loop.
Edit: since randomSwitch is defined using var it’s scope is the startTimer function, so it gets overwritten on every iteration of the loop. When the timers execute, all will reference this variable, which now holds the last item in the loop. If defined using let it has block scope, so it will be a different variable for each loop iteration and each timer will have a different item.
Won’t the variables then be destroyed when execution of the block (in this case the for loop) ends? If they’re not destroyed then don’t we have memory leak? How will the JS engine know that these variable contain active timers and the memory for them should/shouldn’t be reclaimed/garbage collected?
I barely know any JS so don’t know enough about the technicalities to comment.
Not sure how it’s implemented, but the variable should be kept in memory as long as there’s a reference to it, which it is in the timer body. When the timer object is disposed the variable will be garbage collected. But I could be wrong, haven’t used jsscripting personally. Also don’t know how/if setTimeout relates to the openhab timer scheduler.
It’s sending the command to the last value that randomSwitch had.
One way to deal with this is to use function generators.
function timerFuncGenerator(item) {
return () => {
item.sendCommand('ON');
console.log('Timer is up for ', item.name);
var timeoutID = setTimeout(timerFuncGenerator(randomSwitch));
There are some problems with let and const when writing in UI rules for now. The problem is the Script is only created once and then reused. That’s why setting something to this persists between runs of the rule. But that means the second time the rule runs it will see that variable or constant defined with let or const will generate an error because a variable with that name already exists.
However, it might work in this case since it’s not in the global to the script scope but inside another block.
11
Store your 2d array in the cache.
Because of the limitations with let and const I describe above, the way that UI scripts are parsed and reused is almost certainly going to change in the nearish future. When that happens, the this trick to save variables between runs of the script will no longer work.
I’m not certain if GraalVM is garbage collected like that or not. But assuming it is, the timer will have pointers to those variables which will keep them from being garbage collected.
For context and in case anyone else reading this thread finds it useful and in case you have any more advice :)…
At the moment I have the array defined outside of any rule at the very top of my lightingrules.js file like this:
let lightingTimers = [];
I also have a lightingfunctions.js file which processes the array. The lightingfunctions.js file is loaded into any rules in the lightingrules.js file that need it like this:
var OPENHAB_CONF = java.lang.System.getenv("OPENHAB_CONF");
load(OPENHAB_CONF+'/automation/lib/js/personal/commonfunctions.js');
load(OPENHAB_CONF+'/automation/lib/js/personal/lightingfunctions.js');
No rules directly access the array, there are functions to interact with the array (add elements, check for existence, delete elements) so all I should need to do is load the array from the cache in any of these array functions and then write it back into the cache at the end of each function.
Thanks for the info, I’ll keep any eye on future release notes and take backups before I upgrade.
Would this be future proof for now? I need to read up on these generators but effectively, is ...FuncGenerator a special type of function?
The first signs are promising. The first run it did work as required. I’ll test it some more the upcoming days…
The array approach from @higgers also sounds very solid but I do need a bit more reading and test-coding to fill, check and empty the arrays as he described.
