rule "test"
Time cron “0 45 07 * * ?” or
Time cron “0 45 08 * * ?” or
Time cron “0 45 09 * * ?” or
Time cron “0 45 10 * * ?” or
Time cron “0 45 11 * * ?” or
Time cron “0 45 12 * * ?” or
Time cron “0 45 13 * * ?” or
Time cron “0 45 14 * * ?” or
Time cron “0 45 15 * * ?” or
Time cron “0 45 16 * * ?” or
Time cron “0 45 17 * * ?” or
Time cron “0 45 18 * * ?” or
Time cron “0 45 19 * * ?” or
Time cron “0 45 20 * * ?” or
Time cron “0 45 21 * * ?” or
Time cron “0 45 22 * * ?” or
Time cron “0 45 23 * * ?” or
Time cron “0 45 00 * * ?” or
Time cron “0 45 01 * * ?” or
Time cron “0 45 02 * * ?” or
Time cron “0 45 03 * * ?” or
Time cron “0 45 04 * * ?” or
Time cron “0 45 05 * * ?” or
Time cron "0 45 06 * * ?“
sendMail("www@gmail.com”, “Forecast and Blowing Temps”, "AC State/DesiredCool/CurrentTemp: " + EcoBeeEquipmentStatus.state + " " + runtime_desiredCool.state + " " + remoteSensors_hall_capability_temperature.state + "\nForecast: " + weather_forecasts0_temperature.state + "\nBlowingTemp: " + Laundry_Temperature.state + “”)
Not directly related to your question, and I am pretty rusty with cron, but I am curious… seeing your when clause makes me think you could accomplish the same result with 1 line.
Time cron “0 45 * * * ?”
Is that rule to fire at the 45 minute, 0 second mark of every hour?
I used that second link and that generator to make the following:
Tried the following, rule never runs:
I’d expect that to fire every 15 minutes
rule "test"
Time cron “0 */15 * ? * *”
I copied a rule and pasted it.
I left the same “rule name” and what it was doing(which is weird) is running the original rule at the interval and not running the new rule at all…weird.
If you are currently suffering from this bug, your options are (1) reduce your rule to one cron condition, (2) wait for the openHAB 2.1 stable release or (3) switch to the unstable branch and use the latest snapshot.
If you did one of the above and still encounter problems, they are probably unrelated to the bug discussed here. Please search the forum for similar cases or create a new thread.
