Seeing some very odd humidity numbers since moving to openHAB2.
rrd4j.log:2017-04-16 17:42:00.337 [RRD4jService ] - Stored 'Avg_Humidity' with state '174' in rrd4j database
rrd4j.log:2017-04-16 17:42:00.340 [RRD4jService ] - Stored 'First_Floor_Tstat_Humidity' with state '36' in rrd4j database
rrd4j.log:2017-04-16 17:42:00.340 [RRD4jService ] - Stored 'Second_Floor_Tstat_Humidity' with state '205' in rrd4j database
rrd4j.log:2017-04-16 17:42:00.347 [RRD4jService ] - Stored 'Master_Bedroom_Tstat_Humidity' with state '172' in rrd4j database
rrd4j.log:2017-04-16 17:42:00.348 [RRD4jService ] - Stored 'Dad_Bedroom_Tstat_Humidity' with state '187' in rrd4j database
rrd4j.log:2017-04-16 17:42:00.361 [RRD4jService ] - Stored 'Water_Room_Tstat_Humidity' with state '255' in rrd4j database
rrd4j.log:2017-04-16 17:42:00.364 [RRD4jService ] - Stored 'Breezeway_Tstat_Humidity' with state '255' in rrd4j database
rrd4j.log:2017-04-16 17:42:00.377 [RRD4jService ] - Stored 'Apartment_Tstat_Humidity' with state '138' in rrd4j database
.items
Group Tstat10 (Thermostats) ["Thermostat"]
Group Tstat10_Chart (Tstat10)
Number Basement_Tstat_HeatSetPoint "Basement Heat Setpoint [%.1f °F]" <temperature> (Tstat10) ["TargetTemperature"] {channel="zwave:rtc_ct100_00_000:controller:node4:thermostat_setpoint_heating"}
Number Basement_Tstat_CoolSetPoint "Basement Cool Setpoint [%.1f °F]" <temperature> (Tstat10) ["TargetTemperature"] {channel="zwave:rtc_ct100_00_000:controller:node4:thermostat_setpoint_cooling"}
Number Basement_Tstat_Temperature "Basement Temperature [%.1f °F]" <temperature> (Tstat10_Chart, Room_Temperature) ["CurrentTemperature"] {channel="zwave:rtc_ct100_00_000:controller:node4:sensor_temperature"}
Number Basement_Tstat_Humidity "Basement Humidity [%.1f %%]" <humidity> (Tstat10_Chart, Humidity) ["CurrentHumidity"] {channel="zwave:rtc_ct100_00_000:controller:node4:sensor_relhumidity2"}
Number Basement_Tstat_OpMode "Basement Mode" <settings> (Tstat10) {channel="zwave:rtc_ct100_00_000:controller:node4:thermostat_mode"}
Number Basement_Tstat_ModeState "Basement State [MAP(ct100.map):%s]" <settings> (Tstat10) {channel="zwave:rtc_ct100_00_000:controller:node4:thermostat_state"}
Number Basement_Tstat_Battery "Basement Thermostat Battery [%d %%]" <battery> (Tstat10, Battery) {channel="zwave:rtc_ct100_00_000:controller:node4:battery-level"}
DateTime Basement_Tstat_Clock
My .things
Thing zwave:rtc_ct100_00_000:controller:node2 "Node 2: CT100 - Office" (zwave:serial_zstick:controller) [ node_id=2, refresh_interval=300 ] {
Channels:
Type sensor_temperature : sensor_temperature [ config_scale=1 ]
Type thermostat_setpoint : thermostat_setpoint_cooling [ config_scale=1 ]
Type thermostat_setpoint : thermostat_setpoint_heating [ config_scale=1 ]
