I have OpenHAB running and I have a Heat Pump that is brand new and soon will run the heating of my house.
The Heatpump is controlled by a controller, named “Aeroplus 2.0/2.1” and the company building the heat pump says, they buy that controller from a supplier.
The Aeroplus ha a network connector and can be controlled using a Java Interfce from the Browser with Java Plugin.
Now, I have a few Questions :
By chance, does anyone have any experience with bindig that to OpenHAB ?
Or maybe any suggestion about a Binding that could be used to controll something through the Java interface ?
Seams to me, that the the luxtronik_2.1 might be the same as Aeroplus 2.1? Did anyone try to get some FHEM PM running in openhabian? Would be very glad for some help…
Some hints (maybe interesting for some others integrating CTA heatpumps):
Reboot your heatpump (power off/on) in order that IP connection works. For the heatpump configuration: WebServer Password can be kept default (999999).
When you add the IP address in the binding config file services/novelanheatpump.cfg: Make sure you remove “#” in the line you edit, as “#” marks comments.
For me the default port=8888 works fine, even I have the new Luxtronic V1.73 in use.
