Blaz_Komat
(Blaz Komat)
#1
I have max! Cube, but because it is unstable i have flash it with cul/cun firmware.
Then i have add max!cun bindings and in log i see that connection is made.
But when i go into menu “thigns” and i select max!cun i do not see any items.
How can i pair valve thermostats to cube flashed with cun/cul firmware?
vzorglub
(Vincent Regaud)
#2
You won’t. You may see channels but not items.
You may have to add channels yourself. Is there a big blue +?
Why is the title of the post Shelly? When it has nothing to do with shellies???
Blaz_Komat
(Blaz Komat)
#3
Hi, sorry, i will change post title.
Also can you please tell me how can i pair max radiator valve and flashed cube (cun/cul)
Best regrads
