Yesterday my internet service was down and its back now again, Also I updated dhcpcd.conf to have static IP for RPi3. Will having static IP be an issue?
Below is the event log from myopenhab.org. I cant see any entries in error log too.
An update to this. When I commented out the static IP configuration in dhcpcd.conf its working. I tried Un-commenting it back to static IP and its again started not able to access websites.
And when I connect it using Ethernet cable it works with Static IP.
So seems when I assign static IP its not able to connect to wifi. Has anyone else faced this issue? Any work around?
