Current master broken? calDAV persistance failing to build
I just did a clean clone of the git repository. The mvn clean install fails with the following error.
Is this going to be fixed soon? Is this a problem on my end? How can I exclude the calDAV project from build to work without it for now?
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-compiler-plugin:0.22.0:compile (default-compile) on project org.openhab.persistence.caldav: Compilation failure: Compilation failure:
[ERROR] /Users/Maniac/Development/Java/openhab/bundles/persistence/org.openhab.persistence.caldav/src/main/java/org/openhab/persistence/caldav/internal/CaldavPersistenceService.java:[177]
[ERROR] && calDavEvent.getEnd().toDate().before(filter.getBeginDate())) {
[ERROR] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
[ERROR] Access restriction: The method 'AbstractInstant.toDate()' is not API (restriction on classpath entry '/Users/Maniac/Development/Java/openhab/bundles/core/org.openhab.core.persistence/lib/joda-time-2.3.jar')
[ERROR] /Users/Maniac/Development/Java/openhab/bundles/persistence/org.openhab.persistence.caldav/src/main/java/org/openhab/persistence/caldav/internal/CaldavPersistenceService.java:[181]
[ERROR] && calDavEvent.getStart().toDate().after(filter.getEndDate())) {
[ERROR] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
[ERROR] /Users/Maniac/Development/Java/openhab/bundles/persistence/org.openhab.persistence.caldav/src/main/java/org/openhab/persistence/caldav/internal/CaldavPersistenceService.java:[196]
[ERROR] && eventContent.getTime().toDate().before(filter.getBeginDate())) {
[ERROR] /Users/Maniac/Development/Java/openhab/bundles/persistence/org.openhab.persistence.caldav/src/main/java/org/openhab/persistence/caldav/internal/CaldavPersistenceService.java:[200]
[ERROR] && eventContent.getTime().toDate().after(filter.getEndDate())) {
[ERROR] /Users/Maniac/Development/Java/openhab/bundles/persistence/org.openhab.persistence.caldav/src/main/java/org/openhab/persistence/caldav/internal/CaldavPersistenceService.java:[264]
[ERROR] final CaldavItem caldavItem = new CaldavItem(filter.getItemName(), eventState, eventContent.getTime().toDate());
Following the instructions on the wiki page the mvn clean install is failing for me with the Stiebel Heat Pump Binding Tests (against HEAD). Tried moving back to the 1.8 tag, no joy there, either. What am I missing?? :confused:
I got the calDAV problem working by following the eclipse quick fixes, added an import to that file and added a project dependency to the jodatime project. Now it is working. But I think this is still a problem in the latest sources and should be fixed.
I have the same problem. You can remove that module from the pom.xml in the bindings directory if you need to get past that in the meantime.
