Please inform me about the current state regarding the build system change and the schedule of the next release? Will it be a OH 2.5 release or an OH 3 version due to the lack of backward compabitlity?
Thanks in advance, unfortunately I was pretty busy for a few months now and back then, the IDE was not working and there were tons of errors showing up in Eclipse IDE.
What do you mean by „updated“? All addons on the repo work (aside from some bugs which should be fixed before the release). The problem is: bugs need to be reported, we can’t address them if we don’t know they exist.
Also the OH1 addons should work (at least that is true for those I use) WITHOUT changes.
Addons that are not part of the official repo might or might not need updates, that depends on the code.
That is great to hear - so there won’t be any surprises after updating to OH 2.5 then. Any idea when that will happen? Is the IDE starting and running smoothly?
I updated my snapshot installation some time ago from #1555 to (i think somewhere around) #1590 - nothing worked… only errors in the log… So i went back to my backup and all worked like a charm.
Are the biggest errors repaired now or is it still not advised to use the 2.5 snapshots?
That depends on what bindings you use. I know of problems with allplay, amazondashbutton and some bluetooth. But as I said: we can‘t fix what we don‘t know.
I test out pretty much every snapshot and see most/all of the errors you’ve reported in the other thread on the first startup after the cache has been cleared. After things settle down, I restart OH and the errors are gone. IMO, the S1603 is pretty stable and I am using it in my production setup.
For snapshots, you’d need to look at the individual changes, but they only go back a few builds. This is an example for openhab-core. The best way is to see what has changed is to go to the repository and look at the PRs merged prior to the build.
