Description: This custom widget provides a clean, modular, and dynamic overview of your home energy flow. It is designed to be highly configurable, allowing you to monitor your solar production, house consumption, grid balance, and secondary devices like EV chargers or heating elements.
Key Features:
Dynamic Layout: Easily toggle the visibility of the “Wallbox” and “Heater” cards via widget configuration parameters.
Grid Monitoring: Visual indicators for grid import/export (automatically switches icons and colors based on the power flow).
Smart Indicators: House consumption color changes automatically depending on whether you are currently consuming solar energy or pulling from the grid.
Highly Configurable: Use your own item names for all power values, temperatures, and states.
Configuration Parameters:
Solar Power: Solar production (W)
Autonomy: Self-sufficiency level (%)
House Consumption: Total house load (W)
Grid Power: Grid export/import (W)
Wallbox Power & State: Monitor charger status (W, enabled/disabled)
Heater Power & Temp: Track heating element stats (W, °C)
Visibility Toggles: Enable or disable Wallbox and Heater cards independently to clean up your dashboard.
Requirements:
- Fronius stuff or any other binding providing solar, consumption, and grid data items.
Screenshots
Changelog
-show/hide Wallbox and heater cards with parameter
Version 1.0
- initial release
