alda1
(Alex Needle)
1
I did a modification of the SMA 3D widget to be able handle my data:
It’s working fine, but for detail informations I impelented a button. When is clicked, special page is called:
- component: f7-block
style:
align-items: center
display: flex
flex-direction: column
height: 110px
justify-content: center
margin-top: 250px
width: 0px
slots:
default:
- component: oh-button
iconF7: graph_square_fill
color: grey
text: DETAIL
outline: true
action: navigate
actionPage: page:page_6951b7703d
style:
width: 110px
margin-right: 110px
But it’s not a nice solution and I want ask, if it’s possible do this jump when I will click on the widget.
Matze0211
(Matthias)
2
You should be able to set an action on nearly any component.
Therefore just modify you’re widget and copy the action related code
alda1
(Alex Needle)
3
where to place action when widget is touched ?
Matze0211
(Matthias)
4
Post your widget code and we can help you.
But it should be the most top component, where the action is added to the config
alda1
(Alex Needle)
5
here is
thank you
uid: SMA_widget_MOD_by_ALDA
tags: []
props:
parameters:
- context: item
label: Grid L1
required: true
type: TEXT
- context: item
label: Complete consumption L1
required: true
type: TEXT
- context: item
label: PV Production
required: true
type: TEXT
- context: item
label: Battery Power
required: true
type: TEXT
- context: item
label: Batterie SOC
required: true
type: TEXT
parameterGroups: []
timestamp: Sep 14, 2022, 8:05:51 PM
component: f7-card
class:
- display-flex
- flex-direction-column
- align-items-center
style:
height: 383px
slots:
content:
style:
--f7-theme-color: var(--f7-text-color)
display: flex
justify-content: space-between
padding: 0
slots:
default:
- component: f7-col
style:
align-items: center
display: flex
flex-direction: row
slots:
default:
style:
align-items: center
display: flex
height: 110px
margin-top: 0
width: 110px
slots:
default:
- component: oh-icon
height: 110px
icon: sma_grid_2
- component: Label
style:
color: '=(Number.parseFloat(items[props.Grid_L1].state.split(" ")[0]) >= 0) ? "red" : "green"'
font-size: 25px
font-weight: bold
margin-top: -10px
text-align: center
width: 100px
text: = items[props.Grid_L1].state + ' ᵂ'
- component: f7-col
style:
align-items: center
display: flex
flex-grow: 1
slots:
default:
style:
align-items: center
display: flex
height: 110px
margin-top: 0
width: 110px
slots:
default:
- component: Label
style:
font-size: 25px
font-weight: bold
text-align: center
width: 100px
text: =Math.round(items[props.pv_leistung].state) + ' ᵂ'
height: 110px
icon: sma_pv_2
style:
margin-top: -20px
style:
display: flex
margin: 0
padding: 0
width: 100%
slots:
default:
- component: f7-row
preserveAspectRatio: xMidYMid slice
style:
height: auto
width: auto
tag: svg
viewBox: 0 0 100 100
xmlns: http://www.w3.org/2000/svg
slots:
default:
- component: f7-row
d: M60 -5 v10 c0 30 10 35 30 35 h20
fill: none
stroke: rgba(100, 150, 200, 0.8)
stroke-width: 2
tag: path
vector-effect: non-scaling-stroke
visible: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) > 0) ? true : false'
- component: f7-row
fill: rgba(100, 150, 200, 0.8)
r: 6
style:
stroke-width: 4
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
repeatCount: indefinite
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path1"
- component: f7-row
d: M40 -5 v20 c0 40 -10 35 -30 35 h-10
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.Grid_L1].state.split(" ")[0]) < 0) ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
vectorEffect: non-scaling-stroke
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path2"
- component: f7-row
d: M50, 0 v100
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.pv_leistung].state.split(" ")[0])) > 0) ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path3"
- component: f7-row
d: M-5 50 l10 0 c40 0 35 10 35 50 l 0 20
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.Grid_L1].state.split(" ")[0]) > 0) ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path4"
- component: f7-row
d: M 105 50 l -10 0 c -40 0 -35 10 -35 50 l 0 20
fill: none
stroke-width: 2
tag: path
visible: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) < 0) ? true : false'
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#path5"
style:
align-items: center
display: flex
height: 110px
margin-top: -10px
width: 110px
slots:
default:
color: orange
height: 110px
icon: sma_consumption_2
- component: Label
style:
font-size: 25px
font-weight: bold
margin-top: -10px
text-align: center
width: 100px
text: =items[props.complete_L1].state + ' ᵂ'
- component: f7-col
style:
align-items: center
display: flex
flex-direction: row
slots:
default:
style:
align-items: center
display: flex
height: 110px
margin-top: -40px
width: 110px
slots:
default:
- component: oh-link
iconColor: red
iconF7: battery_0
iconSize: 33px
style:
font-size: 25px
font-weight: bold
white-space: nowrap
text: =items[props.batterylevel].state
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 10) ? true : false'
iconColor: orange
iconF7: battery_25
iconSize: 33px
style:
font-size: 25px
font-weight: bold
white-space: nowrap
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 10 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 75) ? true : false'
iconColor: green
iconF7: battery_100
iconSize: 33px
style:
font-size: 25px
font-weight: bold
white-space: nowrap
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 75) ? true : false'
height: 110px
icon: sma_battery_2
style:
margin-top: -20px
- component: Label
style:
color: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) <= 0) ? "red" : "green"'
font-size: 25px
font-weight: bold
margin-top: -10px
text-align: center
white-space: nowrap
width: 100px
text: =Math.abs(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0])) + ' ᵂ'
visible: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) !== 0) ? true : false'
style:
align-items: center
display: flex
height: 110px
margin-top: 250px
width: 0px
slots:
default:
color: grey
text: DETAIL
outline: true
action: navigate
style:
width: 110px
margin-right: 110px
Matze0211
(Matthias)
6
Your top component is the component: f7-card
element.
You should be able to add the action and actionPage config from the button to this element
alda1
(Alex Needle)
7
like this ?
component: f7-card
action: navigate
class:
- display-flex
style:
height: 383px
slots:
content:
style:
display: flex
padding: 0
slots:
Matze0211
(Matthias)
8
Yes, this should theoretically work.
Theoretically, because I’m traveling and cannot test it by myself.
You can just copy the widget code and save it with a different name /uid (first row), then it’s more easy to test and you will not break something.
Matze0211
(Matthias)
10
Most likely other components are on top of the layer, therefore the f7-card is in the background and technically you click on a different element.
As an easy workaround e.g. you could add the action to all the images, than you can at least click on an icon…
alda1
(Alex Needle)
11
Very good idea. YES, I added action under each oh-icon config and it’s working quite fine.
