You can try Meteoblue https://www.meteoblue.com/pl/pogoda/widget/setupthree/londyn_zjednoczone-królestwo-wielkiej-brytanii_2643743
You can generate widget as you like and put it into template widget.
Hi @zacofunny,
thanks for sharing! Have you a sample json for widget or is the default iframe widget the best solution?
As im new to this material of openhab and habpanel, i have a little trouble of getting it done for my location in Germany.
As for now, im using the weather binding on openHAB 2.2.0~20171211135820-1 (Build #1130).
Files Look like this:
And with this, the Panel looks like this:
As u can see: I already put the icons.jar in the right folder, but the translation doesnt work and i think its not the right temperature.
Do you have any hints for me to get this done?
Best regards,
Chris
Hi.
I create the widget in the HABPanel and the temperature is correctly displayed. But I have some issues with the icons.
Can anyone tell me the correct path for the icons-file in openhab 2.2
I run a RaspberryPi 2 with openhabianpi.
Many thanks in advance.
I jumped to OH2.2 and I need the also the right path to the Icons.
Installing the icons from above links works and leads to a working widget, but this I find in the logs:
017-12-21 09:02:20.492 [ERROR] [org.openhab.ui.iconset.climacons ] - [org.openhab.ui.iconset.climacons(232)] unbind method [removeTranslationProvider] not found; Component will fail
2017-12-21 09:02:20.497 [ERROR] [org.openhab.ui.iconset.climacons ] - [org.openhab.ui.iconset.climacons(232)] unbind method [removeTranslationProvider] not found
OK, I drop the icons.jar in
/usr/share/openhab2/addons
and now the weather icon is showed.
But now my location name is not displayed. What can I do?
Hi
I´m having problems with the display of the temperatures. I get a strange A-character directly efter the temperature. Should be 3 degrees Celsius. I´m using Weather underground binding and the temperature in the Paper UI control panel displays 3.0 degrees.
Solved it, found the A-character in the code, before the degree-character. Deleted it and it´s gone!
Strange why it was there from the beginning?
Where do the .map files go?
The icons are doing this in Chrome now for me. They rotate around the top centre point rather than the middle.
Has anyone else found this and found a solution?
Thanks!
Anyone?
Thanks!
There is a ticket in GitHub with a potential solution. I haven’t tried it yet, but have the same issue.
Thanks, I didn’t see that. I suppose every icon file needs editing separately with the fix (unless someone’s already done it!)
I have the latest openhab2 (1.4.1) on R Pi 3 and most recent iconset (org.openhab.ui.iconset.climacons-2.3.0-SNAPSHOT.jar) in addons. Items defined as in instalation detail and weather.cfg is in place, set to Yahoo and my WOID. Unfortunatelly the widget does not work. Items returns no value. I have nulls only.
Does someone of you experienced similar issue? Mayby this is related to the OH2 1.4.1 release? I thing my configuration is ok.
This has solved my issue:
Where i cac create API key for Wundergorund Widget?
Hi all.
Firstly, great to see so many people helping to get the animated climacons working.
I have them installed and working great. I just need advice to how to change the color of the icons. Can anyone point me somewhere to how to change the code?
Currently using:
<img width="100" style="filter: invert(60%) sepia(100%) hue-rotate(185deg) saturate(1000%);"
src="/icon/climacon?iconset=climacons&format=svg&state={{itemValue('CommonId').replace(' ','-') | lowercase }}" />
Thanks in advance!
map transformation file in turkish
weather_tr.map
thunder=gök gürültüsü
storm=fırtına
rain-and-snow=yağmur ve kar
rain-and-sleet=yağmur ve sulu kar
snow-and-sleet=kar ve sulu kar
freezing-drizzle=donma çiselemesi
few-showers=Sağanak yağmur
freezing-rain=dondurucu yağmur
rain=yağmur
snow-flurries=kar yağışı
light-snow=hafif kar
blowing-snow=Kar fırtınası
snow=Kar
sleet=sulu kar
dust=kum fırtınası
fog=sis
wind=rüzgar
cold=soğuk
cloudy=bulutlu
mostly-cloudy-night=çoğunlukla bulutlu gece
mostly-cloudy-day=çoğunlukla bulutlu gün
partly-cloudy-night=parçalı bulutlu gece
partly-cloudy-day=parçalı bulutlu gün
clear-night=açık gece
sunny=güneşli
hot=sıcak
scattered-thunder=dağınık gök gürültüsü
scattered-showers=dağınık sağanak yağışlar
thundershowers=Ağır fırtınalar
snow-showers=Kar yağışı
scattered-thundershowers=dağınık Ağır fırtınalar
unknown=bilinmeyen
days_tr.map
Monday=Pazartesi
Tuesday=Salı
Wednesday=Çarşamba
Thursday=Perşembe
Friday=Cuma
Saturday=Cumartesi
Sunday=Pazar
pressure_tr.map
up=artar
down=azalır
equal=değişiklik yok
season_tr.map
Spring=Bahar
Summmer=Yaz
Autumn=Sonbahar
Winter=Kış
-=veri yok
tr.map
CLOSED=kapalı
OPEN=açık
undefined=tanımsız
-=veri yok
NULL=veri yok
humidex_tr.scale
-=veri yok
[-40,20]=ilgisiz
[20,29]=rahat
[29,38]=hafif rahatsızlık
[38,45]=çabadan kaçın
[45,54]=tehlikeli
[54,100]=sıcak çarpması riski
