Hi Yannick,
Many thanks for this great work! For beginners it’s really not easy to let it run, but now it works fine:
I have a question to the colors: Is it possible to change it? For example yellow to blue?
Hi Yannick,
Hi, sorry for the delay, I just happen to find this in a suggested topics list.
IIRC I made a “clone widget” feature in HABPanel’s custom widgets list (in the original gauge widget tile’s context menu) which will copy it to a regular custom widget that you can edit. Then you should find hardcoded values for the colors in the code.
Hi Yannick,
Many thanks for your reply. I’ve cloned the widget as you described. But I’ve only see this code without hard coded colors:
Revisiting this code it appears the default colors are defined here, in the directive’s JS file:
What you can do, to keep things simple, is save the file above (click on the Raw button on GitHub) in the html folder of your configuration (maybe in a gauge subfolder), modify it as you see fit, then modify the code of the widget in HABPanel changing
oc-lazy-load="['/habpanel-resources/gauge/gauge.directive.js']" to
oc-lazy-load="['/static/gauge/gauge.directive.js']"
Hi Yannick,
Many thanks for your reply. I’ll try it next weekend!
Kind regards
Henry
Hi Yannick,
I’ve tyed it as you described in this path:
And change it in the widget-clone too:
But with no effect.
It would be great, if you give me a solution for this!
Best regards
Henry
Looks ok, what do you mean by “no effect”?
Did you change the source? Try adding console.log('hello') somewhere to confirm the right file is being loaded, check the console in the developers tools of your browser.
I hope, I’ve understood ![]()
Yep, you can confirm that by going to the Sources tab in the devtools window and check whether gauge.directive.js is loaded from habpanel-resources/gauge (the original location, wrong) or static/gauge. In the former case you might be using the original widget and not the one you cloned.
Thanks for this widget, it is really useful! Just a quick note on changing the colours, there appears to be a typo in what you’ve proposed to change the HABPanel settings to. Instead of
it should be
oc-lazy-load=\"['/static/gauge/gauge.directive.js']\"
You need a leading backslash \ after the first = sign, and a trailing one between ] and "
This worked for me and now I have the blue colour I needed. I think this error was introduced as a result of not using code fences as this happened to my original reply.
Hey @ysc Yannik, any chance of getting this to work with OH3? I use it to show energy usage and it’s really good; just migrating to OH3 and it doesn’t work ![]()
