is it possible to put controls like an oh-toggle into the header of a widget?
currently it looks like this:
but id like to move the toggle into the header, to save space and make it look cleaner. is this possible? thats my code so far:
uid: raumLicht
tags: []
props:
parameters:
- description: Raum Name
label: Raum Name
required: false
type: TEXT
- description: Raum der zu steuern ist
label: Raum Gruppe
required: false
type: TEXT
- description: Raum Booster der zu steuern ist
label: Raum Boost Item
required: false
type: TEXT
parameterGroups: []
timestamp: Jan 22, 2021, 12:01:14 PM
component: f7-card
title: '=(props.raumName) ? "Licht " + props.raumName : "Set props to test!"'
slots:
default:
- component: f7-card-content
slots:
default:
- component: f7-row
class:
- margin
slots:
default:
- component: Label
text: Licht
- component: oh-toggle
item: =props.raumGruppe
- component: f7-block
class:
- segmented
slots:
default:
- component: oh-button
active: =(items[props.raumBoost].state === "ON")
text: Boost
action: command
actionItem: =(props.raumBoost)
actionCommand: ON
large: true
raised: true
class:
- margin
active: =(items[props.raumBoost].state === "OFF")
text: Automatik
action: command
actionCommand: OFF
large: true
raised: true
class:
- margin
thanks a lot!
