props is not an item object where you can just call the item’s properties. props is an object that contains only the keys you’ve defined in the widget. In this case, props.item just contains text that is the item name.
You’ve stumbled across an issue that had been troubling users since the introduction of the custom widget feature. By just having the item name it is not actually very easy to get the item label (the human readable identifying text). This is why, is you look at many of the widget examples in the forum they will have an item property and a separate label property defined at the top of the widget.
Nope. In any oh component, the item property is just a string of the item name. If you hunt around a little more you’ll find many examples where you can see this because theitem property is built up from a string concatenation excursion.
Further access to the item’s relevant properties for component function is achieved by the underlying code that supports the widgets.
The one exception to all of this is if you are using an oh-repeater in one of the forms that returns an array of items. In that case the loop variable contains an object with all the information about the item returned by the items api.
Sure. Your first post looks close. I suspect there are really only a few tweaks needed.
This line, as I outlined up above, returns nothing because the props object doesn’t have a title property as you haven’t declared one in the properties section. There are two easy solutions here:
Change props.title to props.item. The title on your card will then be the name (e.g., Strom_Haus_Verbrauch from your example). This isn’t very pretty but it is a very easy.
Add a title property to the widget as well. That will look something like:
parameters:
- context: item
description: Main toggle item (use for single toggle or as main switch for group)
label: Item
required: false
type: TEXT
- context: text
description: Pretty card label
label: Title
required: false
default: You forgot to set a card title
type: TEXT
This goes back to what we’ve been discussion up above. Once you open up the settings dialog for the widget and select an item from the list for this property, props.item equals the name of the item you selected. Nothing less and nothing more. In this case, that’s all you want: the name of the item because that’s the what this item property of the dataseries expects (if you check out the doc file on the oh-aggregate-series you see just says TEXT for this property). So short answer is that all you need is:
item: =props.item
The long answer is: the brackets that you had around that come from a different syntax. The one piece of information about all OH items that is available in the widgets is the current state of the item (and associated formatted version of the state, if that exists). These are held in the items object. In the items object there is a key for every Item name. That means that if you want to get the state of your Strom_Haus_Verbrauch item you would use items.Strom_Haus_Verbrauch.state. But, that’s hard coded and sometimes you want the widget to be able to get the state of a variable item (for example, whatever item has been put into the props.item value. To get a variable key from an object in this syntax you use the brackets. So, the form items[props.item].state says “evaluate props.item and use that string (which should hold the name of an item) to look in the items object for the state of that item”.
This becomes extremely useful when buildin more complicted widgets because associated items often have names that are built around the same root. For example, in a thermostat you might have an item for the current temperature FirstFloorTherm_Current and an item that holds the set temperature to heat to FirstFloorTherm_HeatSet. Now with just one piece of information (the base name of the thermostat item) you can build the item name for all the associated items easily in the same widget. To get the current temp you would use:
Ah, I guess with the title there was a missunderstandig. I have no problem with the title.
The only issue was the Item which is not used.
I now use this:
item: =props.item
But it is not working.
This is my whole widget:
uid: strom_balkendiagramm_Stunde
tags: []
props:
parameters:
- context: item
label: Item
required: false
type: TEXT
- context: text
label: Title
required: false
type: TEXT
parameterGroups: []
timestamp: Feb 1, 2022, 5:39:12 PM
component: f7-card
title: =props.title
class:
- padding-bottom
slots:
default:
- component: f7-row
class:
- margin-top
slots:
default:
- component: f7-col
width: 75
slots:
default:
- component: oh-chart
chartType: day
label: "Strom"
slots:
grid:
- component: oh-chart-grid
containLabel: false
xAxis:
- component: oh-category-axis
gridIndex: 0
categoryType: day
weekdayFormat: default
monthFormat: default
yAxis:
- component: oh-value-axis
gridIndex: 0
series:
- component: oh-aggregate-series
gridIndex: 0
xAxisIndex: 0
yAxisIndex: 0
type: bar
item: =props.item
dimension1: hour
tooltip:
- component: oh-chart-tooltip
confine: true
smartFormatter: true
legend:
- component: oh-chart-legend
bottom: 3
type: scroll
dataZoom:
- component: oh-chart-datazoom
type: inside
That’s interesting, that’s now entirely the correct form. Previously it used to be true that you couldn’t use expressions in the item property of the chart series, but I thought that had been fixed. It turns out, now that I look into it, that it wasn’t fixed for oh-aggregate-series only for some of the other series.
It’s not working because it’s not currently supported. You can file a feature request on github to get the aggregate series’ item field added to the list of properties that accept expressions, if you’d like.
