Hi want to use this radiator widget for my fritzbox radiators. But the binding of the Fritzbox radiators have mor informations Fritzbox Binding
I think i have this information more:
Device is locked for switching manually (OPEN/CLOSE)
Accumulated energy
battery Level ( not only the battery Status)
Its useful to add this function in the Widget?
I have no practise in html. I have chance the modes its easy. But i cant use a normal Button with a left Position under the other functions to change the lock of the radiator.
I dont know if the send command correctly or how i can set the position of the button to an other position as middle.
I get no log line if i push the Button. So i think its wrong?
Great!
But I got an issue with the battery level. in the widget all batterys are shown as “Replace battery” though in ClassicUI and on the device itself the battery level is ok.
Oh, I´m sorry, I wanted to reply to “thisisIO / Michael” question and answer from January 1st 2019.
All works fine (e.g. setting temperature, switching modes etc.) except printing the actual temperature. The widget doesn´t show any readings but part of the code:
{{’%.1f’ | sprintf:itemValue(config.max_temp_actual)}}
“thisisIO / Michael” replied to his answer, that he found a solution:
“I need to make a items without C symbol, only digits -> so it works great.”
I don´t understand what he actually changed in his code or item he created.
No worries, it’s fine. As he solved it, I am afraid there was no further explanation. He was probably putting some “C” in the item to indicate “celsius degrees” and he had to remove it because the “%.1f” means the value should be printed as float (meaning with decimals) and with only one decimal.
If you need further help, just send details: item definition, coding, ect. Maybe I (or anybody else) could help.
All right.
Your code is unchanged, downloaded via Habpanel.
The item, a MAX! thermostat knob, comes through Homegear–>Homematic --> Openhab, because I burned a cul-firmware to my MAX-Cube - it suffered the well known amnesia with the original firmware from time to time, sometimes from one day to the next actually…
I don´t have experience with item definitions via CLI, so PaperUI´s values is all I can deliver at the moment:
As mentioned above, all other actions work well, e.g. setting temperature. PaperUI here gives:
homematic:HG-BC-RT-TRX-CyN:fd475435:OEQ0944087:1#SET_TEMPERATURE
There may be issues with binding method through Homegear/Homematic, but if so I would expect problems with other actions, too.
Your help is very much appreciated and I like your widget very much!
