Hi I try to deal with a custom widget for innogy termostates. So far everything works, but I didn’t get the binding on a widget-slider working. I tried a log but the slider doesn’t bound to the underlaying value.
<div class="slider-div" ng-init='sliderModel={
name: "Ziel Temperatur",
floor : 6,
ceil: 30,
step: 0.5,
horizontal: "true",
showTicks:true,
unit: "°C",
display: none
<widget-slider width="100%" ng-model="sliderModel" value="{{itemValue(config.desired_temperature)}}" item="{{itemValue(config.desired_temperature)}}" />
</div>
I have tried to bind it inside the model as well, nothing worked so far. Can anybody help me what I am doing wrong?
The setting which I want to bind is named desired_temperature.
