Nevertheless the cyrus sensor returns status “ON” - the Fibaro sensor returns status “OPEN”.
So basically I want to filter for both values - but need some help with the syntax
I’m not sure what the device is you have, but maybe the zwave database needs updating to use the correct type for a contact? Do you have the database reference?
This is contained in the XML file of the node in my openHAB-userdata\zwave folder.
Does this help? Otherwise - how can I find out the database reference?
I updated my ZWave Binding to the latest snapshot.
What is now the correct way to update my already existing Things? Delete
from Controller and then re-add, or re-initalize? Or is there another way?
