I just got a D-Link DCH-S150 WIFI motion sensor and try to use it in OH2 (2.2.0 Snapshot 1003). The thing was discovered by PaperUI und I tried to define rules and items. Unfortunately the documentation has no example for item files???
I then tried to a establish a rule as described in the docs:
//Rule DLINK
Channel "dlinksmarthome:DCH-S150:b3f631e1:motion" triggered
logInfo("DLINK","Motion has been detected by rule!")
postUpdate(MO_BUER_LCH, new DateTimeType())
However, neither the log is showing the entry from my rule nor the item gets the date/timestamp update so the rule does not seem to fire.
BUT: In the event log I see that the thing is sending data to OH2:
oh yes… my mistake. Now it works. Thank you very much for the quick help!
Apparently items are not supported for trigger channels…I do not understand fully why something like a trigger channel is needed but at least it works now…
Compared to my Zwave motion sensor devices the functionality and configuration options for D-Link are very poor. Just trigger a signal - that’s all. No configuration options for timing, sensitivity etc. No additional functions like measuring temperature, brightness, humidity or whatever. Not even a regular communication with OH (polling) so one could check by rules if the device is still ok…but ok, it was worth a try to see the difference.
Hi @MikeJMajor, I m new with openhab and trigger channels, i get it that trigger channels dont work with items, but im trying to work this channel with the openhab rest api, where the status info of the motion sensor should be reflected, i cant find any solution for this, could you suggest some?
