I am trying to configure the Z-Wave siren DCH-Z510. This should be really easy as explained in the manual:
Using the SWITCH_BINARY_SET to play the siren, 0xFF will play the emergency sound, 0x00 will stop to play.
So i tried the following real simple configuration:
Switch SIREN {zwave=“4:command=SWITCH_BINARY”}
The device is correctly identified in HABmin, i’m using the latest zwave binding snapshot.
My problem is, setting the SWITCH to ON activates the emergency sound but setting it to OFF does nothing. I have to wait for three minutes or disconnecting it’s power source.
Anyone else using this siren can help me?
The Hardware should be identical to the Zipato PSE02 and Philio PSE02.
The DEBUG Output switching ON and OFF:
2016-07-24 16:46:11.046 [DEBUG] [.ZWaveBinarySwitchCommandClass:146 ]- NODE 4: Creating new message for application command SWITCH_BINARY_SET
2016-07-24 16:46:11.047 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ]- NODE 4: Creating empty message of class = SendData (0x13), type = Request (0x00)
2016-07-24 16:46:11.048 [DEBUG] [b.z.i.protocol.ZWaveController:938 ]- Callback ID = 19
2016-07-24 16:46:11.050 [DEBUG] [b.z.i.protocol.ZWaveController:620 ]- Enqueueing message. Queue length = 1
2016-07-24 16:46:11.050 [DEBUG] [WaveController$ZWaveSendThread:1211]- Took message from queue for sending. Queue length = 0
2016-07-24 16:46:11.052 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 0A 00 13 04 03 25 01 FF 25 13 0C
2016-07-24 16:46:11.054 [DEBUG] [WaveController$ZWaveSendThread:1268]- NODE 4: Sending REQUEST Message = 01 0A 00 13 04 03 25 01 FF 25 13 0C
2016-07-24 16:46:11.064 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 04 01 13 01 E8
2016-07-24 16:46:11.066 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2016-07-24 16:46:11.067 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2016-07-24 16:46:11.069 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 04 01 13 01 E8
2016-07-24 16:46:11.070 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 04 01 13 01 E8
2016-07-24 16:46:11.071 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = SendData (0x13), type = Response (0x01), payload = 01
2016-07-24 16:46:11.072 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ]- NODE 4: Sent Data successfully placed on stack.
2016-07-24 16:46:11.080 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 07 00 13 13 00 00 02 FA
2016-07-24 16:46:11.083 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2016-07-24 16:46:11.084 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2016-07-24 16:46:11.085 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 13 13 00 00 02 00 00 F4
2016-07-24 16:46:11.087 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 09 00 13 13 00 00 02 00 00 F4
2016-07-24 16:46:11.088 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = SendData (0x13), type = Request (0x00), payload = 13 00 00 02
2016-07-24 16:46:11.089 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ]- NODE 4: SendData Request. CallBack ID = 19, Status = Transmission complete and ACK received(0)
2016-07-24 16:46:11.090 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ]- Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 04 03 25 01 FF
2016-07-24 16:46:11.092 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ]- Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 13 00 00 02
2016-07-24 16:46:11.092 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ]- Checking transaction complete: class=SendData, expected=SendData, cancelled=false
2016-07-24 16:46:11.093 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ]- transaction complete!
2016-07-24 16:46:11.094 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveTransactionCompletedEvent
2016-07-24 16:46:11.095 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2016-07-24 16:46:11.096 [DEBUG] [WaveController$ZWaveSendThread:1327]- NODE 4: Response processed after 41ms/4879ms.
2016-07-24 16:46:16.741 [DEBUG] [.ZWaveBinarySwitchCommandClass:146 ]- NODE 4: Creating new message for application command SWITCH_BINARY_SET
2016-07-24 16:46:16.742 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ]- NODE 4: Creating empty message of class = SendData (0x13), type = Request (0x00)
2016-07-24 16:46:16.743 [DEBUG] [b.z.i.protocol.ZWaveController:938 ]- Callback ID = 20
2016-07-24 16:46:16.744 [DEBUG] [b.z.i.protocol.ZWaveController:620 ]- Enqueueing message. Queue length = 1
2016-07-24 16:46:16.745 [DEBUG] [WaveController$ZWaveSendThread:1211]- Took message from queue for sending. Queue length = 0
2016-07-24 16:46:16.747 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 0A 00 13 04 03 25 01 00 25 14 F4
2016-07-24 16:46:16.749 [DEBUG] [WaveController$ZWaveSendThread:1268]- NODE 4: Sending REQUEST Message = 01 0A 00 13 04 03 25 01 00 25 14 F4
2016-07-24 16:46:16.770 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 04 01 13 01 E8
2016-07-24 16:46:16.772 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2016-07-24 16:46:16.773 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2016-07-24 16:46:16.774 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 04 01 13 01 E8
2016-07-24 16:46:16.775 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 04 01 13 01 E8
2016-07-24 16:46:16.776 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = SendData (0x13), type = Response (0x01), payload = 01
2016-07-24 16:46:16.777 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ]- NODE 4: Sent Data successfully placed on stack.
2016-07-24 16:46:16.787 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 07 00 13 14 00 00 02 FD
2016-07-24 16:46:16.789 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2016-07-24 16:46:16.790 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2016-07-24 16:46:16.791 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 13 14 00 00 02 00 00 F3
2016-07-24 16:46:16.792 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 09 00 13 14 00 00 02 00 00 F3
2016-07-24 16:46:16.794 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = SendData (0x13), type = Request (0x00), payload = 14 00 00 02
2016-07-24 16:46:16.794 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ]- NODE 4: SendData Request. CallBack ID = 20, Status = Transmission complete and ACK received(0)
2016-07-24 16:46:16.796 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ]- Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 04 03 25 01 00
2016-07-24 16:46:16.797 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ]- Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 14 00 00 02
2016-07-24 16:46:16.798 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ]- Checking transaction complete: class=SendData, expected=SendData, cancelled=false
2016-07-24 16:46:16.799 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ]- transaction complete!
2016-07-24 16:46:16.800 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveTransactionCompletedEvent
2016-07-24 16:46:16.801 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2016-07-24 16:46:16.802 [DEBUG] [WaveController$ZWaveSendThread:1327]- NODE 4: Response processed after 41ms/4879ms.
