Yes this seems to be broken in 2.5. Turning on DEBUG logging gives the following error:
2019-11-18 11:00:51.171 [DEBUG] [home.internal.DLinkHNAPCommunication] - DLinkHNAPCommunication - Internal error
javax.xml.soap.SOAPException: Unable to create message factory for SOAP: Unable to create SAAJ meta-factory: com.sun.xml.internal.messaging.saaj.soap.SAAJMetaFactoryImpl cannot be cast to javax.xml.soap.SAAJMetaFactory
at javax.xml.soap.MessageFactory.newInstance(MessageFactory.java:120) ~[bundleFile:1.4.0]
at org.openhab.binding.dlinksmarthome.internal.DLinkHNAPCommunication.<init>(DLinkHNAPCommunication.java:160) [bundleFile:?]
at org.openhab.binding.dlinksmarthome.internal.motionsensor.DLinkMotionSensorCommunication.<init>(DLinkMotionSensorCommunication.java:154) [bundleFile:?]
I suspect this is as a result of the new build system. @J-N-K do you have any ideas about this problem?
@J-N-K have you had chance to take a look at this.
I’m assuming there’s some kind of clash with the saaj-impl 1.5.1 library which is a bundle dependency and the one in java 8, but I’ve no idea how to resolve it.
