EDIT: updated the item config as snmp walking showed not OID’s to be correct
- Platform information:
- Hardware:Raspberry pi 3 B+
- OS: Rasbian
- Java Runtime Environment: 1.8.0_65
- openHAB version:2.2.0-1
- Issue of the topic: I am attempting to setup DAEnetIP1 binding to openhab using SNMPv1.
I have found some examples of how this “should” be done even an example config provided by the manufacturer but no one seems to have published their implementation actually working.
What I would like to so is create things that are bound to the inputs or outputs of the DAEnetIP1 board (this should need just a little config change to also work for the DAEnetIP4 since only the OID’s are diffrent). So openhab can use those things to do clever stuff.
The boars have 8 digital and 8 analogue inputs as well as 12 digital (relay) outputs. They may have various sensors or devices connected to them so and abstaction to “thing” would be rather usefull here.
But I cannot seem to get openhab to read or write to the board.
Does any one here have a working openhab implementation of the DAEnetIP1(or 4) boards?
What can I do trouble shoot this binding?
- Please post configurations (if applicable):
- Items configuration related to the issue
String DO1Name "DO1Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.4.1:1000]"}
String DO2Name "DO2Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.4.2:1000]"}
String DO3Name "DO3Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.4.3:1000]"}
String DO4Name "DO4Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.4.4:1000]"}
String DO5Name "DO5Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.4.5:1000]"}
String DO6Name "DO6Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.4.6:1000]"}
String DO7Name "DO7Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.4.7:1000]"}
String DO8Name "DO8Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.4.8:1000]"}
String DO9Name "DO9Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.4.1:1000]"}
String DO10Name "DO10Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.4.2:1000]"}
String DO11Name "DO11Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.4.3:1000]"}
String DO12Name "DO12Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.4.4:1000]"}
Switch DO1 "DO1" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.1:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.1:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.1:1]"}
Switch DO2 "DO2" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.2:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.2:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.2:1]"}
Switch DO3 "DO3" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.3:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.3:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.3:1]"}
Switch DO4 "DO4" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.4:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.4:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.4:1]"}
Switch DO5 "DO5" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.5:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.5:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.5:1]"}
Switch DO6 "DO6" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.6:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.6:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.6:1]"}
Switch DO7 "DO7" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.7:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.7:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.7:1]"}
Switch DO8 "DO8" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.8:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.8:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.1.2.8:1]"}
Switch DO9 "DO9" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.1:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.1:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.1:1]"}
Switch DO10 "DO10" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.2:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.2:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.2:1]"}
Switch DO11 "DO11" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.3:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.3:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.3:1]"}
Switch DO12 "DO12" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.4:1000] >[OFF:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.4:0] >[ON:172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.4.2.4:1]"}
String AI1Name "AI1Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.7.1:1000]"}
String AI2Name "AI2Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.7.2:1000]"}
String AI3Name "AI3Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.7.3:1000]"}
String AI4Name "AI4Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.7.4:1000]"}
String AI5Name "AI5Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.7.5:1000]"}
String AI6Name "AI6Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.7.6:1000]"}
String AI7Name "AI7Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.7.7:1000]"}
String AI8Name "AI8Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.7.8:1000]"}
Number AI1 "AI1" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.1.1:1000]"}
Number AI2 "AI2" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.1.2:1000]"}
Number AI3 "AI3" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.1.3:1000]"}
Number AI4 "AI4" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.1.4:1000]"}
Number AI5 "AI5" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.1.5:1000]"}
Number AI6 "AI6" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.1.6:1000]"}
Number AI7 "AI7" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.1.7:1000]"}
Number AI8 "AI8" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.5.1.8:1000]"}
String DI1Name "DI1Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.4.1:1000]"}
String DI2Name "DI2Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.4.2:1000]"}
String DI3Name "DI3Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.4.3:1000]"}
String DI4Name "DI4Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.4.4:1000]"}
String DI5Name "DI5Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.4.5:1000]"}
String DI6Name "DI6Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.4.6:1000]"}
String DI7Name "DI7Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.4.7:1000]"}
String DI8Name "DI8Name" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.4.8:1000]"}
Number DI1 "DI1" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.5.1:1000]"}
Number DI2 "DI2" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.5.2:1000]"}
Number DI3 "DI3" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.5.3:1000]"}
Number DI4 "DI4" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.5.4:1000]"}
Number DI5 "DI5" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.5.5:1000]"}
Number DI6 "DI6" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.5.6:1000]"}
Number DI7 "DI7" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.5.7:1000]"}
Number DI8 "DI8" {snmp="<[172.16.0.122/7171:private:.1.3.6.1.4.1.32111.1.6.5.8:1000]"}
- Sitemap configuration related to the issue
sitemap daenetip4 label="DAEnet IP4 SNMP" {
Frame label="Digital Output 1" {
Text item=DO1Name label="Name: [%s]"
Switch item=DO1 label="State" icon="light"
Frame label="Digital Output 2" {
Text item=DO2Name label="Name: [%s]"
Switch item=DO2 label="State" icon="light"
Frame label="Digital Output 3" {
Text item=DO3Name label="Name: [%s]"
Switch item=DO3 label="State" icon="light"
Frame label="Digital Output 4" {
Text item=DO4Name label="Name: [%s]"
Switch item=DO4 label="State" icon="light"
Frame label="Digital Output 5" {
Text item=DO5Name label="Name: [%s]"
Switch item=DO5 label="State" icon="light"
Frame label="Digital Output 6" {
Text item=DO6Name label="Name: [%s]"
Switch item=DO6 label="State" icon="light"
Frame label="Digital Output 7" {
Text item=DO7Name label="Name: [%s]"
Switch item=DO7 label="State" icon="light"
Frame label="Digital Output 8" {
Text item=DO8Name label="Name: [%s]"
Switch item=DO8 label="State" icon="light"
Frame label="Digital Output 9" {
Text item=DO9Name label="Name: [%s]"
Switch item=DO9 label="State" icon="light"
Frame label="Digital Output 10" {
Text item=DO10Name label="Name: [%s]"
Switch item=DO10 label="State" icon="light"
Frame label="Digital Output 11" {
Text item=DO11Name label="Name: [%s]"
Switch item=DO11 label="State" icon="light"
Frame label="Digital Output 12" {
Text item=DO12Name label="Name: [%s]"
Switch item=DO12 label="State" icon="light"
Frame label="Digital Input 1" {
Text item=DI1Name label="Name: [%s]"
Text item=DI1 label="State: [%s]" icon="light"
Frame label="Digital Input 2" {
Text item=DI2Name label="Name: [%s]"
Text item=DI2 label="State: [%s]" icon="light"
Frame label="Digital Input 3" {
Text item=DI3Name label="Name: [%s]"
Text item=DI3 label="State: [%s]" icon="light"
Frame label="Digital Input 4" {
Text item=DI4Name label="Name: [%s]"
Text item=DI4 label="State: [%s]" icon="light"
Frame label="Digital Input 5" {
Text item=DI5Name label="Name: [%s]"
Text item=DI5 label="State: [%s]" icon="light"
Frame label="Digital Input 6" {
Text item=DI6Name label="Name: [%s]"
Text item=DI6 label="State: [%s]" icon="light"
Frame label="Digital Input 7" {
Text item=DI7Name label="Name: [%s]"
Text item=DI7 label="State: [%s]" icon="light"
Frame label="Digital Input 8" {
Text item=DI8Name label="Name: [%s]"
Text item=DI8 label="State: [%s]" icon="light"
Frame label="Analog Input 1" {
Text item=AI1Name label="Name: [%s]"
Text item=AI1 label="Value: [%s]"
Frame label="Analog Input 2" {
Text item=AI2Name label="Name: [%s]"
Text item=AI2 label="Value: [%s]"
Frame label="Analog Input 3" {
Text item=AI3Name label="Name: [%s]"
Text item=AI3 label="Value: [%s]"
Frame label="Analog Input 4" {
Text item=AI4Name label="Name: [%s]"
Text item=AI4 label="Value: [%s]"
Frame label="Analog Input 5" {
Text item=AI5Name label="Name: [%s]"
Text item=AI5 label="Value: [%s]"
Frame label="Analog Input 6" {
Text item=AI6Name label="Name: [%s]"
Text item=AI6 label="Value: [%s]"
Frame label="Analog Input 7" {
Text item=AI7Name label="Name: [%s]"
Text item=AI7 label="Value: [%s]"
Frame label="Analog Input 8" {
Text item=AI8Name label="Name: [%s]"
Text item=AI8 label="Value: [%s]"
- Rules code related to the issue
// Imports
rule "DIState"
Item DI received update
if((DI.state as DecimalType).intValue.bitwiseAnd(0x01)==0x01) DI1.postUpdate("ON") else DI1.postUpdate("OFF")
if((DI.state as DecimalType).intValue.bitwiseAnd(0x02)==0x02) DI2.postUpdate("ON") else DI2.postUpdate("OFF")
if((DI.state as DecimalType).intValue.bitwiseAnd(0x04)==0x04) DI3.postUpdate("ON") else DI3.postUpdate("OFF")
if((DI.state as DecimalType).intValue.bitwiseAnd(0x08)==0x08) DI4.postUpdate("ON") else DI4.postUpdate("OFF")
if((DI.state as DecimalType).intValue.bitwiseAnd(0x10)==0x10) DI5.postUpdate("ON") else DI5.postUpdate("OFF")
if((DI.state as DecimalType).intValue.bitwiseAnd(0x20)==0x20) DI6.postUpdate("ON") else DI6.postUpdate("OFF")
if((DI.state as DecimalType).intValue.bitwiseAnd(0x40)==0x40) DI7.postUpdate("ON") else DI7.postUpdate("OFF")
if((DI.state as DecimalType).intValue.bitwiseAnd(0x80)==0x80) DI8.postUpdate("ON") else DI8.postUpdate("OFF")
rule "AIState"
Item AI received update
if((AI.state as DecimalType).intValue.bitwiseAnd(0x01)==0x01) AI1.postUpdate("ON") else AI1.postUpdate("OFF")
if((AI.state as DecimalType).intValue.bitwiseAnd(0x02)==0x02) AI2.postUpdate("ON") else AI2.postUpdate("OFF")
if((AI.state as DecimalType).intValue.bitwiseAnd(0x04)==0x04) AI3.postUpdate("ON") else AI3.postUpdate("OFF")
if((AI.state as DecimalType).intValue.bitwiseAnd(0x08)==0x08) AI4.postUpdate("ON") else AI4.postUpdate("OFF")
if((AI.state as DecimalType).intValue.bitwiseAnd(0x10)==0x10) AI5.postUpdate("ON") else AI5.postUpdate("OFF")
if((AI.state as DecimalType).intValue.bitwiseAnd(0x20)==0x20) AI6.postUpdate("ON") else AI6.postUpdate("OFF")
if((AI.state as DecimalType).intValue.bitwiseAnd(0x40)==0x40) AI7.postUpdate("ON") else AI7.postUpdate("OFF")
if((AI.state as DecimalType).intValue.bitwiseAnd(0x80)==0x80) AI8.postUpdate("ON") else AI8.postUpdate("OFF")
rule "DOState"
Item DO received update
logInfo("DO received update","DO received update")
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0001)==0x0001) DO1.postUpdate(ON) else DO1.postUpdate(OFF)
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0002)==0x0002) DO2.postUpdate(ON) else DO2.postUpdate(OFF)
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0004)==0x0004) DO3.postUpdate(ON) else DO3.postUpdate(OFF)
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0008)==0x0008) DO4.postUpdate(ON) else DO4.postUpdate(OFF)
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0010)==0x0010) DO5.postUpdate(ON) else DO5.postUpdate(OFF)
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0020)==0x0020) DO6.postUpdate(ON) else DO6.postUpdate(OFF)
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0040)==0x0040) DO7.postUpdate(ON) else DO7.postUpdate(OFF)
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0080)==0x0080) DO8.postUpdate(ON) else DO8.postUpdate(OFF)
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0100)==0x0100) DO9.postUpdate(ON) else DO9.postUpdate(OFF)
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0200)==0x0200) DO10.postUpdate(ON) else DO10.postUpdate(OFF)
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0200)==0x0400) DO11.postUpdate(ON) else DO11.postUpdate(OFF)
if((DO.state as DecimalType).intValue.bitwiseAnd(0x0200)==0x0800) DO12.postUpdate(ON) else DO12.postUpdate(OFF)
- Services configuration related to the issue
# Listening Port (optional, defaults to '162')
port=1620
# The SNMP community to listen to (optional, defaults to 'public')
community=glados
# The SNMP retry timeout (in milliseconds). Defaults to 1500.
# Sets the number of milliseconds between retries.
timeout=2000
# The SNMP number of retries. Defaults to 0.
# Sets the number of retries before aborting the request.
retries=3
- If logs where generated please post these here using code fences:
2018-04-16 17:33:20.257 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://172.16.0.73:8080
2018-04-16 17:33:20.343 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://172.16.0.73:8443
2018-04-16 17:33:26.665 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'daenetip4.items'
2018-04-16 17:33:35.082 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'daenetip4.rules'
2018-04-16 17:33:35.361 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-04-16 17:33:35.881 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'daenetip4.sitemap'
2018-04-16 17:33:38.510 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-04-16 17:33:38.871 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-04-16 17:33:38.938 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-04-16 17:33:39.044 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-04-16 17:33:39.209 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-04-16 17:33:39.444 [INFO ] [b.core.service.AbstractActiveService] - SNMP Refresh Service has been started
2018-04-16 17:33:39.469 [WARN ] [ence.jdbc.internal.JdbcConfiguration] - JDBC url is missing - please configure in openhab.cfg like 'jdbc:<service>:<host>[:<port>;<attributes>]'
2018-04-16 17:33:39.472 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2018-04-16 17:33:39.474 [WARN ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: no driver available!
2018-04-16 17:35:46.327 [WARN ] [org.eclipse.jetty.http.HttpParser ] - Illegal character 0x16 in state=START for buffer HeapByteBuffer@127e68[p=1,l=517,c=8192,r=516]={\x16<<<\x03\x01\x02\x00\x01\x00\x01\xFc\x03\x03\xEfI&'4\xA7F...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00>>>cebe654bb39\r\nIf-N...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
2018-04-16 17:35:46.333 [WARN ] [org.eclipse.jetty.http.HttpParser ] - bad HTTP parsed: 400 Illegal character 0x16 for HttpChannelOverHttp@c9e166{r=0,c=false,a=IDLE,uri=null}
2018-04-16 17:35:46.332 [WARN ] [org.eclipse.jetty.http.HttpParser ] - Illegal character 0x16 in state=START for buffer HeapByteBuffer@1c2d022[p=1,l=517,c=8192,r=516]={\x16<<<\x03\x01\x02\x00\x01\x00\x01\xFc\x03\x03\x18\x0f\xB7\x9b\x84\x06\x9a...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
2018-04-16 17:35:46.336 [WARN ] [org.eclipse.jetty.http.HttpParser ] - bad HTTP parsed: 400 Illegal character 0x16 for HttpChannelOverHttp@ffc440{r=0,c=false,a=IDLE,uri=null}
2018-04-16 17:35:46.343 [WARN ] [org.eclipse.jetty.http.HttpParser ] - Illegal character 0x16 in state=START for buffer HeapByteBuffer@1c2d022[p=1,l=179,c=8192,r=178]={\x16<<<\x03\x01\x00\xAe\x01\x00\x00\xAa\x03\x03\x04\xCa3\x13\x15Y\xE3...\x00\x08\xCa\xCa\x00\x1d\x00\x17\x00\x18\x1a\x1a\x00\x01\x00>>>\x08http/1.1uP\x00\x00\x00\x0b\x00\x02...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
2018-04-16 17:35:46.347 [WARN ] [org.eclipse.jetty.http.HttpParser ] - bad HTTP parsed: 400 Illegal character 0x16 for HttpChannelOverHttp@1970cf7{r=0,c=false,a=IDLE,uri=null}
2018-04-16 17:35:46.354 [WARN ] [org.eclipse.jetty.http.HttpParser ] - Illegal character 0x16 in state=START for buffer HeapByteBuffer@1c2d022[p=1,l=179,c=8192,r=178]={\x16<<<\x03\x01\x00\xAe\x01\x00\x00\xAa\x03\x03\xCf\xAc\xBb\xF3D\x1bR...\x00\x08\xAa\xAa\x00\x1d\x00\x17\x00\x18\xFa\xFa\x00\x01\x00>>>\x08http/1.1uP\x00\x00\x00\x0b\x00\x02...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
2018-04-16 17:35:46.357 [WARN ] [org.eclipse.jetty.http.HttpParser ] - bad HTTP parsed: 400 Illegal character 0x16 for HttpChannelOverHttp@1083387{r=0,c=false,a=IDLE,uri=null}
