Hi, is Daikin FTXM supported by OH?
It it has a KKRP01A or BRP072A42 : probably yes:
Yes I know. What i don’t know is if Daikin FTXM have BRP072A42 and if other controller (not documented) are working.
Thanks. And it works without issues?
Yes, i only tested a little since it came out in march and I stil not have used AC yet. The test was fine
I use the Opendaikin Binding with the adapter BRP069A41.
All works fine, except the setpoint.
I can see the actual set temperature but when i try to go up/down nothing happens.
Not much information provided to help, please check your syntax:
https://www.openhab.org/docs/configuration/sitemaps.html#element-type-setpoint
I solved the issue
At begin in Sitemap i used the syntax from the binding instructions
Setpoint item=Daikin_sz_SetPoint visibility=[Daikin_wz_Power==ON] label=“Soll-Temperatur” icon=“temperature_cold”
Now i modify like this an all drive perfect
Setpoint item=Daikin_sz_SetPoint visibility=[Daikin_wz_Power==ON] label=“Soll-Temperatur [%.1f °C]” icon=“temperature_cold” minValue=19 maxValue=26 step=1.0
@sihui Thank you so much for the fast help!
