Hi uwe,
did you follow the instructions found here https://github.com/adr001db/openhab-addons/releases/download/onecta.4.1.3-OIDC-1/Manual.to.get.the.Onecta.Binding.to.work.pdf
Hi uwe,
Hello Paul, thank you very much. That was exactly what I needed to get it done !!! Just one comment for other users who, like me, don’t do this every day: In the Thing configuration fields, you need to enter the email address and password of your Daikin account, NOT the newly assigned Daikin ID. In hindsight, it seems obvious, but I completely messed up on this during setup and kept looking for the problem elsewhere. Thanks again!
Hi Alexander,
first of all, thank you for creating and maintaining this binding. I have successfully connected my Daikin Altherma 3 heat pump using the latest openHAB 5.0.1 version and the current Onecta binding.
I found what looks like a bug related to ON/OFF control of the heating zone.
openHAB 5.0.1
Onecta Binding 5.0.0.202510111234
Daikin Altherma 3
Outdoor unit: ERGA06EAV3
Indoor unit: EHVH08S18EJ6V
Gateway: BRP069A78
Reading all values works correctly.
State changes made in the Onecta app are immediately reflected in openHAB.
Writing some parameters works correctly.
For example, changing the Leaving Water Offset Setpoint from openHAB is immediately visible in the Onecta app.
Sending:
Daikin_Onecta_climateControl_Pompa_ciepla_Power ON
or
Daikin_Onecta_climateControl_Pompa_ciepla_Power OFF
does not change the heat pump state.
The binding sends:
Request:
Body:
{“value”:“on”}
Response:
{“code”:“MANAGEMENT_POINT_MISSING”,“message”:“Could not find management point”}
The raw API data for my unit contains:
embeddedId = climateControlMainZone
managementPointType = climateControl
and:
onOffMode.settable = true
Therefore it looks like the API supports writing the ON/OFF state, but perhaps the binding uses “climateControl” instead of the actual management point identifier “climateControlMainZone” when sending commands.
This would explain why:
reading works,
onOffMode is reported as settable,
API returns MANAGEMENT_POINT_MISSING during write operations.
I have also opened a GitHub issue with logs and details:
Could you please have a look and tell me if this theory makes sense?
Thanks again for all your work on the binding.
Hello JackyKNX,
I have exactly the same problem as you—have you been able to find a solution?
Thank you in advance.
Best regards
Hi, i will look into this
1,5 week ago I created a test fix and I thought I had informed you about that as well. But I think something went wrong there. ![]()
I hope this resolves the issue with the OnOff function. Would you be willing to test this for me? I don’t have a heat pump connected to Onecta myself, so I can’t test it personally.
Once this part is resolved, I’ll need solve this for the other items as well.
Greetings Alexander
Hi Alex,
I just tested your version, and it works fine. I tested the “POWER” activation on the heater and the water heater, and it works for both.
Let me know if you need me to run any more tests.
Thank you very much for your help.
Best regards
First of all, thank you very much for all the work you’ve put into this binding!
I’m running openHAB 5.1.4 and installed the SNAPSHOT2 build, but I’m getting the following error:
org.openhab.binding.onecta.internal.exception.DaikinCommunicationException: org.openhab.binding.onecta.internal.oauth2.auth.OAuthException: OAuth client service is not available.
One thing that surprised me is that the Account Thing doesn’t ask for a username or password. Am I correct in assuming that these are supposed to be provided through an OAuth login flow instead?
Do you have any idea what could be missing or misconfigured to cause the error above?
Thanks!
EDIT: I installed openhab-core-auth-oauth2client and restarted openHAB. Both the OAuth2 client bundle and the Onecta binding bundle are shown as active, but the error still persists.
Hi Robert,
Did you folow the setup manual at the top of this topic ?
Greetings Alexander
Sorta off-topic question, I know, but I have been unable so far to figure out a definite answer:
Is there any logically and feature-wise equivalent means to locally control a Daikin device without
dependency on the cloud?
Hi Markus,
Well, I would also prefer it if operating Daikin devices were possible without a cloud and everything could be controlled locally. But the problem is that the newer Daikin units are no longer locally accessible. As soon as these units are connected to Wi-Fi, they start communicating via the Onecta service.
There are controllers for sale at faikin.au, and with these, you could make the units locally accessible. However, from what I have read, you need a fair amount of technical knowledge, with the risk of damaging the unit.
Yes, but I didn’t see anything there about OAuth client dependencies.
Basically, I just copied the SNAPSHOT2 JAR into the addons directory and then created an Account Thing. Is there anything else I need to install or configure, or did I miss a step?
I mean this PDF document
Sorry, I missed that one before. I’ve found it now next to the JAR download link.
I got it working now, thanks a lot!
There were a few hiccups along the way:
The manual shows username/password fields in the Thing configuration, but I don’t see those. This does not seem to matter, though.
The redirect URI was generated as http instead of https in the OAuth dialog.
After successful authentication, it also tried to redirect to the http success link, so I got a 400 Bad Request error. However, that also does not seem to matter, since the authentication worked and the Account Thing is now online.
Thanks again for your help!
I have been running the binding for sometime now, and the account Thing regularly goes offline with a communication exception. When I restart the binding it comes online again.
COMMUNICATION_ERROR
org.openhab.binding.onecta.internal.exception.DaikinCommunicationException: java.util.concurrent.ExecutionException: java.net.UnknownHostException: api.onecta.daikineurope.com
Are others here experiencing this as well?
@Alexander_Drent would it maybe be an option for a future version of the binding to have some form of auto-reconnect?
Yes I have the same. I even created a rule that then automatically disables / enables the account thing to keep it up & running. That works .. ![]()
I will take a look at it. But first i try to get the pull request approved
Continuing the discussion from [Daikin Onecta (Cloud) Binding 4.0.0.0;5.0.0.0):
Today I’m experiencing issues with the binding. Not the first time I get (smaller) issues which I can easily solve by disabling and enabling the binding via the guy. Today this is not working. I’m using binding version 5.0.0.202507270959 running on Openhab 5.1. Here are the details
runtimeInfo:
version: 5.1.0
buildString: Release Build
locale: en-US
systemInfo:
configFolder: /openhab/conf
userdataFolder: /openhab/userdata
logFolder: /openhab/userdata/logs
javaVersion: 21.0.9
javaVendor: Debian
osName: Linux
osVersion: 6.6.31+rpt-rpi-v8
osArchitecture: aarch64
availableProcessors: 4
freeMemory: 96884072
totalMemory: 994050048
uptime: 13219857
startLevel: 100
addons:
* automation-jsscripting
* binding-homewizard
* binding-matter
* binding-mqtt
* binding-nest
* binding-network
* binding-somfytahoma
* binding-telegram
* misc-openhabcloud
* persistence-mapdb
* persistence-rrd4j
* transformation-jsonpath
clientInfo:
device:
ios: false
android: false
androidChrome: false
desktop: true
iphone: false
ipod: false
ipad: false
edge: false
ie: false
firefox: false
macos: true
windows: false
cordova: false
electron: false
capacitor: false
nwjs: false
webView: false
webview: false
standalone: false
os: macos
pixelRatio: 2
prefersColorScheme: dark
isSecureContext: false
locationbarVisible: true
menubarVisible: true
navigator:
cookieEnabled: true
deviceMemory: N/A
hardwareConcurrency: 8
language: en-BE
languages:
* en-BE
* nl-BE
* nl
* fr-BE
* fr
* en-GB
* en-US
* en
onLine: true
platform: MacIntel
screen:
width: 1800
height: 1169
colorDepth: 30
support:
touch: false
pointerEvents: true
passiveListener: true
intersectionObserver: true
themeOptions:
dark: dark
autoDarkMode: true
bars: light
homeNavBar: default
homeBackground: default
disableExpandableCardAnimation: false
blocklyRenderer: null
disablePageTransitionAnimation: false
hideChatInput: false
webAudio: false
visibleBreakpointDisabled: false
userAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36
(KHTML, like Gecko) Chrome/150.0.0.0 Safari/537.36
timestamp: 2026-08-05T20:05:48.427Z
This is the debug from the binding after doing a bundle:nnn restart
2026-08-05 20:51:54.157 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : ServiceFactory.getService()
2026-08-05 20:51:54.159 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : Checking constructor public org.openhab.binding.onecta.internal.service.DeviceDiscoveryService()
2026-08-05 20:51:54.159 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : Found constructor with 0 arguments : public org.openhab.binding.onecta.internal.service.DeviceDiscoveryService()
2026-08-05 20:51:54.160 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : This thread collected dependencies
2026-08-05 20:51:54.160 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : getService (ServiceFactory) dependencies collected.
2026-08-05 20:51:54.160 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : Querying state satisfied
2026-08-05 20:51:54.160 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2026-08-05 20:51:54.161 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : getting activate: activate
2026-08-05 20:51:54.162 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : Locating method activate in class org.openhab.binding.onecta.internal.service.DeviceDiscoveryService
2026-08-05 20:51:54.163 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : Declared Method org.openhab.binding.onecta.internal.service.DeviceDiscoveryService.activate([interface org.osgi.service.component.ComponentContext]) not found
2026-08-05 20:51:54.163 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : Found activate method: public void org.openhab.binding.onecta.internal.service.DeviceDiscoveryService.activate()
2026-08-05 20:51:54.164 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : invoking activate: activate: parameters []
2026-08-05 20:51:54.164 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : invoked activate: activate
2026-08-05 20:51:54.165 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : Changed state from satisfied to active
2026-08-05 20:51:54.168 [DEBUG] [ernal.service.DeviceDiscoveryService] - Starting background discovery
2026-08-05 20:51:54.170 [DEBUG] [ernal.service.DeviceDiscoveryService] - Scanning for devices
2026-08-05 20:51:54.171 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta indoorUnit unit 'Eetkamer' with ID '35fab2c8-c92c-4893-9181-bf20bda5058d'
2026-08-05 20:51:54.172 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta climateControl unit 'Eetkamer' with ID '35fab2c8-c92c-4893-9181-bf20bda5058d'
2026-08-05 20:51:54.172 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta gateway unit 'Eetkamer' with ID '35fab2c8-c92c-4893-9181-bf20bda5058d'
2026-08-05 20:51:54.173 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta indoorUnit unit 'Jerne Airco' with ID '5c14aa82-c164-4aeb-a195-4c44170e7bc2'
2026-08-05 20:51:54.174 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta climateControl unit 'Jerne Airco' with ID '5c14aa82-c164-4aeb-a195-4c44170e7bc2'
2026-08-05 20:51:54.175 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta gateway unit 'Jerne Airco' with ID '5c14aa82-c164-4aeb-a195-4c44170e7bc2'
2026-08-05 20:51:54.176 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta indoorUnit unit 'Birte Airco' with ID '645cc908-7723-462e-9e97-59136841bec5'
2026-08-05 20:51:54.176 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta climateControl unit 'Birte Airco' with ID '645cc908-7723-462e-9e97-59136841bec5'
2026-08-05 20:51:54.177 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta gateway unit 'Birte Airco' with ID '645cc908-7723-462e-9e97-59136841bec5'
2026-08-05 20:51:54.178 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta indoorUnit unit 'Uitbreiding' with ID '85766d6e-2ddc-427c-9e35-8bf6b7b51dfd'
2026-08-05 20:51:54.178 [DEBUG] [internal.handler.OnectaBridgeHandler] - initialize.
2026-08-05 20:51:54.178 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta climateControl unit 'Uitbreiding' with ID '85766d6e-2ddc-427c-9e35-8bf6b7b51dfd'
2026-08-05 20:51:54.179 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta gateway unit 'Uitbreiding' with ID '85766d6e-2ddc-427c-9e35-8bf6b7b51dfd'
2026-08-05 20:51:54.180 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta indoorUnit unit 'Ouders Airco' with ID '972c732b-9c69-4a82-a4ab-a7bb47cb4445'
2026-08-05 20:51:54.181 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta climateControl unit 'Ouders Airco' with ID '972c732b-9c69-4a82-a4ab-a7bb47cb4445'
2026-08-05 20:51:54.183 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta gateway unit 'Ouders Airco' with ID '972c732b-9c69-4a82-a4ab-a7bb47cb4445'
2026-08-05 20:51:54.202 [DEBUG] [nternal.handler.OnectaGatewayHandler] - refreshDevice : GATEWAY,
2026-08-05 20:51:54.204 [DEBUG] [nternal.handler.OnectaGatewayHandler] - refreshDevice : GATEWAY,
2026-08-05 20:51:54.214 [DEBUG] [nternal.handler.OnectaGatewayHandler] - refreshDevice : GATEWAY,
2026-08-05 20:51:54.215 [DEBUG] [nternal.handler.OnectaGatewayHandler] - refreshDevice : GATEWAY,
2026-08-05 20:51:54.225 [DEBUG] [nternal.handler.OnectaGatewayHandler] - refreshDevice : GATEWAY,
2026-08-05 20:51:54.236 [DEBUG] [rnal.handler.OnectaIndoorUnitHandler] - refreshDevice : INDOORUNIT,
2026-08-05 20:51:54.238 [DEBUG] [rnal.handler.OnectaIndoorUnitHandler] - refreshDevice : INDOORUNIT,
2026-08-05 20:51:54.243 [DEBUG] [rnal.handler.OnectaIndoorUnitHandler] - refreshDevice : INDOORUNIT,
2026-08-05 20:51:54.258 [DEBUG] [internal.handler.OnectaDeviceHandler] - refreshDevice : CLIMATECONTROL, Jerne Airco
2026-08-05 20:51:54.283 [DEBUG] [internal.handler.OnectaDeviceHandler] - refreshDevice : CLIMATECONTROL, Uitbreiding
2026-08-05 20:51:54.286 [DEBUG] [internal.handler.OnectaDeviceHandler] - refreshDevice : CLIMATECONTROL, Ouders Airco
2026-08-05 20:51:54.295 [DEBUG] [internal.handler.OnectaDeviceHandler] - refreshDevice : CLIMATECONTROL, Birte Airco
2026-08-05 20:51:54.306 [DEBUG] [internal.handler.OnectaDeviceHandler] - refreshDevice : CLIMATECONTROL, Eetkamer
2026-08-05 20:51:54.315 [DEBUG] [rnal.handler.OnectaIndoorUnitHandler] - refreshDevice : INDOORUNIT,
2026-08-05 20:51:54.322 [DEBUG] [ta.internal.api.Enums$FanMovementHor] - Unexpected FanMovementHor value of "null"
2026-08-05 20:51:54.326 [DEBUG] [ta.internal.api.Enums$FanMovementHor] - Unexpected FanMovementHor value of "null"
2026-08-05 20:51:54.331 [DEBUG] [rnal.handler.OnectaIndoorUnitHandler] - refreshDevice : INDOORUNIT,
2026-08-05 20:51:54.483 [ERROR] [oauth2client.internal.OAuthConnector] - grant type refresh_token to URL https://idp.onecta.daikineurope.com/v1/oidc/token failed with error code invalid_grant, description The provided authorization code or refresh token is invalid.
2026-08-05 20:51:54.486 [DEBUG] [uth2.auth.OpenHabOAuthTokenRefresher] - Cannot obtain access token from persistent storage.
org.openhab.core.auth.client.oauth2.OAuthResponseException: null
at org.openhab.core.auth.oauth2client.internal.OAuthConnector.lambda$0(OAuthConnector.java:96) ~[?:?]
at com.google.gson.internal.bind.TreeTypeAdapter.read(TreeTypeAdapter.java:95) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:1359) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:1260) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:1170) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:1107) ~[?:?]
at org.openhab.core.auth.oauth2client.internal.OAuthConnector.doRequest(OAuthConnector.java:368) ~[?:?]
at org.openhab.core.auth.oauth2client.internal.OAuthConnector.grantTypeRefreshToken(OAuthConnector.java:227) ~[?:?]
at org.openhab.core.auth.oauth2client.internal.OAuthClientServiceImpl.refreshTokenInner(OAuthClientServiceImpl.java:338) ~[?:?]
at org.openhab.core.auth.oauth2client.internal.OAuthClientServiceImpl.getAccessTokenResponse(OAuthClientServiceImpl.java:379) ~[?:?]
at org.openhab.binding.onecta.internal.oauth2.auth.OpenHabOAuthTokenRefresher.getAccessTokenFromStorage(OpenHabOAuthTokenRefresher.java:121) ~[?:?]
at org.openhab.binding.onecta.internal.api.OnectaSignInClient.getToken(OnectaSignInClient.java:66) ~[?:?]
at org.openhab.binding.onecta.internal.api.OnectaSignInClient.isOnline(OnectaSignInClient.java:74) ~[?:?]
at org.openhab.binding.onecta.internal.api.OnectaConnectionClient.isOnline(OnectaConnectionClient.java:89) ~[?:?]
at org.openhab.binding.onecta.internal.handler.OnectaBridgeHandler.initialize(OnectaBridgeHandler.java:84) ~[?:?]
at jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:580) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:149) ~[?:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:317) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642) ~[?:?]
at java.lang.Thread.run(Thread.java:1583) [?:?]
2026-08-05 20:51:54.495 [DEBUG] [internal.handler.OnectaBridgeHandler] - pollDevices.
When I perform an disable enable using the things gui I get this error
2026-08-05 21:21:43.187 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : ServiceFactory.getService()
2026-08-05 21:21:43.187 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : This thread collected dependencies
2026-08-05 21:21:43.188 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : getService (ServiceFactory) dependencies collected.
2026-08-05 21:21:43.188 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : Querying state satisfied
2026-08-05 21:21:43.188 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2026-08-05 21:21:43.189 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : invoking activate: activate: parameters []
2026-08-05 21:21:43.189 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : invoked activate: activate
2026-08-05 21:21:43.189 [DEBUG] [ernal.service.DeviceDiscoveryService] - bundle org.openhab.binding.onecta:5.0.0.202507270959 (249)[org.openhab.binding.onecta.internal.service.DeviceDiscoveryService(426)] : Changed state from satisfied to active
2026-08-05 21:21:43.192 [DEBUG] [ernal.service.DeviceDiscoveryService] - Starting background discovery
2026-08-05 21:21:43.192 [DEBUG] [ernal.service.DeviceDiscoveryService] - Scanning for devices
2026-08-05 21:21:43.194 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta indoorUnit unit 'Eetkamer' with ID '35fab2c8-c92c-4893-9181-bf20bda5058d'
2026-08-05 21:21:43.194 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta climateControl unit 'Eetkamer' with ID '35fab2c8-c92c-4893-9181-bf20bda5058d'
2026-08-05 21:21:43.195 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta gateway unit 'Eetkamer' with ID '35fab2c8-c92c-4893-9181-bf20bda5058d'
2026-08-05 21:21:43.195 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta indoorUnit unit 'Jerne Airco' with ID '5c14aa82-c164-4aeb-a195-4c44170e7bc2'
2026-08-05 21:21:43.196 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta climateControl unit 'Jerne Airco' with ID '5c14aa82-c164-4aeb-a195-4c44170e7bc2'
2026-08-05 21:21:43.196 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta gateway unit 'Jerne Airco' with ID '5c14aa82-c164-4aeb-a195-4c44170e7bc2'
2026-08-05 21:21:43.197 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta indoorUnit unit 'Birte Airco' with ID '645cc908-7723-462e-9e97-59136841bec5'
2026-08-05 21:21:43.197 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta climateControl unit 'Birte Airco' with ID '645cc908-7723-462e-9e97-59136841bec5'
2026-08-05 21:21:43.198 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta gateway unit 'Birte Airco' with ID '645cc908-7723-462e-9e97-59136841bec5'
2026-08-05 21:21:43.198 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta indoorUnit unit 'Uitbreiding' with ID '85766d6e-2ddc-427c-9e35-8bf6b7b51dfd'
2026-08-05 21:21:43.199 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta climateControl unit 'Uitbreiding' with ID '85766d6e-2ddc-427c-9e35-8bf6b7b51dfd'
2026-08-05 21:21:43.199 [DEBUG] [internal.handler.OnectaBridgeHandler] - initialize.
2026-08-05 21:21:43.204 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta gateway unit 'Uitbreiding' with ID '85766d6e-2ddc-427c-9e35-8bf6b7b51dfd'
2026-08-05 21:21:43.205 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta indoorUnit unit 'Ouders Airco' with ID '972c732b-9c69-4a82-a4ab-a7bb47cb4445'
2026-08-05 21:21:43.206 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta climateControl unit 'Ouders Airco' with ID '972c732b-9c69-4a82-a4ab-a7bb47cb4445'
2026-08-05 21:21:43.206 [DEBUG] [ernal.service.DeviceDiscoveryService] - Discovered a onecta gateway unit 'Ouders Airco' with ID '972c732b-9c69-4a82-a4ab-a7bb47cb4445'
2026-08-05 21:21:43.218 [DEBUG] [nternal.handler.OnectaGatewayHandler] - refreshDevice : GATEWAY,
2026-08-05 21:21:43.220 [DEBUG] [nternal.handler.OnectaGatewayHandler] - refreshDevice : GATEWAY,
2026-08-05 21:21:43.222 [DEBUG] [nternal.handler.OnectaGatewayHandler] - refreshDevice : GATEWAY,
2026-08-05 21:21:43.237 [DEBUG] [nternal.handler.OnectaGatewayHandler] - refreshDevice : GATEWAY,
2026-08-05 21:21:43.237 [DEBUG] [rnal.handler.OnectaIndoorUnitHandler] - refreshDevice : INDOORUNIT,
2026-08-05 21:21:43.241 [DEBUG] [nternal.handler.OnectaGatewayHandler] - refreshDevice : GATEWAY,
2026-08-05 21:21:43.244 [DEBUG] [rnal.handler.OnectaIndoorUnitHandler] - refreshDevice : INDOORUNIT,
2026-08-05 21:21:43.252 [DEBUG] [internal.handler.OnectaDeviceHandler] - refreshDevice : CLIMATECONTROL, Jerne Airco
2026-08-05 21:21:43.257 [DEBUG] [rnal.handler.OnectaIndoorUnitHandler] - refreshDevice : INDOORUNIT,
2026-08-05 21:21:43.273 [DEBUG] [internal.handler.OnectaDeviceHandler] - refreshDevice : CLIMATECONTROL, Uitbreiding
2026-08-05 21:21:43.295 [DEBUG] [internal.handler.OnectaDeviceHandler] - refreshDevice : CLIMATECONTROL, Ouders Airco
2026-08-05 21:21:43.304 [DEBUG] [internal.handler.OnectaDeviceHandler] - refreshDevice : CLIMATECONTROL, Eetkamer
2026-08-05 21:21:43.317 [DEBUG] [ta.internal.api.Enums$FanMovementHor] - Unexpected FanMovementHor value of "null"
2026-08-05 21:21:43.319 [DEBUG] [internal.handler.OnectaDeviceHandler] - refreshDevice : CLIMATECONTROL, Birte Airco
2026-08-05 21:21:43.319 [DEBUG] [ta.internal.api.Enums$FanMovementHor] - Unexpected FanMovementHor value of "null"
2026-08-05 21:21:43.323 [DEBUG] [rnal.handler.OnectaIndoorUnitHandler] - refreshDevice : INDOORUNIT,
2026-08-05 21:21:43.327 [DEBUG] [rnal.handler.OnectaIndoorUnitHandler] - refreshDevice : INDOORUNIT,
2026-08-05 21:21:43.486 [ERROR] [oauth2client.internal.OAuthConnector] - grant type refresh_token to URL https://idp.onecta.daikineurope.com/v1/oidc/token failed with error code invalid_grant, description The provided authorization code or refresh token is invalid.
2026-08-05 21:21:43.490 [DEBUG] [uth2.auth.OpenHabOAuthTokenRefresher] - Cannot obtain access token from persistent storage.
2026-08-05 21:21:43.498 [DEBUG] [internal.handler.OnectaBridgeHandler] - pollDevices
I’ll probably remove the bundle and try to set it up once more unless there is something else I can try?
I’ve upgraded to 5.2. Onecta binding version is 5.0.0.202507270959 but still get the following error;
I’ll reinitialize the binding. Probably something got invalidated over time and is not refreshing
