Thanks for the support,
is it normal that the execution of amdump does not show any message of the operation it is doing?
see my attach file:
see my attach file:
Yes. You can run amreport when amdump has finished.
Ok for a amreport,
but amdump is normal that donât show me anything when the process is running?
no trace me any error, any percentage⊠nothingâŠ
after 20 minutes my terminal is stuck. I just must waiting?
Yes it is normal.
Put it into background using & at the end so your terminal doesnât lock up.
But you normally neednât manually run it as itâs started from cron.
thank you so much,
after 1 hour the backup is finished.
I just read through this thread when gathering information about the amanda
backup functionality included in openHABian. At the moment I have a working setup of using the openhab-cli backup
on a automated basis including my nas as backup device.
To understand it right where the difference between amanda
and openhab-cli
is:
openhab-cli
functionality only backups the openHAB related configuration files like things, items, rules and others. Personal system based configuration with auto mounts and/or cron jobs wonât be included. So in case of a desaster recovery one needs to install a clean OS first and then could restore the openHAB configuration. All system based configuration will need to be added manually.amanda
based functionality could backup the whole system including OS if configured in the right way. In case of a desaster recovery one needs to restore the backup to a new sd card and the system would be up and running like before.Can u @mstormi please clarify if my suggestions are correct? Or anyone else having deeper knowledge of the different backup options?
Of course I did Just wanted to double check and repeat what I have understood so far.
Just thinking what project to start first: Upgrade to 2.5 or get amanda running. May be the time between christmas and new year lasts for both
When given the choice to make changes or make a backup first, always choose the make the backup first.
Iâd like to add to that openhab-cli backup
just redirects to the backup script that comes with openHAB ($OPENHAB_HOME/runtime/bin
) . Those scripts mean that everyone (regardless of operating system) has way of backing up and restoring openHAB specific configurations.
