DALI binding does not update lamp status on external bus events
Hi there
I’m trying to add all my lamps to OH using the official DALI binding. to that end, I installed the daliserver, as documented and configured the lights. I can also control the lights from the web UI and the app. However, when I use one of the switches in my home (also on DALI), the app does not update to the new status (read: it does not process external events). The daliserver logs show that events are received however. Is there something working with my configuration or is this a limitation of the binding?
My installation uses OH 4.0.1 with a Lunatone USB DALI (article 89454248). The binding does not report any errors.
Thanks!
op
