Just wondering if someone can help out a newbie.
I have tried for a couple of days now to get my danalock to lock the door, when I click 1 time on the Fibaro Button, without luck using the paperui site, but I don’t really understand the Fibaro button settings, and I can’t find any understandable documentation on it.
Does anybody happen to have the same setup that can help me out with some guidiance, or at least tell me what settings I need under the Fibaro Button to trigger the Danalock?
I finally go the things working together I missed that I had to add a .0 to the scene, and not just 1
Now, I am trying to get the Fibaro Button to get activated with Google home, but as far as I can see, The Fibaro Button is not a normal switch, but a scene selector?
I have tried to add both the Switchable and Lighting tag to the button in the home.items file, but google will not link the account then.
I have by the way added a rule, that with 1 click on the Fibaro button, it will unlock the lock (not unlock of course) Number zwave_device_8581b43b_node4_scene_number “Scene Number” [ “Switchable”]
If I do the same with my Danalock, there’s no problem, and Google will link the account: Switch zwave_device_8581b43b_node6_lock_door “Door Lock” [ “Switchable”]
But that way it’s possible to both lock and unlock my door with voice, which I don’t want.
Can you please tell me if it’s possible to get the Fibaro button controlable by Google home somehow?
Yes, exactly. Your virtual switch can be triggered by Google Home, and your rule can then trigger on “virtual_item received command ON”.
I would also suggest a second rule that synchronizes the virtual item with the actual state of the lock. Toggling it to off won’t do anything (since you won’t have a rule for that), but you can then see its status in the Google Home app.
