I’ve been using the. Danfoss TRV LC-13 for years without issues. Over the summer the batteries were empty, and after replacing the LC-13 is not getting through initialisation (or so either the controller AEOtec controller v2, or the LC13 thinks). I’ve waited for approx 10 days for the initialisation to finish.
Below are the zwave debug log, any suggestions short of excluding and re-including the device?
Thanks,
Niels
2020-11-16 13:49:12.542 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:624b62a8:node10:battery-level linked - polling started.
2020-11-16 13:49:12.542 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:624b62a8:node10:thermostat_setpoint_heating linked - polling started.
2020-11-16 13:49:20.583 [DEBUG] [col.serialmessage.SerialApiGetInitDataMessageClass] - NODE 10: Node found
2020-11-16 13:49:20.594 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - NODE 10: Init node thread start
2020-11-16 13:49:20.731 [DEBUG] [ternal.protocol.initialization.ZWaveNodeSerializer] - NODE 10: Serializing from file /openhab/userdata/zwave/network_d55e6778__node_10.xml
2020-11-16 13:49:20.901 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - NODE 10: Restore from config: Ok.
2020-11-16 13:49:20.901 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_THERMOSTAT_OPERATING_STATE, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_CLOCK, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_THERMOSTAT_SETPOINT, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_MULTI_CMD, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_WAKE_UP, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_PROTECTION, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_MANUFACTURER_SPECIFIC, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_METER, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_POWERLEVEL, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_VERSION, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_CLIMATE_CONTROL_SCHEDULE, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_BATTERY, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_SWITCH_ALL, endpoint 0 created
2020-11-16 13:49:20.902 [DEBUG] [nhab.binding.zwave.discovery.ZWaveDiscoveryService] - NODE 10: Device discovery completed
2020-11-16 13:49:21.667 [DEBUG] [nhab.binding.zwave.discovery.ZWaveDiscoveryService] - NODE 10: Device discovery resolved to thingType zwave:danfoss_lc13_00_000
2020-11-16 13:49:21.668 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 10: Starting initialisation from EMPTYNODE
2020-11-16 13:49:21.716 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - NODE 10: Init node thread finished
2020-11-16 13:49:21.716 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 10: Node advancer - advancing to IDENTIFY_NODE
2020-11-16 13:49:21.716 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 10: Node advancer: Initialisation starting
2020-11-16 13:49:21.731 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Controller status changed to ONLINE.
2020-11-16 13:49:21.731 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Controller is ONLINE. Starting device initialisation.
2020-11-16 13:49:21.732 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating node properties.
2020-11-16 13:49:21.732 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating node properties. MAN=2
2020-11-16 13:49:21.732 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating node properties. MAN=2. SET. Was 2
2020-11-16 13:49:21.732 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Properties synchronised
2020-11-16 13:49:21.732 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising Thing Node...
2020-11-16 13:49:21.764 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:624b62a8:node10:thermostat_setpoint_heating for QuantityType
2020-11-16 13:49:21.764 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:624b62a8:node10:thermostat_setpoint_heating for QuantityType
2020-11-16 13:49:21.764 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:624b62a8:node10:battery-level for PercentType
2020-11-16 13:49:21.764 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:624b62a8:node10:battery-level for PercentType
2020-11-16 13:49:21.766 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:624b62a8:node10:time_offset for DecimalType
2020-11-16 13:49:21.766 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:624b62a8:node10:time_offset for DecimalType
2020-11-16 13:49:21.766 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising cmd channel zwave:device:624b62a8:node10:alarm_general for OnOffType
2020-11-16 13:49:21.766 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Initialising state channel zwave:device:624b62a8:node10:alarm_general for OnOffType
2020-11-16 13:49:21.766 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Polling initialised at 600 seconds - start in 7200 milliseconds.
2020-11-16 13:49:21.767 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Device initialisation complete.
2020-11-16 13:49:21.858 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 10: ProtocolInfo
2020-11-16 13:49:21.858 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 10: Listening = false
2020-11-16 13:49:21.858 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 10: Routing = true
2020-11-16 13:49:21.858 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 10: Beaming = true
2020-11-16 13:49:21.858 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 10: Version = 4
2020-11-16 13:49:21.858 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 10: FLIRS = false
2020-11-16 13:49:21.858 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 10: Security = false
2020-11-16 13:49:21.858 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 10: Max Baud = 40000
2020-11-16 13:49:21.858 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 10: Basic = BASIC_TYPE_ROUTING_SLAVE
2020-11-16 13:49:21.858 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 10: Generic = GENERIC_TYPE_THERMOSTAT
2020-11-16 13:49:21.858 [DEBUG] [al.protocol.serialmessage.IdentifyNodeMessageClass] - NODE 10: Specific = SPECIFIC_TYPE_SETPOINT_THERMOSTAT
2020-11-16 13:49:21.858 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2020-11-16 13:49:21.859 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2020-11-16 13:49:21.859 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Version = 1, version set. Enabling extra functionality.
2020-11-16 13:49:21.859 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 10: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2020-11-16 13:49:21.859 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Creating new instance of command class COMMAND_CLASS_BASIC
2020-11-16 13:49:21.859 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 10: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2020-11-16 13:49:21.859 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 10: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2020-11-16 13:49:21.876 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 10: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@7d951196
2020-11-16 13:49:21.876 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 10: Node Init transaction completed with response COMPLETE
2020-11-16 13:49:21.876 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 10: Node advancer - advancing to REQUEST_NIF
2020-11-16 13:49:21.876 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2020-11-16 13:49:21.876 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 10: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@38978040
2020-11-16 13:49:21.876 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 10: Bump transaction 37 priority from Controller to Immediate
2020-11-16 13:49:21.876 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 10: Adding to device queue
2020-11-16 13:49:21.876 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 10: Added 37 to queue - size 14
2020-11-16 13:49:28.967 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Polling...
2020-11-16 13:49:28.967 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Polling deferred until initialisation complete
2020-11-16 13:59:28.967 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Polling...
2020-11-16 13:59:28.967 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 10: Polling deferred until initialisation complete
