Hi, I used to have my system running with 9 Danfoss Living Connect Z thermostats and it worked fine. I had to reinstall a new system recently and this time Openhab will not recognise them. I’m using an Aeotec Z-stick gen 5 as a controller which Openhab finds but when I pair with the thermostat it just sees unknown device. This is killing me a little bit - especially as it used to work and I have 9 of these things. By the way they are the open Z-wave version not the proprietary Danfoss protocol version.
I have openhabian latest version installed.
Does anyone know how I can get Openhab to recognise them? The are useless at the moment and it’s getting bloody cold!
Here are the logs from the Karaf console:
openhab> log:tail org.openhab.binding.zwave
21:15:06.980 [INFO ] [.zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
21:15:12.448 [INFO ] [ave.internal.protocol.ZWaveController] - Starting ZWave controller
21:15:12.452 [INFO ] [ave.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
21:17:13.512 [INFO ] [ave.internal.protocol.ZWaveController] - Starting ZWave controller
21:17:13.515 [INFO ] [ave.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
21:17:48.408 [WARN ] [zwave.discovery.ZWaveDiscoveryService] - NODE 2: Device discovery could not resolve to a thingType! Manufacturer data not known.
21:18:13.850 [WARN ] [zwave.discovery.ZWaveDiscoveryService] - NODE 2: Device discovery could not resolve to a thingType! Manufacturer data not known.
Many thanks in advance!
Tony
